Page 7 of 17 1 2 5 6 7 8 9 16 17
Re: 1968 GTS 383 [Re: dart4forte] #1384847
10/01/13 11:01 PM
10/01/13 11:01 PM
Mesa, Arizona
dart4forte Offline OP
Mesa, Arizona
Last one. Special thanks to FABO member Hotrod340 of the Amarillo Mopar club for digging these up
Re: 1968 GTS 383 [Re: dart4forte] #1384848
10/05/13 11:31 PM
10/05/13 11:31 PM
Minnesota
DLewis Offline
DLewis  Offline
Minnesota
That looks absolutely awesome!
Re: 1968 GTS 383 [Re: DLewis] #1384849
10/05/13 11:54 PM
10/05/13 11:54 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I have a set of small bolt Keystones but they are missing the center caps, which fit only small bolts. They are tough to find for sure!
JB Rhinehart, Realist
A-Body's RULE!
Re: 1968 GTS 383 [Re: dart4forte] #1384850
10/21/13 10:13 PM
10/21/13 10:13 PM
Mesa, Arizona
Mesa, Arizona
Spent the last few days washing nuts and bolts. I think I've worn out my tumbler. Got most of the hardware for the engine cleaned so now starts the suspension. Everything is at the powder coater, should be ready for pickup Thursday. Tranny is out and that will go to the shop for freshening up. Block is now washed and cleaned out and have all the parts for reassembly. Here's a boring pic of the painting
Re: 1968 GTS 383 [Re: dart4forte] #1384851
10/22/13 07:36 PM
10/22/13 07:36 PM
Mesa, Arizona
Mesa, Arizona
Here's some progress on the car. Top off the doner car this afternoon
Re: 1968 GTS 383 [Re: dart4forte] #1384852
10/23/13 12:36 AM
10/23/13 12:36 AM
Between Houston & Galveston TX
SattyNoCar Online happy
SattyNoCar  Online Happy
Holy.....
Also looks like the wagon is coming back together.
John
Re: 1968 GTS 383 [Re: SattyNoCar] #1384853
10/23/13 06:10 PM
10/23/13 06:10 PM
Mesa, Arizona
Mesa, Arizona
Holy.....
well, almost. Got the tailgate finished and the metal along the side windows is next. Only big sanfu is the bumper. Took it over to Spokane to be replated. Job started costing $400 to replate only to find out they raised their rates so it's $600 to plate. This all due to the tree huggers we have here in the NW. So, lat week they call and say that while repairing the ends of the bumper they blow out some metal while welding. Now the price jumps to $1500 to reapir, staighten and replate. I don't think so. Picked up the bumper on Monday. They did staighten the bumper so we'll go ahead and repair the rust damage and paint the bumper. That will do until I can find another good bumper. Nothing is ever easy.
Re: 1968 GTS 383 [Re: dart4forte] #1384854
10/28/13 10:22 PM
10/28/13 10:22 PM
Mesa, Arizona
Mesa, Arizona
Heres a pic of the replacement top from the doner car. Will need to be blasted before it's grafted in
Re: 1968 GTS 383 [Re: dart4forte] #1384855
10/28/13 10:29 PM
10/28/13 10:29 PM
Mesa, Arizona
Mesa, Arizona
Number two
Re: 1968 GTS 383 [Re: dart4forte] #1384856
10/28/13 10:30 PM
10/28/13 10:30 PM
Mesa, Arizona
Mesa, Arizona
Number three
Re: 1968 GTS 383 [Re: dart4forte] #1384857
10/28/13 10:32 PM
10/28/13 10:32 PM
Mesa, Arizona
Mesa, Arizona
The next challenge is to find all of the parts I cleaned and bagged last winter. I'm down to looking for two boxes which are real important. Emblems and motor mounts
Re: 1968 GTS 383 [Re: dart4forte] #1384858
10/28/13 10:42 PM
10/28/13 10:42 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Looking good John, good move replacing the roof skin, that car deserves it
Re: 1968 GTS 383 [Re: ScottSmith_Harms] #1384859
10/30/13 03:18 PM
10/30/13 03:18 PM
Mesa, Arizona
Mesa, Arizona
Yeah, the more we looked at it the more it became apparent that the roof skin needed to be replaced.
Had a scare yesterday. Couldn't find my motor mounts. Looked high and low. The kid that Nick had working for him had the motor ready to go and put the mounts in a safe place. Of course Nick fired him later so we couldn't find that safe place until yesterday. Ordered all the brake hardware today, motor is in the process of rebuild so things are coming together.
Reading the article on how you restored your fuel lines, interesting. Thinking of taking that idea and applying the use of large PVC pipe for the lines to soak in the rust remover. Since I have new lines waiting for install I'll go ahead with that. Who restored your sending unit?
Also, we flow tested the A body exhaust manifolds against a standard B and C body magnum manifold. I've always wanted to do this. The data is quite interesting. They flowed pretty much the same. We put emphasis on the driver side manifold especially around the bend that cleared the steering to see if that caused a restriction. The flow numbers showed a slight cfm difference. I think the hp differance between the 335hp and the 330hp 383 was more in line with the different camshaft profile rather than an exhaust restriction.
That yellow Duster is coming right along
Re: 1968 GTS 383 [Re: dart4forte] #1384860
10/30/13 03:29 PM
10/30/13 03:29 PM
Mesa, Arizona
Mesa, Arizona
Update on the motor build. Found out day before yesterday that two of the bores have a rust spot that may not be taken out by honing. Kinda disappointing in that the motor had TRW forged pistons and I was planning on re-using them. A light hone didn't affect either bore so we are looking at several options.
At this point the block can be bored to .040. It's at .030 now. there's no way to know of boring to .040 will take care of the rust spots. Don't know how deep they are in the metal. If we bore to .040 and we're successfull we can order a hyperutecnic piston to fill the holes. there are not many piston options available for the 383.
The second option would be to sleeve the two bores and take them to .030 and re-using the TRWs. Both options cost basicly the same.
Re: 1968 GTS 383 [Re: dart4forte] #1384861
11/04/13 07:01 PM
11/04/13 07:01 PM
Mesa, Arizona
Mesa, Arizona
Thought I would do some checking on getting the grill and tail panel claened up. They are in pretty good shape with just a few small dings. They need cleaning and paint. I check with a vendor and this is the quote I got
The grille is about $1250, the headlight bezels (pair) around $550, the tail finish panel around $900.00
Re: 1968 GTS 383 [Re: dart4forte] #1384862
11/16/13 08:55 PM
11/16/13 08:55 PM
Mesa, Arizona
Mesa, Arizona
Update.....
The dash is out for cleaning, painting, and general wiring resto. Judging by all the holes looks like past owners had CBs, gauges etc under the dash. Also looks like it was bent a little bit underneath
Re: 1968 GTS 383 [Re: dart4forte] #1384863
11/16/13 08:56 PM
11/16/13 08:56 PM
Mesa, Arizona
Mesa, Arizona
Dashpad
Re: 1968 GTS 383 [Re: dart4forte] #1384864
11/16/13 08:57 PM
11/16/13 08:57 PM
Mesa, Arizona
Mesa, Arizona
looky at all the holes
Re: 1968 GTS 383 [Re: dart4forte] #1384865
11/16/13 09:04 PM
11/16/13 09:04 PM
Mesa, Arizona
Mesa, Arizona
Had a supprise yesterday. The guys got the roof fitted and ready to spotweld
Re: 1968 GTS 383 [Re: dart4forte] #1384866
11/16/13 09:05 PM
11/16/13 09:05 PM
Mesa, Arizona
Mesa, Arizona
The other side
