Page 1 of 9 1 2 3 4 5 6 7 8 9
QA1 Suspension R & D #1386348
02/12/13 09:26 PM
02/12/13 09:26 PM
Woodinville, WA
Viol8r Offline OP
Viol8r  Offline OP
Woodinville, WA
Wanted to give you guys s heads up that QA1 Suspension in conjunction with FM3 Marketing has contacted me to help finalize the research and delevopment phase of the front K-Member and associated components of this line of products.
I will be involved in documenting the build of the components and also attending events/ shows/ tracks. We do not have all the details yet as they have not released the product to me yet. But this will include tubluar upper control arms, lower control arms, shocks, K-Member, Sway-bar, etc.
I believe this could be an impressive and affordable option that a lot you guys have been looking for. Hopefully I can help work some kinks out, if there is any, and add this to the top of the list for a must have mod to your car.
http://www.qa1.net/qa1_motorsports/drag-...-k-members.html
http://www.qa1.net/qa1_motorsports/drag-...ntrol-arms.html
1968 Pro-Touring Dodge Charger
*2011 Optima Ultimate Street Car Challenge Invitee
http://www.popularhotrodding.com/features/1203phr_1968_dodge_charger/index.html
Re: QA1 Suspension R & D [Re: Viol8r] #1386349
02/12/13 09:48 PM
02/12/13 09:48 PM
Manitoba Canada
67autocross Offline
67autocross  Offline
Manitoba Canada
Does it use factory torsion bars or it set up for coil overs?
A new iron curtain drawn across the 49th parallel
Re: QA1 Suspension R & D [Re: 67autocross] #1386350
02/12/13 10:23 PM
02/12/13 10:23 PM
On The Boat, On The Lake, Wa. ...
amxautox Online content
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Online Content
2nd picture in the 2nd link shows the lowers to be torsion bar sockets.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: QA1 Suspension R & D [Re: amxautox] #1386351
02/12/13 11:49 PM
02/12/13 11:49 PM
Chicago, Illinois
Devil Offline
Devil  Offline
Chicago, Illinois
I'd love to take this stuff, combine it with the Hotchkis setup and go have some fun.
That is my pie in the sky dream for my 71 Challenger.
Ryan
Re: QA1 Suspension R & D [Re: Devil] #1386352
02/13/13 12:36 AM
02/13/13 12:36 AM
Woodinville, WA
Viol8r Offline OP
Viol8r  Offline OP
Woodinville, WA
I do not think running a combo of makes is a bad thing, as long as you have a goal and purpose for the car in mind. This QA1 combination should provide some serious competition for Hotchkis and a bit of a cost savings.
There are so many variables to each build, but having a one stop shop for the majority of the suspension parts will be a bonus.
Re: QA1 Suspension R & D [Re: amxautox] #1386353
02/13/13 01:14 AM
02/13/13 01:14 AM
Manitoba Canada
67autocross Offline
67autocross  Offline
Manitoba Canada
Found them! Someone was selling ones like them for drag racing a while back.
I would like to see if that stuff is any lighter than the stock k-member, lower and upper control arms. I would guess that the weight reduction would be the main advantage.
Re: QA1 Suspension R & D [Re: 67autocross] #1386354
02/13/13 01:21 AM
02/13/13 01:21 AM
Woodinville, WA
Viol8r Offline OP
Viol8r  Offline OP
Woodinville, WA
I would like to see if that stuff is any lighter than the stock k-member, lower and upper control arms. I would guduhess that the weight reduction would be the main advantage.
Many advantages over stock. Weight being they first, rigidity second, adjustability third
Re: QA1 Suspension R & D [Re: Viol8r] #1386355
02/13/13 01:29 AM
02/13/13 01:29 AM
Manitoba Canada
67autocross Offline
67autocross  Offline
Manitoba Canada
Keep us posted as you install and test the parts, have you started putting them on the car yet?
Re: QA1 Suspension R & D [Re: 67autocross] #1386356
02/13/13 01:45 AM
02/13/13 01:45 AM
Woodinville, WA
Viol8r Offline OP
Viol8r  Offline OP
Woodinville, WA
No sir. The deal should be finalized in the next few weeks. I will keep you guys posted and list all the vitals once I can put my greasy little fingers on the parts! Should be interesting....
We were the fastest Mopar on the road course at the OUSCI a few years back. So I am hoping for even better results! I had a melting pot of parts on the car at that time so it will be nice to call one place home.......
Re: QA1 Suspension R & D [Re: Viol8r] #1386357
02/13/13 11:19 PM
02/13/13 11:19 PM
NY NY
3
340duster340 Offline
NY NY
the tubular lcas look like a knock off of a set a guy on fabo made a while back.
Re: QA1 Suspension R & D [Re: 340duster340] #1386358
02/14/13 12:44 AM
02/14/13 12:44 AM
Woodinville, WA
Viol8r Offline OP
Viol8r  Offline OP
Woodinville, WA
Knock off or not, this will be a little different situation with a corporation backing the development. I think the tubular lower has been begging for some new ideas....lets see how it looks.
Re: QA1 Suspension R & D [Re: Viol8r] #1386359
02/15/13 02:50 AM
02/15/13 02:50 AM
Washington State, USA
W
Winchester 73 Offline
W
taking requests?
id like to see a sans motor mount version thats a touch cheeper for engine plate cars,and sphericle strut rod connections.i think both would help sales with drag racers especially strut rod connection.
Re: QA1 Suspension R & D [Re: Winchester 73] #1386360
02/15/13 03:21 AM
02/15/13 03:21 AM
Woodinville, WA
Viol8r Offline OP
Viol8r  Offline OP
Woodinville, WA
taking requests?
This is a fair point. I believe there answer would be that there K-Member can handle a solid motor mount situation minus the Plate. I think this was most likely developed with a pro-street/ drag racing mentality as it only excepts E-body and 70+ B-body sway bars. They are only 1 1/4", and that is not going to work for me. We are already going to have to talk about how to remedy this.
When I have my initial technical sitdown with QA1, I will raise this point regarding full drag set-ups with plates and see if they are even considering this. As far as the Strut arm is concerned there are several options out there that are much more aggressive then stock. Firm Feel, Hotchkis, etc. Thanks for the input.
Re: QA1 Suspension R & D [Re: Viol8r] #1386361
02/25/13 12:13 PM
02/25/13 12:13 PM
sandwich IL
sublimehemi Offline
sublimehemi  Offline
sandwich IL
well i talked to qa1 at drag expo and they said they lowered the retail price to 700 dollars...
70 charger ,all aluminum 528 hemi 727 cope rmvb,680hp 670 tq,full sequential holley hp efi,full hotchkis tvs,qa1 k and lowers,borgeson steering box cass viper 11.75 with cass s-trac dana 3.54
Re: QA1 Suspension R & D [Re: sublimehemi] #1386362
02/27/13 08:23 AM
02/27/13 08:23 AM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
I am just a dummy on here so please explain how this is better than a welded/reinforced K frame?
Have you tested it's "flex" against a stock and welded reinforced K frame? How did you test it? Show us some results.
The K frame is a very integral part of a cars ability to resist flex.
Lighter does not necessarily mean better.
It's not about the money, it's about improving the cars.
Is this a real improvement?
Weight saving to induce more flex is not an option.
What are the weight differences?
Since we don't know each other I thought I should share with you the car I built in the pic. Yes it has a welded/reinforced K frame and more but no roll cage. It eats SRT8 Challengers on the road course with ease.
So tell me how this new idea will improve lap times?
Re: QA1 Suspension R & D [Re: ThermoQuad] #1386363
02/27/13 09:36 AM
02/27/13 09:36 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Marty I hope this turns into a good deal. QA1 seems to be a pretty sharp company that puts quality ahead of profit. Their shocks and rod ends are good stuff.
Mopar to the bone!!!
Re: QA1 Suspension R & D [Re: ThermoQuad] #1386364
02/27/13 12:51 PM
02/27/13 12:51 PM
Woodinville, WA
Viol8r Offline OP
Viol8r  Offline OP
Woodinville, WA
Tom- Let me start by saying I have not sat down with QA1 yet to stragetize the final development on this product, nor do I have the unit in front of me. So I am not going to guess on technical information that I just don't have.
I run a fairly quick car myself and have 0 welding done to the K-member so I am quite excited to see what it has to offer over the R & R of a 50 year old unit.
The flex numbers will have to be something that I can test once the old and new are sitting next to each other. How do I test this?....I don't know, how did you test your welded K-member? Science or seat of the pants??
The unit is designed to except Rack and Pinion, tubular lower and upper CA's, so obviously there won't be many similarities between the two but, I agree, the overall strength is an important part of the car. Let's also remember not everyone is out here to race their car, but to be allowed to use some more modern technology on the car to make it drive better in non-performance situations. This unit may take care of both situations, we will see.
There are still a lot of questions I need answered myself, so once I get to that point with QA1, I will share what I know.
Re: QA1 Suspension R & D [Re: 72Swinger] #1386365
02/27/13 12:55 PM
02/27/13 12:55 PM
Woodinville, WA
Viol8r Offline OP
Viol8r  Offline OP
Woodinville, WA
I agree with this. I believe we have to at least give them a shot at it. If we just assume all companies can't figure this out then our kids will still be welding k-members for there cars in 20 years.....I for one appreciate any company that goes out on limb to develop Mopar parts, its not easy wall to break through.....i.e. see earlier posts.
Re: QA1 Suspension R & D [Re: Viol8r] #1386366
02/27/13 01:18 PM
02/27/13 01:18 PM
Manitoba Canada
67autocross Offline
67autocross  Offline
Manitoba Canada
So it will be tube k member with rack steering with torsion bars? That could be a nice set up, do you have a time line as to when you will be starting on this?
Re: QA1 Suspension R & D [Re: 67autocross] #1386367
02/27/13 01:24 PM
02/27/13 01:24 PM
Woodinville, WA
Viol8r Offline OP
Viol8r  Offline OP
Woodinville, WA
Yes that is correct. Rack and pinion with Tubular structure and torsion bars. I was a bit surprised by the torsion bars still in the design, but with a good shock and the right balance, sky is the limit.
I received notification a few weeks ago that they finalizing the contract. I suspect we should hear something this week.
