want to get rid of throttle cable #1386772
02/13/13 03:01 AM
02/13/13 03:01 AM
superstreet1896 Offline OP
have had a stock cable set up from pedal to carb. want to change to a linkage set up. what is everyone using for a set up. btw stock firewall
Re: want to get rid of throttle cable [Re: superstreet1896] #1386773
02/13/13 03:16 AM
02/13/13 03:16 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Why? a cable is so easy to use.
Re: want to get rid of throttle cable [Re: rowin4] #1386774
02/13/13 11:10 AM
02/13/13 11:10 AM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
I'll try to get a few pics tonight, basically a long tube that pivots up around the steering column support, with a rod going straight to the carb, through the firewall.
Using in conjunction with a throttle stop? If so a rigid mounting, and pedal stop are of paramount importance.
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: want to get rid of throttle cable [Re: MoparBilly] #1386775
02/13/13 01:42 PM
02/13/13 01:42 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
2011 Drag Pak Challenger
Re: want to get rid of throttle cable [Re: rickseeman] #1386776
02/14/13 01:31 AM
02/14/13 01:31 AM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
no race car should ever use a cable. A solid rod with a toe clip on the pedal.
I have a S&W gas pedal in mine that bolts into the stock location and simple 1/4 rod ends. Speedway makes a nice rod thats annodized purple. $20.00
http://www.speedwaymotors.com/Aluminum-Accelerator-Linkage-Rod,1604.html
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: want to get rid of throttle cable [Re: bigtimeauto] #1386777
02/14/13 08:08 PM
02/14/13 08:08 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
When I went to a rod instead of the cable MY reaction times improved, there was less friction I guess. Mine was home made but I'm sure it can be bought.
