My Big Brakes - 14"x1.25" with viper calipers on all 4 #1387046
02/13/13 07:41 PM
02/13/13 07:41 PM
Houston Tx
Uhcoog1 Offline OP
Uhcoog1  Offline OP
Houston Tx
JCC asked me about my floater axle, and we got to talking brakes, and he suggested I post about my brakes.
Front:
Dr Diff kit - Gen III viper front calipers on SRT8 14.1x1.25" rotors. The rotors weigh about 27 pounds each (!), and the hubs are aluminum. The kit uses 73+ disc brake spindles and a caliper mounting bracket he makes. The brakes fit inside factory GT500 wheels (18x9.5 with 45mm offset). This wheel also fits around the tie rod end, which allows for the 7.2" of backspace. *With this combo, the tire hits the frame before lock on my duster.
Rear:
Schreiner Enterprises 9" floater using 5x4.5" hubs, Coleman 14x1.25" rotors, Gen III viper front calipers, and brackets I made. I went with a floater axle so I could run 4 piston calipers and not worry about pad knockback. The brackets consist of cut down GM Metric caliper brackets bolted to 1.25x1.25x8.5" aluminum stock. The caliper brackets run a full 360* around the axle - made for a much easier job!
Pads:
Cadillac CTS-V factory pads - they are branded "Brembo", and are a Ferodo HP1000 compound (same compound that probably all 'brembo' branded pads use, including the new Camaro, Viper, and high end exotics). The CTS-V pads are .300" taller than the viper pads, otherwise they are the same dimensions. They are the same size pad used on the Viper ACR-X, which uses these exact calipers. The pads fit height-wise on my rotors (just barely). They cost less than Viper brembo pads, though some aftermarket pads cost more in this size (vs viper size). I will probably have to stagger the pad compound to get the bias right, but I'll wait to fix it once I know I have a problem.
Master cylinder: 15/16" from Dr Diff. Manual. Should be about right, but if not, I'll change it out.
Wilwood proportioning valve - I'll probably need all 58% reduction in line pressure to get close to the right bias at threshold braking. With sticky tires, I'll end up with a more aggressive pad in the front.
The car isn't running, but I'll report back once it is, let ya'll know how this thing stops. The goal of the car is to run with a C6 Z06 and porsche GT3 on a road course.
Pics:
-'02 Dodge Viper Ex-World Challenge racecar
-'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
Re: My Big Brakes - 14"x1.25" with viper calipers on all 4 [Re: Uhcoog1] #1387047
02/13/13 08:03 PM
02/13/13 08:03 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Nice!!
any reason why you went with the same size caliper in the back instead of running the Gen 3 rear viper calipers, which are also a 4-piston design that looks like the fronts, but with smaller pistons.
I put gen 2 front brakes on all 4 corners on my Dakota, with 13" rotors (same bolt pattern as Viper) but I have factory RWAL that keeps me from locking up the rears. --and it works great despite the RWAL being designed for a disc/drum system.
**Photobucket sucks**
Re: My Big Brakes - 14"x1.25" with viper calipers on all 4 [Re: 70Cuda383] #1387048
02/13/13 08:41 PM
02/13/13 08:41 PM
Houston Tx
Uhcoog1 Offline OP
Uhcoog1  Offline OP
Houston Tx
I bought a set of 4, and they ended up being two sets of fronts. Not a huge difference in volume (4.3 sq/in vs 3.9 sq/in).
Re: My Big Brakes - 14"x1.25" with viper calipers on all 4 [Re: Uhcoog1] #1387049
02/13/13 08:45 PM
02/13/13 08:45 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Same brakes I have in the front.
Mopar to the bone!!!
Re: My Big Brakes - 14"x1.25" with viper calipers on all 4 [Re: Uhcoog1] #1387050
02/14/13 01:30 PM
02/14/13 01:30 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
How much room did you have on the spindles?
When I did my 8 piston calipers on the same diameter rotor it was a really tight fit. There was only one place I could mount the calipers and that spot allowed about 1/2" of wiggle room. The lower ball joint, upper control arm, and sway bar prevented stuffing it anywhere else.
I kept my TSM rear lower bracket adding spacers to bring them into position. The biggest difference being that I kept the 8-3/4" rear end.
- Stu Harmon
Re: My Big Brakes - 14"x1.25" with viper calipers on all 4 [Re: feets] #1387051
02/14/13 02:05 PM
02/14/13 02:05 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
Thanks for making me have brake envy.
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: My Big Brakes - 14"x1.25" with viper calipers on all 4 [Re: feets] #1387052
02/14/13 02:59 PM
02/14/13 02:59 PM
Houston Tx
Uhcoog1 Offline OP
Uhcoog1  Offline OP
Houston Tx
There's a good bit more room between the caliper and the spindle. I'm still amazed you got those 8 piston calipers to fit! Here's a couple pics for you:
Do you have any pad knock back with the 4 piston in the rears? How much endplay do you have?
For those of you who don't know, Alex is no stranger to big brakes. His current 6 piston project:
Re: My Big Brakes - 14"x1.25" with viper calipers on all 4 [Re: AlexP] #1387053
02/14/13 03:11 PM
02/14/13 03:11 PM
Woodinville, WA
Viol8r Offline
Viol8r  Offline
Woodinville, WA
We have built similar set-ups on other cars, and unfortunately with e 15/16" M/C and no help behind it, you will drive it the first time and most likely it will not stop! We learned our lesson a while back.... This type of set-up could need hydraboost and some other type of unique boosting system.
Let us know if it works out as-is.
1968 Pro-Touring Dodge Charger
*2011 Optima Ultimate Street Car Challenge Invitee
http://www.popularhotrodding.com/features/1203phr_1968_dodge_charger/index.html
Re: My Big Brakes - 14"x1.25" with viper calipers on all 4 [Re: Viol8r] #1387054
02/14/13 03:21 PM
02/14/13 03:21 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I use a manual 1-1/8" MC from a D150 and it works great. The pedal feels great. It's a bit lighter than the factory manual drums but not as soft as a typical power brake system.
My caliper volume is different than the Viper setup but it still demonstrates the ability to use a common manual MC on a big brake system.
When fitting my calipers, I mounted a rotor, wired it to prevent movement, and wedged a caliper in place using the brake pads and wood shims. Running the suspension through the full range of motion including steering angles put the caliper in it's place. I have about 1/4" of clearance to the upper control arm and about that much between the lower inner edge of the caliper and the ball joint arm.
I got lucky. Fitting those things had not even crossed my mind when I dropped the cash for them.
- Stu Harmon
Re: My Big Brakes - 14"x1.25" with viper calipers on all 4 [Re: Viol8r] #1387055
02/14/13 03:52 PM
02/14/13 03:52 PM
Houston Tx
Uhcoog1 Offline OP
Uhcoog1  Offline OP
Houston Tx
Have you had success keeping any of those cars with manual brakes, just with a larger master cylinder?
I don't imagine I'll need a booster, but I haven't ruled out a different size master cylinder. Something I haven't found a way to calculate is what is too small of a master cylinder. The formulas will tell you what is too big (i.e. you'll know when you don't have enough pressure), but nothing really indicates when it gets too small (and you don't have enough pad movement). Any thoughts on this?
Feets - your brake worksheet shows pad movement of .0056 with my application assuming 6:1 pedal ratio and 5" of pedal movement. The formula doesn't make sense to me, so doing it my way, I got .0334" per caliper of clamping movement with the above numbers.
Here are my numbers:
4.3 sq/in area per caliper (one side only, 44mm/40mm - all 4 are this)
0.69 sq/in - master cylinder volume given the above movement (15/16 mc)
= 25:1 total caliper to master cylinder area *This might be a good measurement to compare different brake set-ups for going too small of a master cylinder - might tell us when a M/C is too small*
*What I don't know is how much the pads retract when released, how much pad knockback occurs, and how much fluid compression occurs. That's what really matters in determining when you've gone with too small of a master cylinder, yes?
Feets- what size master do you have? What is the area of your front calipers and rear calipers? You are running manual brakes, yes?
Re: My Big Brakes - 14"x1.25" with viper calipers on all 4 [Re: Uhcoog1] #1387056
02/14/13 04:17 PM
02/14/13 04:17 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
My front calipers have two 28mm and two 32mm pistons per side. The total volume is less than you'd think.
The rears use 28mm and 30mm pistons. Again, fairly low volume.
The manual master has a 1-1/8" bore.
If you're getting more than .010" pad movement then something is wrong. Brake pads normally ride a couple thousandths of an inch off the rotor. Anything more will lead to a squishy pedal.
- Stu Harmon
Re: My Big Brakes - 14"x1.25" with viper calipers on all 4 [Re: feets] #1387057
02/14/13 04:56 PM
02/14/13 04:56 PM
Houston Tx
Uhcoog1 Offline OP
Uhcoog1  Offline OP
Houston Tx
Are you using square inches?
square inches = area
cubic inches = volume
If you're getting that much pad movement then something is wrong. Brake pads normally ride a couple thousandths of an inch off the rotor. Anything more will lead to a squishy pedal.
I just didn't understand your formula for brake pad movement in the spreadsheet that is here:
http://3gduster.com/brakes.html
Instead, I calculated the volume displaced by the master cylinder:
((.9375/2)^2)*3.1416*.8333 = .5752 ci (MC displacement)
and then calculated the movement of a single piston with that volume with an area of 17.2 (4.3 sq in per caliper * 4 calipers).
.5752 / 17.2168 = .0334" of movement
Note: I then checked the math in excel, calculating the volume of a cylinder for four 44mm cylinders and four 40mm cylinders:
((44/25.4/2)^2)*3.14*.0334 = .0787
((40/25.4/2)^2)*3.14*.0334 = .0651
BTW- your total piston area in the front is ~4.4 sq in.
**I'm not arguing the brake pads actually move this much. All of this is just an exercise in determining when you have too small of a master cylinder.
Re: My Big Brakes - 14"x1.25" with viper calipers on all 4 [Re: Uhcoog1] #1387058
02/14/13 05:26 PM
02/14/13 05:26 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
There's the hitch in your getalong. You should only look at one pair of calipers.
The master cylinder has a single bore but it is divided into two sections. One for the front and one for the rear.
In effect, it's a separate master for the front and another for the rear.
There's hitch number two. You do not use both side of a multipiston caliper. You only do one side.
The original 2.75" calipers on my Imperial (and several other cars) measure 5.9 sq inches.
To determine if the MC is too small, look at the pressure generated vs the pad movement.
High pressure at low movement = too small.
Low pressure at high movement = too large.
- Stu Harmon
Re: My Big Brakes - 14"x1.25" with viper calipers on all 4 [Re: feets] #1387059
02/14/13 05:45 PM
02/14/13 05:45 PM
Houston Tx
Uhcoog1 Offline OP
Uhcoog1  Offline OP
Houston Tx
Thanks for pointing out the MC error!
Any rule of thumb for the above rule?
Re: My Big Brakes - 14"x1.25" with viper calipers on all 4 [Re: Uhcoog1] #1387060
02/14/13 06:12 PM
02/14/13 06:12 PM
Houston Tx
Uhcoog1 Offline OP
Uhcoog1  Offline OP
Houston Tx
I found an interesting point of reference offered by Mark Williams:
http://www.markwilliams.com/braketech.aspx
Rule of thumb from their website:
9.6 sq in = 7/8 MC
14.4 sq in = 1" MC
19.2 sq in = 1 1/8 MC
Re: My Big Brakes - 14"x1.25" with viper calipers on all 4 [Re: Uhcoog1] #1387061
02/14/13 06:26 PM
02/14/13 06:26 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
From what Feets is describing I need a larger master than my 15/16". I need to push pretty damn hard on the pedal to get a hard stop.
Re: My Big Brakes - 14"x1.25" with viper calipers on all 4 [Re: Uhcoog1] #1387062
02/14/13 06:38 PM
02/14/13 06:38 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Rule of thumb?
Well, who's thumb are you using? My thumb is likely different than yours.
The feel is a personal thing.
As a general rule you want about 1000 psi of pressure at the caliper.
Now to put a wrench in things...
When you have a longer lever arm (read larger diameter rotor) you won't need quite as much pressure. It's like having a longer wrench. You don't need to pull as hard to get the same torque.
That means you can use a bit less pressure with larger diameter rotors. What doesn't change is pad movement.
To get an idea how far your pads move, run the numbers on your stock stuff. Try to work out similar pad movement at a reasonable pedal travel and pressure.
Clear as mud?
- Stu Harmon
Re: My Big Brakes - 14"x1.25" with viper calipers on all 4 [Re: 72Swinger] #1387063
02/14/13 06:44 PM
02/14/13 06:44 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
That generally means your MC is too big.
It works a little backwards.
Big MC + small calipers = hard pressure
Small MC + big calipers = low pressure
You have to fiddle with it a bit to get the numbers you want. That was one reason for the spreadsheet. It's easier to play with numbers than it is to swap parts.
- Stu Harmon
Re: My Big Brakes - 14"x1.25" with viper calipers on all 4 [Re: feets] #1387064
02/15/13 02:23 AM
02/15/13 02:23 AM
Washington State, USA
W
Winchester 73 Offline
W
i think the book was "driving to win by jackie stewart?"
research concluded that a driver could mentally modulate leg power better if it dident have movement in the equation so cars were setup with as solid a brake peddle as possible.a driver could "hit" the peddle with a more accurate amount of force without movement in the brain as well.
does this aply to our cars or gocarts on steroids where mechanicle advantage may not be nessesary i have no idea.i have however puty a big bore aluminum mas cyl on a 4 wheel drum 69 dodge truck,the peddle felt like it bent more than it moved it seemed like i could stop perfectly on a mark with it stopping.it was just an experiment, i changed it back before i sold it.
i wonder how much leg power factors into this,8 months ago i was leg pressing 1000 lbs.i had to stop leg training due to hitting my knee REALLY hard on the asphalt and after that all lifts felt really spooky.i kept waiting for it to go away but it wouldent.about three weeks ago i just said o well and started leg work again.after a couple leg workouts it feels fine but the presses have been kept under 800lbs.leg feels fine so ill be strong again in no time
Re: My Big Brakes - 14"x1.25" with viper calipers on all 4 [Re: Winchester 73] #1387065
02/15/13 10:56 AM
02/15/13 10:56 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Do whatever you want on your car but I'm not going to live with a solid brake pedal.
Pressing 300 lbs on your brake pedal to stop the car at every red light and stop sign would get old VERY quickly. Think about it. How many one leg 300 lb presses can you do? Now, how many times do you hit the brakes on your way to work? No matter how He Man you think you are I bet the brake pedal would still win.
It would also be hard on the seat frame and floor.
Some people forget that we drive these cars for pleasure.
- Stu Harmon
