Will I need to change My rear end??
#1384642
02/10/13 05:47 PM
02/10/13 05:47 PM
Posts: 153 Plant city fl
70Dart499
Plant city fl
Will I need to change my 8 3/4 out in order to run a trans brake? My car weighs 3100 pounds and runs 6.80's, would probably run 6.70's with the brake. I would love to be able to switch to a tranny brake so I could run super pro, but I'm not liking the idea of having to buy a $3,000.00 moser rear end to do it.
1970 Dart Drag Car
Re: Will I need to change My rear end??
[Re: 70Dart499]
#1384643
02/10/13 06:30 PM
02/10/13 06:30 PM
Posts: 1,169 MI
68shifter
MI
How stout is your 8-3/4 now. You could likely get by for a while but eventually on borrowed time. You can get Dana's built for half of that. If your ladder bar consider a truck housing since the snubber provision isn't needed for you, and you already have brakes. Good luck.
68' Barracuda (4 speed)
64' Savoy (4 speed)
65' Satellite (girl tranny)
[Re: 68shifter]
#1384644
02/10/13 06:36 PM
02/10/13 06:36 PM
70Dart499
Plant city fl
The 8 3/4 is pretty Stout, it's got a spool, moser axles, not sure on the gear, but I don't think it's a pro gear (I may be wrong but I don't think they make one for an 8 3/4). It's a stock case and thirdmember, and it's not backbraced. I don't like the idea of being on borrowed time, so I might just wait a footbrake race for a while longer until I can swap the rear for a Dana or a 9". Where might I find a Dana cheaper than moser & strange.
1970 Dart Drag Car
[Re: 70Dart499]
#1384649
02/10/13 08:51 PM
02/10/13 08:51 PM
Posts: 3,838 Central Missouri Fort Leonard...
mopar65
The 8 3/4 is pretty Stout, it's got a spool, moser axles, not sure on the gear, but I don't think it's a pro gear (I may be wrong but I don't think they make one for an 8 3/4). It's a stock case and third member, and it's not back braced. I don't like the idea of being on borrowed time, so I might just wait a foot brake race for a while longer until I can swap the rear for a Dana or a 9". Where might I find a Dana cheaper than moser & strange.
with a trans brake i would not waste your time trying to make a 8-3/4 live. i would go with a Dana 60 or 9 inch ford. when i built the Dana in my 65 Plymouth, i used the 60 out of a 78 3/4 ton ford truck. i sent the housing off to moser to have ends put on it.i think i had less than 1500 in the hole set up. OK my 73 dodge dart weighs 3520 with me in it.i have a stock stroke 440, with a back braced 8-3/4, 742 case, Richmond 4.10 gears moser 30 spline spool axles. right after i got the car running i took it to the track and blew up the 4.10 gears on my 5th pass. at time i was only running 1.58 60foots and 10.66 at 125 in the 1/4. i have sense then put Richmond 4.30 gears in and have ran a best 60 ft of 1.48 and a 10.49 at 125 in the 1/4. sorry for the long winded post just trying to say i don't see your 8-3/4 lasting very long with a trans brake and the power you are making. mopar65
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727
10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come...
( SGT Miller) Proudly served 12 years in the US ARMY RESERVES
support our troops
[Re: hankcrank]
#1384652
02/10/13 08:56 PM
02/10/13 08:56 PM
70Dart499
Plant city fl
Big blocks are hard on 8 3/4's and the trans brake would make things worse. Your car is not real heavy but still over 3,000. You might be OK if it was a lot lighter but if your goal is to run super pro it is normally a full tree so foot braking is competitive in that class.
Super Pro around here is a full tree, and while I might be able to go some rounds at my local track, I won't be competitive at the big money bracket races without a t-brake and a delay box, not to mention I would like to try to run a few IHRA Hot Rod (aka NHRA Super Street 10.90 index) races in the future. Im shooting for eventually being able to double enter in both footbrake and super pro. It looks like a Dana is in order first though, thanks for the advice.
1970 Dart Drag Car
[Re: Mr.Yuck]
#1384658
02/11/13 11:49 AM
02/11/13 11:49 AM
Posts: 3,210 robin hood country
deaks
robin hood country
Another thing worth mentioning, is that selling the 8-3/4 before it's broke, will go along way to paying for the dana. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
