Dual 4160 Stage V Intake HEMI Carb Setup Recommendation
#1382595
02/06/13 08:21 PM
02/06/13 08:21 PM
Posts: 9,670 Lima, Peru
domingo
EL Master
EL Master
Lima, Peru
Hi guys! Please help me come up with a baseline setup for my 4160 carbs. They are going on a: -528 CID HEMI (4,5" bore 4,15" stroke) -10.5:1 CR -CNC ported MP Cyl Heads by Modern Cyl Head tested @ 28" 4.315" bore size 2.25" intake valve 1.94" exh valve intake exh 0.100 74.9 68.1 0.200 157.2 133.3 0.300 249.8 198 0.400 323.7 239.5 0.500 385.8 271.7 0.600 418.2 265.9 0.700 430.8 254.4 0.800 430.8 249.8 0.900 428.1 244.7 1.000 429.9 241.5 -2,25" headers -open exhaust -Stage V RAT BUSTER dual inline intake Manifold -Dual 4160 Holley 750 cfm carbs -Comp Cams Xtreme Street SOLID Roller Cam Intake- 248@.050 & .604lift >Exhaust- 254@.050 & .591lift >Lobe sep is 114 >lobe #`s: 4875B/4876B sn#-A6105 I am going thrugh my carbs (I got em used) and this is what Ive found so far: -They have a proform primary Billet Metering plate. -They have a Quick Fuel Seciondary Plate that allows me to Have screw in Jets -I found NO check balls on the Vacuum Secondary Diaphragms - The Springs on the Vacuum Secondary Diaphragms are RED -I have a 4 port window 105 power valve -Primary Jets are 72 -Secondary Jets are 80 -Accelerator Pump Discharge Nozzles are 31 -I have the low Profile Accelerator Pumps I guess they are 30cc -I have the orange Pump Cams set on hole #1 One thing that caught my eye is that when I took the Proform Primary Metering PLate out one of the emulsion holes on each side is plugged (see pic) Any suggestions on how to set em up/what to change for my engine? This is going in my race car. 67 Barracuda 2900 pounds 727 w/ trans brake 4,88 gears 33" slicks cal tracks 5800 stall Turbo Action Converter Thanks!!!!!!!!
Re: Dual 4160 Stage V Intake HEMI Carb Setup Recommendation
[Re: Dragula]
#1382598
02/07/13 11:18 AM
02/07/13 11:18 AM
Posts: 2,652 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
John Arruzza probably has the most experience with that intake. Call him at 919-918-7584.
For what it's worth, that intake is mostly a repop of the old KB/Chrysler marine intake. The Holley carbs for it were (I think) 4127 & 4128. Holley may not have made carbs with that number but modifieds 3116's to that number. Good luck. Remember you don't open them in stages like a street hemi. Open them both together.
2011 Drag Pak Challenger
[Re: rickseeman]
#1382599
02/07/13 11:42 AM
02/07/13 11:42 AM
domingo
EL Master
EL Master
Lima, Peru
Yes!
I have the linkage to open them together....
Man, I dont know, I havent bought anything from John EVER....It'd feel kinda weird to call him for advice and waste his time....
Somebody here's gotta know.
Or maybe Ill just go by the reccomendations on the MOpar Muscle Article and set up the carbs similar to that and go from there....
The engines are kinda similar: similar cubes, half a point less compresson than mine, a bigger cam, but less heads...here are the details on the mopar muscle engine:
Heads ($6,587.96) Type: Stage V Engineering Hemi Conversion (sold bare with, rockers, shafts and stands); $3,990.00 Finish Porting: Superior Automotive; $750.00 Valvesprings: Manley double w/damper PN 22430; $180.39 Valvespring Cups: Manley PN 42122; $59.95 Intake Valves: Manley 2.20 Severe Duty stainless PN 11516; $136.69 Exhaust Valves: Manley 1.90 Severe Duty stainless PN 11901; $136.69 Retainers: Manley titanium PN 23661; $190.00 Locks: Manley 10-degree PN 13193; $49.00 Lash Caps: Manley PN 42101; $28.00 Valve Seals: Pioneer neoprene w/ Teflon inserts; $16.00 Rocker Assembly: Stage V Engineering cast stainless roller rockers, billet thrust clamps, stands, shafts, plugs (incl. w/head set) Adjusters: Manton 3/8; $224.00 Pushrods: Crower 3/8 chrome moly PN 70399; $186.39 Rocker Covers: SVE cast aluminum, black wrinkle finish; $350.00 Rocker Cover Gaskets: Mopar Performance PN P4120353; $35.95 Head Gaskets: Fel Pro PN 1009; $39.95 Head Bolt Kit: SVE Grade 9; $145.00 Spark Plug Tubes: MP PN 4120294; $69.95
Camshaft ($1,044.97) Type: Crower mechanical roller PN33472; $381.99 Advertised Duration: 308-deg. Intake, 314-deg. exhaust Lift: 0.688-in. intake, 0.649-in. exhaust Centerline: 101-deg. Lifters: Crower mechanical roller, oiling type PN S-66232; $565.99 Timing Chain: JP Performance billet steel, PN 5606T; $89.00 Thrust Button: Manley aluminum PN 42116; $7.99
Induction ($1,101.88) Intake Manifold: Mopar Performance Street Hemi PN P5153737; $425.99 Remove Plenum Dividers: Superior Automotive; $150 Intake Gaskets: SCE PN P166101; $15.99 Carburetion: Dual Edelbrock 750-cfm Performers PN 1407; $254.95 (each)
Ignition ($527) Distributor: MSD ProBillet PN 8546; $295.10 Coil: MSD Blaster 2 PN 8202; $38.30 Wires: MSD HeliCore, 8-mm. PN 31289; $179.60 Timing Specs: 34-deg. BTDC Spark Plugs: Champion RN9YC; $14.00
[Re: sasquatch]
#1382606
02/07/13 05:36 PM
02/07/13 05:36 PM
Posts: 4,179 California
mickm
California
That intake as cast with minor port cleanup will make 850 HP. It is way more than a recast of the old Kb Marine intake. I have 528 hemis with that intake and ootb Eddie 800 avs carbs with basic tuning cracking 850 on the right motor which you sound like you have for the most part. Advice. 800 AVS and never look back. Todd
that's interesting. have you ever done any comparisons? i have the 650's on mine. just did 712HP at 6k. the engine is a 540, with stage V heads.
do you think the 800's will make that much difference?
[Re: sasquatch]
#1382607
02/07/13 05:42 PM
02/07/13 05:42 PM
domingo
EL Master
EL Master
Lima, Peru
so ive heard!!!
