'68 headliner issues #1387278
02/14/13 12:03 PM
02/14/13 12:03 PM
scarface06 Offline OP
I have a '68 Satellite and I'm getting ready to put in a new headliner. The one that is in the car now does not appear to be original, it looks too new. But there are no exposed sail panels. The headliner goes all the way from the front to the back glass in a single piece. There is sail panel board under the headliner in the back that I guess it was glued to.
I do have the tack strips that go all the way around the back window, but not the vertical pieces that the sides of the headliner hook to and are then covered by the exposed sail panel.
So my question is, did '68 come without exposed sail panels or am I missing something?
Re: '68 headliner issues [Re: scarface06] #1387279
02/14/13 04:50 PM
02/14/13 04:50 PM
New Kent, Va.
bobbyb Offline
bobbyb  Offline
New Kent, Va.
My 68 Satellite doesn't have the exposed ones.
2004 Dodge Rumble Bee 5.7 Hemi
1969 Plymouth Roadrunner
Re: '68 headliner issues [Re: bobbyb] #1387280
02/14/13 05:16 PM
02/14/13 05:16 PM
Avondale AZ
Prodart440 Offline
Prodart440  Offline
Avondale AZ
My 68 road runner has them.
Aaron
68 Roadrunner 383/AT
69 Dart GT Conv. 383/AT
05 Dodge Ram 4x4 Cummins
06 GoManGo R/T Daytona #757
68 Coronet 440
Re: '68 headliner issues [Re: scarface06] #1387281
02/14/13 05:24 PM
02/14/13 05:24 PM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
No exposed sail panels....there are cardboard panels that are under the c-pillar(sail) area of the headliner...the only tack strips are the ones that surround the rear window. Otherwise, the headliner just glues to the parcel shelf area where the pillar and shelf panel meet, and also to the roof pillar at the quarter windows.
At least this is how my '68 GTX and Satellite parts car were.
I think the Road Runner may have been different.
I hope I understood your post....
Re: '68 headliner issues [Re: Prodart440] #1387282
02/14/13 05:26 PM
02/14/13 05:26 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
It might be an early/late thing with Satellites and Road Runners. My 68 RR was a late build (May 68) and it has the boards on the inside.
Re: '68 headliner issues [Re: 68jim] #1387283
02/14/13 05:28 PM
02/14/13 05:28 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
#2, Headliner is silver but looks white with the flash...
Re: '68 headliner issues [Re: 68jim] #1387284
02/14/13 05:31 PM
02/14/13 05:31 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
Pics of sail panels.
Re: '68 headliner issues [Re: 68jim] #1387285
02/14/13 05:45 PM
02/14/13 05:45 PM
The cardboard sail panels were actually there to prevent the headliner from billowing / puffing out when you closed either the doors or the trunk. Unless you have the windows open, the sudden rush of air from closing the door or trunk will cause the headliner to "inflate" like a balloon in that area since the area behind it is all open and would be the path of least ressitance. Having the cardboard in place acts as a deflector so it will not cause the headliner to tear or become unglued and cause it to sag in that area.
Re: '68 headliner issues [Re: Prodart440] #1387286
02/14/13 06:28 PM
02/14/13 06:28 PM
PEI Canada
chromedome426 Offline
PEI Canada
I had come to the conclusion that the early 68 b-bodies had the one piece roof liner going all the way down to the bottom of the rear piller. This style did have a small piece of cardboard hidden under the liner that was held onto the piller by a single nail type pin. It is hard to find pictures of this style installed with no wrinkles. I spent hours making mine perfect.
The later 68 b-bodies that I have worked on, all had the 69 style roof liner that stops part way down the rear piller, and then uses the visible cardboard sail panels to cover the bottom of the piller. These cardboard panels are a little bigger than the earlier hidden style cardboard. Depending on the trim level of the car this cover can be either covered with vinyl roof liner material or just colored cardboard. It is held on with two door panel style clips. This style roof liner was much faster & easier to install without the wrinkles.
So, for anyone that wants the later 68 roof liner & sail panels, you need to order them for a 69 or they may send you the wrong one.
If you don't have these vertical gripper teeth on the rear piller then you need the 68 style roof liner and sail panel.
Re: '68 headliner issues [Re: chromedome426] #1387287
02/14/13 08:04 PM
02/14/13 08:04 PM
Cool deal, you guys helped me figure it out. I thought I had some weird set up. I ordered the headliner from Yearone and it came with plain cardboard panels. I also, not knowing any better, ordered covered sail panels. So I guess I can go either way if I find the ther w tack strips.
Re: '68 headliner issues [Re: scarface06] #1387288
02/14/13 10:29 PM
02/14/13 10:29 PM
When I ordered my headliner back in 2000 from Legendary, I also ordered the cardboard panels which came through already covered in the material. Assuming this was correct, I installed them into my 69 charger. After the headliner installation guy cut down the extra material for the headliner, the job was done only to find out a few years later that it was NOT supposed to have the material attached to the cardboard but pulled over in front of it with it acting like an air deflector.
