Re: E-Body disc brakes dragging
[Re: DAYCLONA]
#1383048
02/07/13 03:26 PM
02/07/13 03:26 PM
Posts: 520 New Zealand
nz383man
New Zealand
Cheers Mike Yes this car is factory boosted & has had a new master cylinder although I thought the brakes dragged with the old one too. How do I check this clearance? do I split the Master cylinder off the booster, measure how far the pin protrudes & measure how far in it's seat is on the master cylinder? Thanks, Kevin
[Re: nz383man]
#1383050
02/07/13 05:33 PM
02/07/13 05:33 PM
RapidRobert
Either look into the fluid as said or undo the M/C mounting nuts & pull the M/C forward some or open a bleeder & turn the wheel/rotor & that'll tell you if it is a pushrod adjustment (psi) problem. As said discs always have some drag & the Q is how much do yours have? I just replaced the 74 A single piston caliper on one side when I had that problem & the new (rebuilt) one had way less drag but as you know the 4 piston ones ain't cheap
