wifes 69 coronet #1385805
02/11/13 08:12 PM
02/11/13 08:12 PM
usa
Mcat Offline OP
Mcat  Offline OP
usa
at idle lites dim gauge shows discharge a little gas and boom everything comes back replaced voltage regulator /alternator still the same any ideas thank's
Re: wifes 69 coronet [Re: Mcat] #1385806
02/11/13 08:42 PM
02/11/13 08:42 PM
GMP440 Offline
GMP440  Offline
Very commenon with these electrical systems. Do you know what the amperage rating is for your alternator? I used a 65 amp alternator with the correct round back on my 68' Coronet. Big difference, virtually no dimming of the lights. The alternator I used was one from a 72' Chrysler Neuport. That year Neuport used the round back alternator which is correct for your 69' Coronet. You'll love the improvement.
Re: wifes 69 coronet [Re: GMP440] #1385807
02/11/13 08:57 PM
02/11/13 08:57 PM
usa
Mcat Offline OP
Mcat  Offline OP
usa
not sure what amps on the alternator got it at carquest for 69 coronet
Re: wifes 69 coronet [Re: Mcat] #1385808
02/11/13 09:02 PM
02/11/13 09:02 PM
usa
Mcat Offline OP
Mcat  Offline OP
usa
what is the stock amp rating want to straighten this out because i'm going to convert it over to electronic ignition
Re: wifes 69 coronet [Re: Mcat] #1385809
02/11/13 09:17 PM
02/11/13 09:17 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
That is how they were originally , turn up the idle to about 1200 and it should stop it , but you don't want to run the idle that high .
Re: wifes 69 coronet [Re: Mcat] #1385810
02/11/13 09:20 PM
02/11/13 09:20 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
What about doing the mad electric change over? Eliminate the factory connector terminal and wire it solid.
Re: wifes 69 coronet [Re: moparpollack] #1385811
02/11/13 11:44 PM
02/11/13 11:44 PM
morrisville, pa
skajm Offline
skajm  Offline
morrisville, pa
Please do the headlight/relay set up. And the amp gauge by pass. And add more grounds from engine to firewall to volt reg to frame. More grounds the better. I did these to my car I wish I know about this repair in the 80's. it made a big difference
Joe
Re: wifes 69 coronet [Re: GMP440] #1385812
02/12/13 03:47 AM
02/12/13 03:47 AM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
Does that have the dual field connections on the back or single? Just curious.
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: wifes 69 coronet [Re: OhioMopar] #1385813
02/12/13 11:03 AM
02/12/13 11:03 AM
Dual & if purchasing one I'd go ahead & get the 78 amp one from an 85 M body & as you know just ground one field terminal if using an earlier type reg
Re: wifes 69 coronet [Re: RapidRobert] #1385814
02/12/13 11:16 AM
02/12/13 11:16 AM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
Thanks! I was planning on using the updated engine harness for the electronic ignition. That's why I was curious. Awesome!
Re: wifes 69 coronet [Re: OhioMopar] #1385815
02/12/13 11:36 AM
02/12/13 11:36 AM
If the updated harness has the triangle plug for the flat reg (& I would think that it would) & this is going into an earlier car that had a box reg FYI you can trim the sides & redrill 1 mounting hole on a flat 70 up reg & it will nestle neatly into the firewall recess where the box reg once resided. That way you wouldn't have to cut the harness if it's setup for the flat reg.
Re: wifes 69 coronet [Re: RapidRobert] #1385816
02/12/13 12:09 PM
02/12/13 12:09 PM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
It does. It has the dual field terminals, the '70 and up style regulator, and the electronic ignition harness built in. Going in a '69 Bee.
1969 Dart GTS 340
2015 Dodge Dart GT
Re: wifes 69 coronet [Re: OhioMopar] #1385817
02/12/13 01:33 PM
02/12/13 01:33 PM
JohnRR Offline
JohnRR  Offline
I think I have that same harness that I was going to put in my Bee ...
Re: wifes 69 coronet [Re: JohnRR] #1385818
02/12/13 01:48 PM
02/12/13 01:48 PM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
I put one in my R/T. It was kind of nice. The parts were usually in stock(newer voltage regulator, better selection of alternators). I was going to try to 'hide' the electronic box under the battery tray. But then I figured it had the wrong alternator and voltage regulator on it, so why bother?
Re: wifes 69 coronet [Re: OhioMopar] #1385819
02/13/13 04:47 PM
02/13/13 04:47 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
OP should clean all connections, check ground for VR. Would be wise to swap in YO harness if going to electronic ignition. Maybe run dedicated ground to ECU and VR.
I want my fair share
Re: wifes 69 coronet [Re: SomeCarGuy] #1385820
02/13/13 05:07 PM
02/13/13 05:07 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Sounds to me that the belt is loose.
