1965 cable shift transmission #1387139
02/13/13 11:13 PM
02/13/13 11:13 PM
CHULA VISTA , CA
J_GAMALA Offline OP
J_GAMALA  Offline OP
CHULA VISTA , CA
i need theCLAMP BOLT that holds the park cable in place where can i get one thanks JAVIER
Re: 1965 cable shift transmission [Re: J_GAMALA] #1387140
02/14/13 12:38 AM
02/14/13 12:38 AM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
You might try torqueflite Patty.
This is the land of the free because of the brave
Re: 1965 cable shift transmission [Re: J_GAMALA] #1387141
02/14/13 04:08 PM
02/14/13 04:08 PM
Cab_Burge Online work
Cab_Burge  Online Work
1962 Dodge and Plymouth to 1965 will work, slant six 727 to the Hemi ones Last resort you could use a bolt and a lot of sealer to make one work, grind the middle down to a V to act as the pinch saddle like the stock ones did
Re: 1965 cable shift transmission [Re: Cab_Burge] #1387142
02/14/13 04:32 PM
02/14/13 04:32 PM
Casco, MI
Savoy1964 Offline
Savoy1964  Offline
Casco, MI
I might have a spare one at home I will check
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph
2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
Re: 1965 cable shift transmission [Re: Savoy1964] #1387143
02/17/13 01:06 PM
02/17/13 01:06 PM
CHULA VISTA , CA
J_GAMALA Offline OP
J_GAMALA  Offline OP
CHULA VISTA , CA
thanks again i really need this bolt and have not found one yet
Re: 1965 cable shift transmission [Re: J_GAMALA] #1387144
02/17/13 05:26 PM
02/17/13 05:26 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Those clamp bolts are in high demand because so many have been snapped off due to over-tightening. EZ does it.
Re: 1965 cable shift transmission [Re: John_Kunkel] #1387145
02/18/13 12:53 AM
02/18/13 12:53 AM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
..... to add ...some have even broken the alum casting
Re: 1965 cable shift transmission [Re: J_GAMALA] #1387146
02/19/13 12:08 AM
02/19/13 12:08 AM
CHULA VISTA , CA
J_GAMALA Offline OP
J_GAMALA  Offline OP
CHULA VISTA , CA
thanks to all that tried to help, and also THOSE THAT WERE ASKING A RIDICULOUS PRICE FOR THE CLAMP BOLT (you know who you are), i found one thanks to a local source here in San Diego
Re: 1965 cable shift transmission [Re: J_GAMALA] #1387147
02/19/13 10:32 AM
02/19/13 10:32 AM
Casco, MI
Savoy1964 Offline
Savoy1964  Offline
Casco, MI
Glad to hear you found one. I would of just sent it to you if I could of found it.
Re: 1965 cable shift transmission [Re: Savoy1964] #1387148
02/21/13 12:35 AM
02/21/13 12:35 AM
CHULA VISTA , CA
J_GAMALA Offline OP
J_GAMALA  Offline OP
CHULA VISTA , CA
thank you I know you would have, thanks again for looking
