4.2 or 5.0 Lever #1387111
02/13/13 09:42 PM
02/13/13 09:42 PM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
Any advantage one over the other in a 904 full race under 350HP? Thanks
Re: 4.2 or 5.0 Lever [Re: A/MP] #1387112
02/13/13 10:19 PM
02/13/13 10:19 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
Not at that power level.
Alan Jones
Re: 4.2 or 5.0 Lever [Re: LA360] #1387113
02/13/13 10:26 PM
02/13/13 10:26 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
T think a 3.8 would work just fine.
Re: 4.2 or 5.0 Lever [Re: A/MP] #1387114
02/13/13 10:34 PM
02/13/13 10:34 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
Most trans guys will tell you to avoid the 5.0 anymore and use the 4.7. I use the 4.7 in everything I build.
Keith
Re: 4.2 or 5.0 Lever [Re: Dunnuck Racing] #1387115
02/13/13 11:14 PM
02/13/13 11:14 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
I use the 4.2 whenever possible.
Re: 4.2 or 5.0 Lever [Re: moper] #1387116
02/13/13 11:28 PM
02/13/13 11:28 PM
Planet Earth
RoadRunnerLuva Offline
Planet Earth
Go with the 4.2
Plymouth Makes It!
Re: 4.2 or 5.0 Lever [Re: RoadRunnerLuva] #1387117
02/14/13 12:43 AM
02/14/13 12:43 AM
Toronto
mshred Offline
mshred  Offline
Toronto
haven't ran the trans yet, but I went with a 4.2 based off the recommendations from a lot of builders I talked with and guys on here as well.
Re: 4.2 or 5.0 Lever [Re: mshred] #1387118
02/14/13 12:49 AM
02/14/13 12:49 AM
ill
dennismopar73 Offline
ill
I run what the valve body guy says to run, or what he prescribe.
Cheat vb still recomend , the 5.0 , while other makers of trans brake do recomend the 4.2!
Re: 4.2 or 5.0 Lever [Re: dennismopar73] #1387119
02/14/13 01:27 AM
02/14/13 01:27 AM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
I run a cheeta TB vb in my cuda with a 5.0 and 277 first gear. Was doing that weighing in at 3800 lbs. 129/131 60 fts a hundred passes or more on it and when tore down for inspection over the winters, parts are still good. My trans was set up for me this way, I went by what was built for me. I can't recomend what's better to use, only a testimony on what I have been using is all.
