Weird Holley Accel Pump problem UPDATE
#1384154
02/09/13 07:56 PM
02/09/13 07:56 PM
Posts: 20,773 A collage of whims
topside
A collage of whims
Here's something I've never run into before (800DP): When running, Sec pump arm is locked, won't move. Pull carb off, disassemble, reassemble, works fine. Back on motor, start up, locks up again. Check ball @ pump is free, arm isn't bent. Right now with engine off, adjustment backed completely off, still locked. Probably the 20th Holley I've been through at least; what did I miss? Carb was built up from a buddy's spare parts but otherwise seems OK.
Re: Weird Holley Accel Pump problem - ???
[Re: topside]
#1384155
02/09/13 09:14 PM
02/09/13 09:14 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
did you replace the pump diaphragm ?
had something happen on primary pump..
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: Sixpak]
#1384162
02/10/13 12:20 AM
02/10/13 12:20 AM
Posts: 1,090 Saskatchewan, Canada
barracudabob
I've had the hole in the bowl gasket close up when the screws holding the bowl get tightened. Check the die cut hole in the gasket. Teflon coated ones tend to do it less, the black thick paper ones or brown ones are usually the culprit. Old bowl gaskets used to only punch one hole for the pump passage and if you put the gasket on backwards it would block the hole. Most new gaskets have two holes in them to prevent this problem.
X2 Had this happen on a 600 Holley. Gasket only had one hole for acc pump. I had it on backwards, and the arm wouldn't move.
Re: Weird Holley Accel Pump problem UPDATE
[Re: topside]
#1384168
02/10/13 06:22 PM
02/10/13 06:22 PM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
you have a vac secondary meetering block not one from a dbbl pumper
BB, TT5,Procharged 3300lb Street Car 4.79/154
[Re: topside]
#1384170
02/10/13 06:55 PM
02/10/13 06:55 PM
bigtimeauto
Trophy Winner
Trophy Winner
its actually 3 holes you will have to drill and then plug the bottom of the block where you drill. just look at your front block.
I'm not even sure if you have the boss in that block. not to mention the fueling is also going to be off as the emulsion tubes are different on pumpers versus vac secondary carbs.
