Summit Twist Tite Fuel Line? #1387343
02/14/13 02:09 PM
02/14/13 02:09 PM
tboomer Offline OP
tboomer  Offline OP
Anyone use this from cell to regulator? Says it is NHRA approved but not recomended?
Re: Summit Twist Tite Fuel Line? [Re: tboomer] #1387344
02/14/13 02:16 PM
02/14/13 02:16 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
were's your regulator? As far as I know you can only have a small amount of rubber line. I'm using it from my tank to the filter, from the filter to the pump, and from the pump to the hard line. Maybe 10" in total. Works fine. Had it 2 years w/ no issues.
Coming soon!!!!
Re: Summit Twist Tite Fuel Line? [Re: Mr.Yuck] #1387345
02/14/13 02:26 PM
02/14/13 02:26 PM
tboomer Offline OP
tboomer  Offline OP
Regulator is on the pass. side inner fender....
Re: Summit Twist Tite Fuel Line? [Re: tboomer] #1387346
02/14/13 02:35 PM
02/14/13 02:35 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
are you talking about the rubber or braided? to my knowledge you cannot run rubber from the tank to the front. like this??
http://www.summitracing.com/parts/sum-220785-b/overview/
Re: Summit Twist Tite Fuel Line? [Re: Mr.Yuck] #1387347
02/14/13 02:38 PM
02/14/13 02:38 PM
tboomer Offline OP
tboomer  Offline OP
Yes...That is the stuff..
Re: Summit Twist Tite Fuel Line? [Re: tboomer] #1387348
02/14/13 05:48 PM
02/14/13 05:48 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
You can't run that from your fuel cell alllll the way to the regulator as far as I know.
Re: Summit Twist Tite Fuel Line? [Re: Mr.Yuck] #1387349
02/14/13 06:45 PM
02/14/13 06:45 PM
tboomer Offline OP
tboomer  Offline OP
Thank you. I wonder why they say it is NHRA legal?
Re: Summit Twist Tite Fuel Line? [Re: Mr.Yuck] #1387350
02/14/13 07:03 PM
02/14/13 07:03 PM
Q
Quicktree Offline
Quicktree  Offline
Q
yes you can it's legal, everybody is using it.
Re: Summit Twist Tite Fuel Line? [Re: Quicktree] #1387351
02/14/13 07:06 PM
02/14/13 07:06 PM
tboomer Offline OP
tboomer  Offline OP
That a fact,Tony? Sure would save some money for sure!
Re: Summit Twist Tite Fuel Line? [Re: Quicktree] #1387352
02/14/13 07:18 PM
02/14/13 07:18 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Stop making sense...
It's NOT rubber line.
Re: Summit Twist Tite Fuel Line? [Re: RobX4406] #1387353
02/14/13 07:23 PM
02/14/13 07:23 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
it's NOT? I think you need to READ the link.
"Hose, Twist-Tite, Rubber, Black, -6 AN, 20 ft. Length, Each"
go ahead and run it all the way and try nd pass tech. What's that 6 letter word in the middle?
Re: Summit Twist Tite Fuel Line? [Re: Mr.Yuck] #1387354
02/14/13 07:38 PM
02/14/13 07:38 PM
RobX4406 Offline
RobX4406  Offline
It's not a "rubber" line in NHRA's eyes because it requires no hose clamps. Go stay in a holiday inn.
I have run similar stuff from front to rear and ALWAYS passed tech... why??? Because it's an approved line mr. know it all.
Grab a rule book and read it for once before you step on ground you know nothing about! There's a list of approved non- steel braided hoses and this one was on it last I checked, along with Jegs style of this hose as well.
Let me help you... Page 89
http://www.nhra.com/userfiles/file/NHRAAcceptedProducts.pdf
Re: Summit Twist Tite Fuel Line? [Re: RobX4406] #1387355
02/14/13 07:40 PM
02/14/13 07:40 PM
Renton Washington
Triple Threat Offline
Renton Washington
Re: Summit Twist Tite Fuel Line? [Re: Mr.Yuck] #1387356
02/14/13 07:48 PM
02/14/13 07:48 PM
Q
Quicktree Offline
Quicktree  Offline
Q
dude it's legal
Re: Summit Twist Tite Fuel Line? [Re: Mr.Yuck] #1387357
02/14/13 07:55 PM
02/14/13 07:55 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Well the line I run has that 6 letter word [ rubber ] in it also, but its covered with stainless braid.
Re: Summit Twist Tite Fuel Line? [Re: Quicktree] #1387358
02/14/13 07:55 PM
02/14/13 07:55 PM
RobX4406 Offline
RobX4406  Offline
dude it's legal
I wish I had the pic of Andy Mayes car with all the pushlock fuel lines... must have been 100 ft in the engine compartment...
Re: Summit Twist Tite Fuel Line? [Re: RobX4406] #1387359
02/14/13 07:57 PM
02/14/13 07:57 PM
Q
Quicktree Offline
Quicktree  Offline
Q
dude it's legal
everyone runs it now, it passes tech every race i just ordered 35' of it.
Re: Summit Twist Tite Fuel Line? [Re: Quicktree] #1387360
02/14/13 08:01 PM
02/14/13 08:01 PM
RobX4406 Offline
RobX4406  Offline
Most of those push lock style lines are not rubber like the .99/ft stuff you buy at autozone. It's a synthetic rubber compound with additional woven material.
Want to use summits description as gospel, be my guest. Not the first time their descriptions have been off base.
Re: Summit Twist Tite Fuel Line? [Re: Mr.Yuck] #1387361
02/14/13 08:03 PM
02/14/13 08:03 PM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
Mr. YukYuk....it's legal....most braided stainless is rubber too
It's legal because it has braided reinforcement and because NHRA says so....
Re: Summit Twist Tite Fuel Line? [Re: Quicksilver440] #1387362
02/14/13 08:09 PM
02/14/13 08:09 PM
Central Valley, CA.
Central Valley, CA.
The reason summit says It's not recommended as fuel line is that they had too many people complain that their garage smells like fuel with that line....for almost the same price you can get braided Aeroquip stainless teflon line that will last forever. Check out www.aeroquip.cc. -8 is $3.50 ft in bulk....$4.00 ft in exact lengths. It won't smell up your garage either.
