green bearing install #1384720
02/10/13 06:44 PM
02/10/13 06:44 PM
Oconto wi
tillysuperbee Offline OP
Oconto wi
got my green bearins that i ordered from
mancinni and not instructions came with like they said. any tips or directions ?
Re: green bearing install [Re: tillysuperbee] #1384721
02/10/13 07:05 PM
02/10/13 07:05 PM
Fitchburg,Massachusetts
MPerry Offline
Mopahts memba'
MPerry  Offline
Mopahts memba'
Do you have the old bearings off and do you have access to a press?
Re: green bearing install [Re: MPerry] #1384722
02/10/13 07:14 PM
02/10/13 07:14 PM
Oconto wi
Oconto wi
yes they are off and cleaned up and i have access to a press
Re: green bearing install [Re: tillysuperbee] #1384723
02/10/13 07:31 PM
02/10/13 07:31 PM
MPerry Offline
Mopahts memba'
MPerry  Offline
Mopahts memba'
Should be as simple as pressing the bearing on then press the collar on. Make sure you don't have a side load on the bearings from the spacer block. (I remove mine when running green bearings) Make sure you have the inner seals installed.
Re: green bearing install [Re: tillysuperbee] #1384724
02/10/13 08:16 PM
02/10/13 08:16 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
64 Plymouth Savoy
Dana 60
