Re: big block 400 timing
[Re: 73bbroadrunner]
#1387666
02/14/13 10:39 PM
02/14/13 10:39 PM
RapidRobert
I'd set the initial with the "vacuum guage method" then with that figure in hand set the slot length to get 36 total (vac adv capped for initial and total amounts) then play with the springs then hookup & play with the vac adv (if used) IN THAT ORDER. 38 may work OK depending on octane/scr/cam. Experiment & see what YOUR eng likes. EDIT other than the initial, for the subsequent 3 adjustments (actually 4 since the vac adv has 2 you can make) you want to stay just under the pinging point on each of em
#1387668
02/16/13 02:01 AM
02/16/13 02:01 AM
Posts: 10,233 Someplace you aren't
SomeCarGuy
I found that 34 degrees was the best for overall smooth performance. 38 worked OK, but I think it may have had some silent knock. Just play around with it and see. Going to depend on your particular engine and the gas you have locally.
I want my fair share
