oil capacity of small block?
#138297
10/18/08 09:32 AM
10/18/08 09:32 AM
Posts: 693 Coronado, CA
go-fish
Coronado, CA
I have a Moroso 7qt and put 7 qts in it for the first time. So my question is how much more do I put in for the oil galleys and oil fiter. I filled the filter as much as I could (1/2 way) and was wondering if I should put more to compensate for the oil gallies and the rest of the oil system.
70 'cuda: ProCharged 408, Tremec 5 speed, S60,triangulated 4 link, Hydroboost and Wilwoods
Re: oil capacity of small block?
[Re: MoparforLife]
#138299
10/18/08 10:31 AM
10/18/08 10:31 AM
go-fish
Coronado, CA
The dipstick and dipstick tube aren't stock. I need to mark the dipstick with an engraver for proper fill marks when I get it at the right level.
[Re: BergmanAutoCraft]
#138301
10/18/08 11:03 AM
10/18/08 11:03 AM
go-fish
Coronado, CA
That sucks. The engine is in the car so it'll be hard to do that. I think the dip stick is out of a Magnum Dakota. I'll see if I can find the receipt. If it is then I should just use the fill marks on the stick, right? LA & Magnum same in that respect?
[Re: go-fish]
#138302
10/20/08 07:42 AM
10/20/08 07:42 AM
well i have the milodon 7qt pan (340) and changed the oil the other day. I put in 8qts (i extra for the filter) and the oil level was at the FILL line on the dipstick.
Im thinking these new chrome dipsticks arent that accurate.
anyone know the correct tube length for the small black. I had a bitt of trouble getting the tube in the block. it might be up a little bit. a measurement would confirm this
[Re: MNobody]
#138304
10/20/08 10:32 AM
10/20/08 10:32 AM
The dipstick tube on my 1974 318 measures about 7 3/4 inches from the block to the top of the tube and the full mark on the dipstick is 16 3/8" down from the top of the tube. This is not a factory tube, it has been cut to length which i hope is right lol. Stock oil pan and 5 quarts of oil put's it right between the U and the L on full which is slightly above the full line. hope this helps.
its a start! Thanks!
now that I think about it, I have an old power wagon I could use for measuring.... DOH!
