Re: late model hemi swap is it worth it ?
[Re: NoFrills]
#1385921
02/11/13 11:52 PM
02/11/13 11:52 PM
moparpollack
Lil Herman
Lil Herman
85086
I am thinking about swapping a 5.7 hemi into my 67 belvedere station wagon. I was wondering if people that have swapped them into older stuff think it was worth it in the end. My car is a running driving 440 auto. I like taking it for rides with my kids but it gets terrible mpg and don't really make that much power. I would want to leave the hemi injected and would put a 518 behind it.
It's a big investment to save gas money. At the end of the day it's still 375 hp for a newer hemi. Case in point where do you drive and how far. On the highway my friends 512 charger got 17mpg on the highway with 3:55 gears 28" tires. In town not so much. My new challenger does 70mph at 1500 ish rpm. It's boring as all get out putting down the highway like this.
My main grpe about putting a newer engine in an old car is what happens if you break down? Most parts are custom like the spark controller or any sensor. How do you diagnose this and get back on the road? With old school technology most can get it going with basic hand tools.
My buddy drove older cars cross country with points because he knew he could fix them in twenty minutes. Only basic hand tools were all he took. ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: ahy]
#1385924
02/12/13 01:02 AM
02/12/13 01:02 AM
Posts: 1,130 Dayton, Ohio
wldtm
Dayton, Ohio
Mine gets 25 MPG at 70 mph with 3.91 and 28 tall tire in an A body. Yes, it has a .64 overdrive in the 5 speed.
Is is quick as h*ll, no. Can I drive it anywhere, yes. I built it for that reason.
Reliability is great, because as mentioned earlier, it has factory efi and the DLC connector. go to any dealership or autozone and get the codes and trouble shoot from their
I love it, but would probably get beat in several street races.
All up to the end goal of your vehicle.
JM
Interested in having you car wired? Drag car, street car, EFI swap?
PM for details
[Re: wldtm]
#1385925
02/12/13 06:30 AM
02/12/13 06:30 AM
Posts: 685 Bismarck, ND USA
cageman
Bismarck, ND USA
I would just use the 545 that the hemi came with, thats what I did, easy (either way you have to do floor pan mods). Has a speed signal an auto meter speedo can read, and a tach signal an auto meter tach can also read. I used an 03. If I was to do it over, I would have dumped the 03 computer, which has two, one for the engine and one for the trans for an 05 computer, and put a 500 hp tune on it and away I go. With an 05 you need an adapter for the tach and speedo, but they make em. I guess With the tti's it is supposedly 400 hp, but you touch the key it is running and it idles great and will run for 200,000 miles. Try that with a carb engine, ha ha, yeah right. I can hook the scanner up to it and see what is going on, that too is nice. I used a hotwire wire harness, Chris was very helpful, will use him again. Right now Im finishing up the stainless fuel tank I made, it is turning out sweet, I used the rams fuel pump, so it was designed for this engine.
[Re: NoFrills]
#1385927
02/12/13 10:52 PM
02/12/13 10:52 PM
cageman
Bismarck, ND USA
I have a thousand into the wiring, I used the stock fuel pump, made my own stainless tank, all the fittings and what not, I'll have 5 grand into it easy. But I also rewired the whole car, new aluminum radiator, put the ac delete pulley on it, made my own driveshaft, All new auto meter guages and all the little stuff. But it starts with a simple turn of the key and it idles perfectly. Cant beat the oem engineeering. All the hotwire wires clip right together, it took me ten minutes to wire that part. Todays gas and carbs dont mix. Fuel injection is the only option it seems.
[Re: NoFrills]
#1385928
02/13/13 02:38 AM
02/13/13 02:38 AM
DaytonaTurbo
Manitoba, Canada
I can get a good deal on a new 5.7 truck motor and a frend has a fast xfi that he never used that I can get for cheep. Really I would like to put a t56 in in but I have a fresh non lock up 518 laying around. The 440 is ok was suposed to be fresh when I got it. If never really impressed me stock cam 915 heads. It will detinate with out 93 octane gas and im lucky if it gets 10 mpg even on the high way. I think it will end up costing me around 4500 to do the swap with me doing the labor. I also realize 4500 will buy alot of gas for the 440.
Something is big time wrong with your 440 if a "fresh" 440 with a stock cam is only getting 10mpg. With a fresh 440 with decent compression pistons and a stock cam and 727 with some granny highway gears in the rear you should be knocking down mid-upper teens even in a station wagon that's no doubt heavier than a regular b body. Did you take the time to jet your carb properly and tune your distributor advance (initial, total and vacuum)?
[Re: DaytonaTurbo]
#1385929
02/13/13 02:46 AM
02/13/13 02:46 AM
Posts: 11,632 SHELBY TWP,,MICHIGAN
72N96RR
I LOVE WEDGIES
I LOVE WEDGIES
The last two issues of Mopar Action magazine has gone into great detail about putting a 6.1 HEMI in old school muscle..They are now convinced after dynoing a solid 750 hp motor that produced 600FT lbs of torque,, that this motor is the end all best hemi setup (OLD OR NEW) available today as far as a pump gas motor with little to no maintenance.. ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
1972 Road Runner / GTX 440 4spd Dana 3.54 Just about to turn 26K original miles..
A boat, a GMC truck, some Craftsman Tools, LOTS of Zombie Protection, and a few Goldfish..
If you love someone set them free.. If they come back it means nobody else wanted them either..!!
[Re: a12rag]
#1385934
02/13/13 09:32 PM
02/13/13 09:32 PM
Posts: 8,779 Mt.Gilead, Ohio
OhioMopar
Mt.Gilead, Ohio
Inject the 440 and put that 518 behind it. Would be less work and expense, wouldn't it? Will the XFI system you can get cheap be made to work for the 440?
1969 Dart GTS 340 1969 Super Bee X9 N-96 1969 Coronet R/T X9 N-96 2015 Dodge Dart GT 2019 Ram 2500 Big Horn. Looking for the original block for my Bee. The last 4 are 7449
[Re: cageman]
#1385937
02/14/13 01:16 AM
02/14/13 01:16 AM
moparpollack
Lil Herman
Lil Herman
85086
Any pictures?
[Re: moparpollack]
#1385938
02/14/13 10:22 AM
02/14/13 10:22 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
considering my 4200 lb 2011 charger R/T is a ~13.7 second ride in the quarter mile with the A580 auto and 2.65 rear gears, I'd love to take a bone stock 2009-up 5.7 eagle motor and put it in my duster with it's current gearing of an A833OD and 3.23's....would easily be a 12 second car, that on the highway would get about 27-28mpg....
