Another what will it make G4 G3 Hybrid Hemi.
#1383680
02/08/13 08:59 PM
02/08/13 08:59 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
I've been thinking about this combo for some time and would like input as to what it could make HP wise? 6.4 factory short block. 03 to 08 5.7 hemi heads, hand ported and stock valve. About 300 cfm at .600 6.4 hemi standard tranny cam. I think its bigger than the auto. Lift I think is .557 int .537 Ex. If my calculations are correct running the 03-08 head would result in a 9.5 compression. With headers and a drag pack intake, would 540 hp at 6500 be possible?
Re: Another what will it make G4 G3 Hybrid Hemi.
[Re: WO23Coronet]
#1383682
02/08/13 09:23 PM
02/08/13 09:23 PM
MattW
Ontario Canada
IMO and I'm no expert, the Apache is too big. This is not a race engine looking for throttle response and usable RPM. I think this combo would be duable for around 5K
[Re: MattW]
#1383683
02/08/13 09:49 PM
02/08/13 09:49 PM
Posts: 458 Michigan
BPE
Matt This will never work and be a total waste of your hard earned money. Just pack it up and send to me. Rod
[Re: MattW]
#1383684
02/08/13 10:03 PM
02/08/13 10:03 PM
Posts: 833 MN
hemidup
MN
The closet engine I built that made 545 hp was based off a 6.1 block, cnc ported 5.7 heads with 2.05" int and 1.57" exh valves, 4.055" bore/4.05" stroke = 418 cubes, 9:1 compression, 231/236 @ .050 114lsa, 5.7 plastic truck intake and 80mm throttle body. 545 hp at 5600 rpm was all it would make due to the restrictive plastic intake manifold. So the engine only made 1.3 hp per cube which I was hoping for a bit more. Your gonna have to make 1.37 hp per cube to reach your goal of 540 hp which I think you can do with your tad bit higher compression, don't know much about the cam, but COMP might have them now, your intake, carb and with a 1000 more useable rpm just might get you there.
Jerry Williams.
[Re: BPE]
#1383685
02/08/13 10:15 PM
02/08/13 10:15 PM
MattW
Ontario Canada
Rod
LOL Looks like a 4.06 bore for my pistons. Will contact you soon. Matt
[Re: hemidup]
#1383686
02/08/13 11:56 PM
02/08/13 11:56 PM
MattW
Ontario Canada
That truck intake is real good at a mild level. With the cubes you had I see why it was done at 5600. IMO the DP intake is basically a tunnel ram and works extremely well at all RPM.This is were I THINK the power will come from. This whole package should be able to bolt together for less that 5K if you have an spun 5.7 laying around. 2240.00 for short block. Old 5.7 heads 80.00 for G4 camshaft 800.00 for intake 670 for MDS contoller and wiring harness 70 for toner ring 200 for front cover. I'm I missing anything
[Re: MattW]
#1383687
02/09/13 01:21 AM
02/09/13 01:21 AM
Posts: 72 San Angelo, Texas
Cevidicus
San Angelo, Texas
I would think you would need the G4 timing set and the Comp phaser lock outs. If you pop out the crank to change out tone rings you'll need to replace all the tty fasteners. Or I've been told that the FAST XIM ignition controller will work with the 54 tooth G4 tone ring.
I'd like to see a Combo like this work. Would make a wicked little street motor.
[Re: Cevidicus]
#1383688
02/09/13 10:01 PM
02/09/13 10:01 PM
MattW
Ontario Canada
OK add 90 for the phaser lock out and 200 for the timing chain set. As for the crank reluctor wheel, is it possible to change this without removing crank?
[Re: MattW]
#1383689
02/10/13 06:13 AM
02/10/13 06:13 AM
Posts: 833 MN
hemidup
MN
To change out the reluctor wheel/toner ring, need to pull the crank.
Jerry Williams.
