Re: NEW ROLL BAR PICS! 70 Duster [Re: His and Her 69's] #1386537
02/15/13 08:54 AM
02/15/13 08:54 AM
PA
MrMopar95 Offline OP
Panhandler
Panhandler
PA
triangulation brother, its at its STRONGEST all tied in to the subframe connectors and to be legal for 8.50 cert. some day YOU MUST BE TIED INTO THE SUBFRAME CONNECTORS! The cage is setup for easy add ons in the future.
Nick Bowman
1970 Plymouth Duster -
"Footbrake" Red-or-Dead
2X Pittsburgh Raceway Park Points Champion
Re: NEW ROLL BAR PICS! 70 Duster [Re: MrMopar95] #1386538
02/15/13 09:00 AM
02/15/13 09:00 AM
ohio
all spooled up Offline
ohio
i like the way you did your down bars into the subframe connectors
Re: NEW ROLL BAR PICS! 70 Duster [Re: all spooled up] #1386539
02/15/13 09:26 AM
02/15/13 09:26 AM
PA
Panhandler
Panhandler
PA
THANK YOU!!!!
Nick Bowman
Re: NEW ROLL BAR PICS! 70 Duster [Re: MrMopar95] #1386540
02/15/13 09:29 AM
02/15/13 09:29 AM
tboomer Online work
tboomer  Online Work
Looks good,Nick!
Re: NEW ROLL BAR PICS! 70 Duster [Re: MrMopar95] #1386541
02/15/13 10:46 AM
02/15/13 10:46 AM
MR_P_BODY Offline
MR_P_BODY  Offline
This is true... BUT where you put the triangulated bar
is to a unsupported area.. it would have been must
stronger if you went to the bottom of the main hoop....
instead of the cross bar... I'm not telling you what
to do but what would have been stronger... but to
be honest I would have just run the down leg on the
steeper angle and landed on the frame connector...
stronger and less steel
