Educate me on drag shocks. #1386183
02/12/13 04:24 PM
02/12/13 04:24 PM
PEI Canada
chromedome426 Offline OP
PEI Canada
Have a friend with a 68 B-body looking for advice on drag shocks.
His car can hook well on a perfect track, but most times it will hook and then let go.
His car is a 1968 Road Runner, 3400lbs, 500cid, CalTracs, Split Mono-leaf, Rancho 9 way adjustable rear shocks, Calvert 90/10 front shocks, 29x10 Hoosier slicks, 4:10 gears, .880 Dia(slant six)torsion bars, tubular upper control arms w/rod ends, and greasable lower control arm pins w/urethane bushings.
He just ordered a pair of the Firm Feel .820 Dia (drag race) torsion bars.
He is wanting to here some opinions about changing over to the AFCO racing shocks.
Thanks.
Re: Educate me on drag shocks. [Re: chromedome426] #1386184
02/12/13 04:31 PM
02/12/13 04:31 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Afco are a better shock but he needs to make sure he
has good front end travel... if he takes a video of
the launch he can get a better idea of what is really
happening... I'm thinking he is running out of front
end travel and as soon as it tops out it falls back
down to cause the spin... also when its on a lesser
hooking track he needs to loosen up the rear shocks
for more lift
Re: Educate me on drag shocks. [Re: chromedome426] #1386185
02/12/13 04:34 PM
02/12/13 04:34 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Boy he's already into it for a bunch of money. I take it he's adjusted the Cal-Tracs a few different ways? What are his 60 foots? Hook and let go? like at the 1-2 shift? Only cars I've seen start blowing the tires apart at the 100 foot are turbo cars when the boost comes on hard.
Coming soon!!!!
Re: Educate me on drag shocks. [Re: Mr.Yuck] #1386186
02/12/13 05:31 PM
02/12/13 05:31 PM
PEI Canada
PEI Canada
He has 5.25 inches of travel on the front suspension. The 60' times are in the 1.43 - 1.50 area. He did have a 1.41 once.
When the track is perfect he can get 12 inches of air under the front tires and it will stay hooked even when the front comes back down. When the track is marginal he can only get 2 inches of air under the front tires. He does loosen the shocks for those conditions but feels that the rear shocks may need to be double adjustable. He is also wondering if the double adjustable front shocks would help?
Here is a picture of the car in storage. Sorry for the poor quality pic, it's the best I have of it on this computer.
Re: Educate me on drag shocks. [Re: chromedome426] #1386187
02/12/13 05:47 PM
02/12/13 05:47 PM
MR_P_BODY Offline
MR_P_BODY  Offline
At 5.25 travel he has plenty... myself I only use a
single adjustable shock...I've always felt the compression
(on a double adjustable) was for down track... the extension
was for the starting line
Re: Educate me on drag shocks. [Re: MR_P_BODY] #1386188
02/12/13 09:54 PM
02/12/13 09:54 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Seems to me that he's got all the right stuff there. I'm sure there's guys out there going fast and hooking hard with LOTS less than he has. Something else has to be at issue here. I'd be hesitant to just throw more money at it. What sort of performance levels are we talking about, here?
As said, Video will be needed before anyone here can really offer any good help.
Re: Educate me on drag shocks. [Re: MR_P_BODY] #1386189
02/12/13 10:17 PM
02/12/13 10:17 PM
Ont. Canada
10.90 Racer Offline
super street
10.90 Racer  Offline
super street
Ont. Canada
for more lift
What setting are the rear shocks on???
Re: Educate me on drag shocks. [Re: 10.90 Racer] #1386190
02/12/13 11:28 PM
02/12/13 11:28 PM
MR_P_BODY Offline
MR_P_BODY  Offline
for more lift
I dont now why your asking me... its not my car
Re: Educate me on drag shocks. [Re: MR_P_BODY] #1386191
02/13/13 12:17 AM
02/13/13 12:17 AM
IN
Irun5snd8th Offline
Irun5snd8th  Offline
IN
Mopars have a super short leaf spring compared to the Chevys. The hit and unload, often called porpoising, is common to the Mopars for this reason. Lil bro's car was awesome till we put the stroker in it and then it started the same deal as your friend. The answer was a good pair of double adjustable shocks along with a pinion angle change. Check the angle first cause thats cheaper than a set of shocks. You should have at least 5 degrees on a leaf spring car and it is absolutely critical on a leaf car.
AFCO, Rons Fuel Injection sponsored Dodge Challenger Mention Street Lethal Motorsports
Re: Educate me on drag shocks. [Re: Irun5snd8th] #1386192
02/13/13 12:33 AM
02/13/13 12:33 AM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
CalTracs want 1-3 neg degrees of pinion angle relative to the trans. Its hard to answer any questions you may have without knowing the cars set up. Like how much preload,what rear shocks are set at,what size tire and air pressure,top or bottom hole, how much converter,. Most of the average 10.30-10.60 et car would usually 60 in the 1.40-1.49. Some well sorted out will go much better. He has allot of good parts there so it is got to be just the set up or combo and not to throw more parts at it. We have stock front end with dbl adjustable afco's and we 60 1.28-1.32. So he allready has more then us. So there is some work to be done.Jake
JAKES AUTOMOTIVE
Re: Educate me on drag shocks. [Re: JAKE68] #1386193
02/13/13 05:06 AM
02/13/13 05:06 AM
sweden
sshemi Offline
sshemi  Offline
sweden
Instructions for caltracs says 4* piniong angle
Re: Educate me on drag shocks. [Re: chromedome426] #1386194
02/13/13 09:51 AM
02/13/13 09:51 AM
maryland
74yellowduster Offline
maryland
this sounds like "when the track isn't perfect" his slicks don't hook.
it sounds like when they hook it works perfectly.
how much air is he running in them, how old are they, is he heating them up enough, can he go wider, etc.
it sounds like he has the suspension right, but he's spinning for some reason
Re: Educate me on drag shocks. [Re: chromedome426] #1386195
02/13/13 10:15 AM
02/13/13 10:15 AM
an8sec70cuda Online content
an8sec70cuda  Online Content
Try different front shocks, you might be surprised.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Educate me on drag shocks. [Re: sshemi] #1386196
02/13/13 02:44 PM
02/13/13 02:44 PM
PEI Canada
PEI Canada
Unfortunately we don't have any video of the car. However, he will definately get some, once the 3 feet of snow melts off the track.
He sent me a few pictures that may or may not help for now.
He has tried every setting on the shocks multiple times. He has set the bars in both the upper and lower holes. He has also played with preload to no preload on the bars. Slicks are 29x10 on 10" wheels and has 14 psi hot.
The comment about pinion angle turned on a light bulb for him. That is something that he hasn't changed. I believe it's only at 2 or 3 degrees down.
The car has run 10.25 at 132 mph in good air but mostly in the heat of summer it's 10.40's at 129 mph.
Re: Educate me on drag shocks. [Re: chromedome426] #1386197
02/13/13 02:46 PM
02/13/13 02:46 PM
PEI Canada
PEI Canada
Picture from front view:
Re: Educate me on drag shocks. [Re: chromedome426] #1386198
02/13/13 02:50 PM
02/13/13 02:50 PM
PEI Canada
PEI Canada
Stance at 1/2 track:
Re: Educate me on drag shocks. [Re: chromedome426] #1386199
02/13/13 03:03 PM
02/13/13 03:03 PM
PEI Canada
PEI Canada
He said it's like the car is hitting the tires too hard and then unloading them when the body starts to come back down.
He wonders if the double adjustable rear shocks would slow the body from coming down too fast and help keep the tire planted longer?
He is also wondering what to use for front shocks?
Re: Educate me on drag shocks. [Re: chromedome426] #1386200
02/13/13 03:13 PM
02/13/13 03:13 PM
Preferably an adjustable front shock, but anything tighter than the Calvert's will be better. I use some old Lakewood 90/10s that are a lot stiffer than the Calverts which are REALLY loose. Sounds exactly like what my car did after I put on the Calvert 90/10 front shocks. I got it to hook once on a very well prepped track and "treated" tires...it almost went on the back bumper. The very next pass it started to unload again. Put my old front shocks back on and it went right back to hooking like always. The front rises too fast, bottoms out, and unloads the rear.
I put on new rear shocks, new tires, and every possible bar adjustment trying to fix it...didn't respond to anything. I never thought those Calvert shocks would be the problem b/c everyone says they're great, but I found out the hard way.
CHIP
Re: Educate me on drag shocks. [Re: chromedome426] #1386201
02/13/13 03:23 PM
02/13/13 03:23 PM
maryland
maryland
i cant tell too well from the pictures, but it doesnt look like he can go wider. is he 50/50 front to rear on weight?
he might be able to go with a softer compound?
HOOSIER CHART
MICKEY THOMPSON COMPOUND SELECTION CHART
Medium----------------------------------------------------------Soft
M7 X5 M5 M8 R1 L8 X7 L4
Re: Educate me on drag shocks. [Re: chromedome426] #1386202
02/13/13 04:32 PM
02/13/13 04:32 PM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
Looking at this shot it looks like rear shocks are way to loose. 9 way rancho likes to be at #8 With bar in lower hole. Now on my brothers car we have a problem with it hooking and then nose diving becuase when it hooks it pulls the motor down below power band we are going to put more converter in it. It has a very high power band and a 5500 converter is not enough. based on dyno sheets we will be puting in a converter that will flash from 6800-7100. and go from there.
JAKES AUTOMOTIVE
