Page 8 of 17 1 2 6 7 8 9 10 16 17
Re: 1968 GTS 383 [Re: dart4forte] #1384867
11/16/13 09:06 PM
11/16/13 09:06 PM
Mesa, Arizona
dart4forte Offline OP
Mesa, Arizona
Last roof pic
Re: 1968 GTS 383 [Re: dart4forte] #1384868
11/16/13 09:08 PM
11/16/13 09:08 PM
Mesa, Arizona
Mesa, Arizona
And it looks like a I need another heaterbox
Re: 1968 GTS 383 [Re: dart4forte] #1384869
11/16/13 09:09 PM
11/16/13 09:09 PM
Mesa, Arizona
Mesa, Arizona
Another pic of the damaged heaterbox
Re: 1968 GTS 383 [Re: dart4forte] #1384870
01/11/14 02:13 AM
01/11/14 02:13 AM
Mesa, Arizona
Mesa, Arizona
Back on schedule. more sheet metal replacement. Replacing the fenders is also on the list. As soon as the metal work is done it goes in line for final prep and paint
Re: 1968 GTS 383 [Re: dart4forte] #1384871
01/11/14 02:16 AM
01/11/14 02:16 AM
Mesa, Arizona
Mesa, Arizona
The guys pulled the rear end the other day so we can get the car on the rotisserie. I'll be pulling it apart for cleaning, disassembly, painting and re-assembly. I need to pull the pig and check out the ring and pinion
Re: 1968 GTS 383 [Re: dart4forte] #1384872
01/11/14 02:18 AM
01/11/14 02:18 AM
Mesa, Arizona
Mesa, Arizona
Stopped by Jim's yesterday to check on the motor. The short block is almost finished aside from degreeing the cam. looks like the motor will be pulling around a 9.2 CR.
Re: 1968 GTS 383 [Re: dart4forte] #1384873
01/11/14 02:19 AM
01/11/14 02:19 AM
Mesa, Arizona
Mesa, Arizona
.040 over. Pistons are below the deck approximately .020. these are a little shorter than the forges .303 over we took out.
Re: 1968 GTS 383 [Re: dart4forte] #1384874
01/11/14 02:21 AM
01/11/14 02:21 AM
Mesa, Arizona
Mesa, Arizona
and prepping to degree the cam. ooops, forgot to install the cam.
Re: 1968 GTS 383 [Re: dart4forte] #1384875
01/14/14 01:10 AM
01/14/14 01:10 AM
Mesa, Arizona
Mesa, Arizona
More progress on the GTS
Re: 1968 GTS 383 [Re: dart4forte] #1384876
01/14/14 01:12 AM
01/14/14 01:12 AM
Mesa, Arizona
Mesa, Arizona
New DS fender. Need to weld up the holes
Re: 1968 GTS 383 [Re: dart4forte] #1384877
01/14/14 01:15 AM
01/14/14 01:15 AM
Mesa, Arizona
Mesa, Arizona
This the passenger side fender. both were in good shape. Just need to weld up the holes
Re: 1968 GTS 383 [Re: dart4forte] #1384878
01/14/14 01:17 AM
01/14/14 01:17 AM
Mesa, Arizona
Mesa, Arizona
Under hood all cleaned up. Need to weld up those hood pin holes
Re: 1968 GTS 383 [Re: dart4forte] #1384879
01/14/14 01:47 AM
01/14/14 01:47 AM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Were the shock bolts broken or was there rust in the trunk panel you replaced?
Re: 1968 GTS 383 [Re: moparpollack] #1384880
01/14/14 03:46 PM
01/14/14 03:46 PM
Mesa, Arizona
Mesa, Arizona
There was rot along the seam of the panel. It's a separte panel from the trunk floor. now it has a better panel with all of the stock plug welds.
Re: 1968 GTS 383 [Re: dart4forte] #1384881
01/15/14 06:18 PM
01/15/14 06:18 PM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
Last one. Special thanks to FABO member Hotrod340 of the Amarillo Mopar club for digging these up
That looks mean with the Keystones on it!
Re: 1968 GTS 383 [Re: Dave Watt] #1384882
01/16/14 02:16 AM
01/16/14 02:16 AM
Mesa, Arizona
Mesa, Arizona
I'd like to go with the Keystones however the choices of tires in 14" are pretty low. I have a set of 15" Torque Thrusts in small bot patteren that I will be running on this car.
Re: 1968 GTS 383 [Re: dart4forte] #1384883
01/18/14 05:10 AM
01/18/14 05:10 AM
Mesa, Arizona
Mesa, Arizona
Got the motor finished. My guy does premo work.
Re: 1968 GTS 383 [Re: dart4forte] #1384884
01/18/14 05:11 AM
01/18/14 05:11 AM
Mesa, Arizona
Mesa, Arizona
Rear of motor. Start detailing tomorrow
Re: 1968 GTS 383 [Re: dart4forte] #1384885
01/18/14 05:13 AM
01/18/14 05:13 AM
Mesa, Arizona
Mesa, Arizona
Got the car on the rotisserie yesterday, decided to steam clean the car. There's lots of plug welds to be done with the wheel houses and quarter panels
Re: 1968 GTS 383 [Re: dart4forte] #1384886
01/18/14 05:16 AM
01/18/14 05:16 AM
Mesa, Arizona
Mesa, Arizona
Lots of grime, oily dirt and just plain crud. Notice the torque boxes in the rear and not the front.
Forgot to mention the right front wheel of the rotissery ran over my left foot. Broke three toes OUCH!!!!!!!
