Rear End Fluid Advice.. #1386735
02/13/13 01:55 AM
02/13/13 01:55 AM
Closest Race Track
W
WH23H6 Offline OP
WH23H6  Offline OP
W
Closest Race Track
Hey Guys,
Quick question.... who is running "what" for rear end fluid?
I have a Nostalgia Super Stocker... 3200LBS... ford 9 inch....
Doing a fluid change...looks like 90/10 to me.. I know some guys are running synthetic fluid but Im not so sure I like it for rear gears! Seems to me that the gears would be better protected by a petroleum based product due to the heavy loads and shock factors... what do you guys think?
Thanks..
Re: Rear End Fluid Advice.. [Re: WH23H6] #1386736
02/13/13 03:04 PM
02/13/13 03:04 PM
Long Island, NY
Cudafied Offline
Cudafied  Offline
Long Island, NY
I use Redline Heavy ShockProof it has low viscosity until it is shocked then it goes to 75w250. I don't think I would get the 75-80 passes out of my street gears before they start to crack with regular gear oil.
Click here for Redline product info page
This is what 75 runs on street gears looked like with transbrake 6000 stall and a heavy car...
Re: Rear End Fluid Advice.. [Re: Cudafied] #1386737
02/13/13 09:01 PM
02/13/13 09:01 PM
ill
dennismopar73 Offline
ill
street i run 90-140, racin run 50 w oil
Re: Rear End Fluid Advice.. [Re: dennismopar73] #1386738
02/13/13 09:03 PM
02/13/13 09:03 PM
Q
Quicktree Offline
Quicktree  Offline
Q
I run all synthetic fluids
Re: Rear End Fluid Advice.. [Re: Quicktree] #1386739
02/13/13 10:22 PM
02/13/13 10:22 PM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
75-140W Synthetic. 4 years now and the gears look like new. Footbreak car, 10.00 @ 135 mph typical ET, 3500 lbs w/driver.
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
Re: Rear End Fluid Advice.. [Re: Quicktree] #1386740
02/13/13 10:57 PM
02/13/13 10:57 PM
Az
Crizila Offline
Crizila  Offline
Az
80/90 full synthetic in my diff.
Fastest 300
Re: Rear End Fluid Advice.. [Re: WH23H6] #1386741
02/14/13 12:24 AM
02/14/13 12:24 AM
Scheifers 250 WT, you must warm it up before each run when cool or cold outside All the new cars come with synthetics evrywhere they can run them, my 2006 Ram 3500 4wh.dr. calls for synthetic in both rear ends and the transfer case, I use the Redline brand synthetics gear oil in it
Re: Rear End Fluid Advice.. [Re: WH23H6] #1386742
02/14/13 03:01 AM
02/14/13 03:01 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Redline Shockproof here too.
Re: Rear End Fluid Advice.. [Re: WH23H6] #1386743
02/14/13 01:01 PM
02/14/13 01:01 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Been using Valvoline 75-90 syn. for years in my 8 3/4.........maybe that`s why it`s still alive..........
Re: Rear End Fluid Advice.. [Re: WH23H6] #1386744
02/14/13 01:48 PM
02/14/13 01:48 PM
Locomotion Offline
Locomotion  Offline
I've been using Amsoil Severe Gear 75w-90 in my differentials for years. My gear guy like it as well because it provides longer life for the gears as well as bearings!
They also have a 75w-110 and 75w-140
