Re: Anyone running a 408 stroker with 340 Exhaust Manifolds
[Re: Russ H.]
#1387417
02/15/13 01:31 AM
02/15/13 01:31 AM
RapidRobert
all I can add is they are 2&1/4 outlets & the dr one is somewhat restricted. I'd want better for 408 cubes but as you know headers are much more difficult to deal with
[Re: scatpacktom]
#1387419
02/15/13 01:33 PM
02/15/13 01:33 PM
Russ H.
I am
What cam are you using????????
[Re: Russ H.]
#1387421
02/15/13 08:07 PM
02/15/13 08:07 PM
Posts: 2,315 South, FL
cudaized
South, FL
I have a 416 stroker with factory 1970 340 exhaust manifolds - extrude honed. Cam specs: Cam: Hughes HE3844AL for high torque Lobe separation: 108 Installed centerline: 106 Intake Exhaust ----------------------------- Cam Lift 0.357 0.360 Valve Lift w/1.5:1 0.535 0.540 w/1.6:1 0.571 0.576 Valve Lash Settings .000" .000" Duration Advertised 286 290 @0.50" 237 244 Cam timing @ 0.50" Opens: 13 BTC 53 BBC Closes: 44 ABC 11 ATC 515 ft lbs of torque at 5,300 RPM. I think it runs good.
[Re: not_a_charger]
#1387424
02/15/13 08:22 PM
02/15/13 08:22 PM
Posts: 3,103 Phila Pa
scatpacktom
Phila Pa
Was the Extrude Honing worth the money? I know it ain't cheap.
No its not
[Re: ScottSmith_Harms]
#1387427
02/16/13 08:55 PM
02/16/13 08:55 PM
cudaized
South, FL
The problem with my engine is not the exhaust, the cork is the intake at this point, there may well be some more HP available from the manifolds once I open up the intake etc.. Tough to say until the exhaust becomes the biggest restriction.
I went searching for this too. I found a little bit, but don't get your hopes up to high. Your numbers are about right for these "stock" appearing set ups.
[Re: cudaized]
#1387429
02/17/13 03:00 AM
02/17/13 03:00 AM
Posts: 6,906 IL, Aurora
ademon
IL, Aurora
right but there are more than a few that look stock running much higher CR, and much bigger solid rollers, with tricked out carbs and intakes, many of those engines are well over 500hp
[Re: ademon]
#1387430
02/17/13 11:46 AM
02/17/13 11:46 AM
cudaized
South, FL
Yes they are. Here is what I ended up with.
[Re: Russ H.]
#1387431
02/17/13 02:56 PM
02/17/13 02:56 PM
scatpacktom
Phila Pa
Are any of you F.A.S.T. or stock appearing guys running hydraulic roller cams in stroked small blocks with the 340 HP Exhaust manifolds? If so, whose cam and specs?
A hydraulic cam has no business being in a race engine.
[Re: Russ H.]
#1387432
02/17/13 03:00 PM
02/17/13 03:00 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Most shelf type cams are totally wrong for a engine running exhaust manifolds.There are several things to consider with manifolds, and what you " think should work", probably is way off base. They have " special needs", just like most of us.
RIP Monte Smith
[Re: CompWedgeEngines]
#1387433
02/17/13 03:07 PM
02/17/13 03:07 PM
Posts: 3,300 Northern Indiana
Dunnuck Racing
Northern Indiana
I agree 100% . Get in touch with somebody that builds and tests several engines and has a good idea of what it takes. Most cam companies tech lines get it wrong too. Keith
