Will I need to change My rear end?? #1384642
02/10/13 05:47 PM
02/10/13 05:47 PM
Plant city fl
70Dart499 Offline OP
Plant city fl
Will I need to change my 8 3/4 out in order to run a trans brake? My car weighs 3100 pounds and runs 6.80's, would probably run 6.70's with the brake. I would love to be able to switch to a tranny brake so I could run super pro, but I'm not liking the idea of having to buy a $3,000.00 moser rear end to do it.
1970 Dart Drag Car
Re: Will I need to change My rear end?? [Re: 70Dart499] #1384643
02/10/13 06:30 PM
02/10/13 06:30 PM
MI
68shifter Offline
68shifter  Offline
MI
How stout is your 8-3/4 now. You could likely get by for a while but eventually on borrowed time.
You can get Dana's built for half of that. If your ladder bar consider a truck housing since the snubber provision isn't needed for you, and you already have brakes.
Good luck.
68' Barracuda (4 speed) 64' Savoy (4 speed) 65' Satellite (girl tranny)
Re: Will I need to change My rear end?? [Re: 68shifter] #1384644
02/10/13 06:36 PM
02/10/13 06:36 PM
Plant city fl
Plant city fl
The 8 3/4 is pretty Stout, it's got a spool, moser axles, not sure on the gear, but I don't think it's a pro gear (I may be wrong but I don't think they make one for an 8 3/4). It's a stock case and thirdmember, and it's not backbraced. I don't like the idea of being on borrowed time, so I might just wait a footbrake race for a while longer until I can swap the rear for a Dana or a 9". Where might I find a Dana cheaper than moser & strange.
1970 Dart Drag Car
Re: Will I need to change My rear end?? [Re: 70Dart499] #1384645
02/10/13 08:08 PM
02/10/13 08:08 PM
B.C. Canada
hankcrank Offline
hankcrank  Offline
B.C. Canada
Big blocks are hard on 8 3/4's and the trans brake would make things worse. Your car is not real heavy but still over 3,000. You might be OK if it was a lot lighter but if your goal is to run super pro it is normally a full tree so foot braking is competitive in that class.
Re: Will I need to change My rear end?? [Re: 70Dart499] #1384646
02/10/13 08:31 PM
02/10/13 08:31 PM
Central New York
slippery440 Offline
Crybaby440
slippery440  Offline
Crybaby440
Central New York
And here we go!! Do everyone a favor and do a search. You will find atleast 100 post on this subject. I will not answer this question just for the reason someone eles will answer just the oposite way. This is the great debate.
If the MODS did their job I would not be hitting the notify MOD button. LOL
Re: Will I need to change My rear end?? [Re: slippery440] #1384647
02/10/13 08:36 PM
02/10/13 08:36 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I switched to a Dana 60 when I went to a t-brake in my Mirada just because I wanted to decrease my chances of scattering parts out back.
Re: Will I need to change My rear end?? [Re: J_BODY] #1384648
02/10/13 08:46 PM
02/10/13 08:46 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
....and we went to a D-60 in our small block Duster as it was running faster than the Mirada and we were twisting the 30 spline axles pretty hard. Rather than spend the $$ on new axles and matching spool, we just sold off our gear sets, and built a Dana.
Re: Will I need to change My rear end?? [Re: 70Dart499] #1384649
02/10/13 08:51 PM
02/10/13 08:51 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
The 8 3/4 is pretty Stout, it's got a spool, moser axles, not sure on the gear, but I don't think it's a pro gear (I may be wrong but I don't think they make one for an 8 3/4). It's a stock case and third member, and it's not back braced. I don't like the idea of being on borrowed time, so I might just wait a foot brake race for a while longer until I can swap the rear for a Dana or a 9". Where might I find a Dana cheaper than moser & strange.
with a trans brake i would not waste your time trying to make a 8-3/4 live. i would go with a Dana 60 or 9 inch ford. when i built the Dana in my 65 Plymouth, i used the 60 out of a 78 3/4 ton ford truck. i sent the housing off to moser to have ends put on it.i think i had less than 1500 in the hole set up. OK my 73 dodge dart weighs 3520 with me in it.i have a stock stroke 440, with a back braced 8-3/4, 742 case, Richmond 4.10 gears moser 30 spline spool axles. right after i got the car running i took it to the track and blew up the 4.10 gears on my 5th pass. at time i was only running 1.58 60foots and 10.66 at 125 in the 1/4. i have sense then put Richmond 4.30 gears in and have ran a best 60 ft of 1.48 and a 10.49 at 125 in the 1/4. sorry for the long winded post just trying to say i don't see your 8-3/4 lasting very long with a trans brake and the power you are making. mopar65
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: Will I need to change My rear end?? [Re: mopar65] #1384650
02/10/13 08:52 PM
02/10/13 08:52 PM
mopar65 Offline
mopar65  Offline
oh sorry here is a pick of my wasted 4.10 gears. Mopar65
Re: Will I need to change My rear end?? [Re: 70Dart499] #1384651
02/10/13 08:53 PM
02/10/13 08:53 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Its not very stout if it isnt back braced... that
would be the first thing to do... I dont know if you
do your own work or not BUT if you dont you might
as well get a dana now... if you dont back brace a
8 3/4 your on borrowed time... if it hooks at all
the ends will bend forward
EDIT
I use a 8 3/4 on a trans brake... have for YEARS but
in a lighter car... I wont get into what others say
about the 8 3/4 but in a lite car they live fine
(doenst matter on the torque)......... JMO
Re: Will I need to change My rear end?? [Re: hankcrank] #1384652
02/10/13 08:56 PM
02/10/13 08:56 PM
Plant city fl
Plant city fl
Super Pro around here is a full tree, and while I might be able to go some rounds at my local track, I won't be competitive at the big money bracket races without a t-brake and a delay box, not to mention I would like to try to run a few IHRA Hot Rod (aka NHRA Super Street 10.90 index) races in the future. Im shooting for eventually being able to double enter in both footbrake and super pro. It looks like a Dana is in order first though, thanks for the advice.
1970 Dart Drag Car
Re: Will I need to change My rear end?? [Re: 70Dart499] #1384653
02/11/13 01:23 AM
02/11/13 01:23 AM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
You can build a Dana for under $1000 if your thrifty....even if you have one built it won't cost $3000....call Dr diff. My guess is $2000 tops.
Re: Will I need to change My rear end?? [Re: Quicksilver440] #1384654
02/11/13 01:26 AM
02/11/13 01:26 AM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
trans brakes, and 8 3/4 Not good
....do a dana a be done with it..
Re: Will I need to change My rear end?? [Re: 70blackfish] #1384655
02/11/13 02:03 AM
02/11/13 02:03 AM
Poulsbo, WA
ChrisJohnston669 Offline
Poulsbo, WA
strange dana 60 is like 2000-2200
Re: Will I need to change My rear end?? [Re: ChrisJohnston669] #1384656
02/11/13 02:27 AM
02/11/13 02:27 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
My dana was $50 for the housing out of a truck
$385 to narrow, install the torino ends by dutchman
$400 for 35 spline shafts
$85 for 3.55 dana gears
$175 for 35 spline power lock
$350 for bearing and install kit
$200 for explorer disk brake kit
I installed dana 70 gears in the 60 shousing, its a hybrid called a Jana 76, it was only about 150 more to do the conversion.
Tim
Re: Will I need to change My rear end?? [Re: 70Dart499] #1384657
02/11/13 10:06 AM
02/11/13 10:06 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
why not back brace it? That should help. 3100lbs is light enough.
Coming soon!!!!
Re: Will I need to change My rear end?? [Re: Mr.Yuck] #1384658
02/11/13 11:49 AM
02/11/13 11:49 AM
robin hood country
deaks Offline
deaks  Offline
robin hood country
Another thing worth mentioning, is that selling the 8-3/4 before it's broke, will go along way to paying for the dana.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: Will I need to change My rear end?? [Re: 70Dart499] #1384659
02/11/13 12:23 PM
02/11/13 12:23 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Another thing to consider is...is it really worth all that cost and work to pick up a tenth?
Re: Will I need to change My rear end?? [Re: 70Dart499] #1384660
02/11/13 12:33 PM
02/11/13 12:33 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
A brand new bolt-in Dana 60 with 35 spline axles, spool, choice of ratio and 1350 yoke runs $1800.
You can re-use your old brakes.
Re: Will I need to change My rear end?? [Re: Mr.Yuck] #1384661
02/11/13 01:33 PM
02/11/13 01:33 PM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
Because in the end the weak link is still the GEARS , see the picture above .
