Steering column reinstall problem
#138237
10/17/08 10:46 PM
10/17/08 10:46 PM
Posts: 328 Missouri, U.S.A.
JSSuperbee
Missouri, U.S.A.
Looking for help from anyone. Didn't change anything when I took the column out. Now it appears to be too short! The coupling is about 1/2 inch from going over the spline shaft in the box. I loosened the P.S. gear box up about 1/2 inch and pried it back towars the coupling. Still too short by about 1/8 inch therefore....I can't get the roll pin in. I tried hammering on the coupling to get it to go over the spline...no good...won't go any further. Tried loosening all the bolts that hold the column to the firewall....no good. I'm afraid if I keep hammering on the coupler and prying, I'm going to break something. What am I doing wrong. It's a '69 Superbee with auto on the column.
James Stinebaker
Re: Steering column reinstall problem
[Re: stumpy]
#138240
10/17/08 11:10 PM
10/17/08 11:10 PM
JSSuperbee
Missouri, U.S.A.
Do I have to take the column back out or can I leave it where it is?
James Stinebaker
[Re: 70sixpkrt]
#138241
10/17/08 11:13 PM
10/17/08 11:13 PM
JSSuperbee
Missouri, U.S.A.
Moving it back will make it even shorter. I need more length. I tried hammering it forward (towards the steering gear box)but it won't go any further.
James Stinebaker
[Re: JSSuperbee]
#138242
10/17/08 11:13 PM
10/17/08 11:13 PM
Posts: 3,685 South San Francisco, Ca
70sixpkrt
You can leave the column in. Just make sure it is unbolted. Just let it rest on the drivers seat. Remember the coupler has splines also.
[Re: 70sixpkrt]
#138246
10/18/08 12:32 AM
10/18/08 12:32 AM
JSSuperbee
Missouri, U.S.A.
I'v been beating on the vice grips and got some length out of it but need about another 1/16 inch. Still can't get the roll pin in. Everything is unbolted inside the car. Just mashed my finger pounding on the vice grips and bled all over everything. I'll try again tomorrow. Boy is this frustrating.....but I sure appreciate your input.
James Stinebaker
[Re: JSSuperbee]
#138247
10/18/08 12:35 AM
10/18/08 12:35 AM
70sixpkrt
Are you sure the splines are meshed evenly? How about putting a dab of grease on the splines? By the way, don't hammer it too hard. There is a seal underneath the the lock ring and it will leak. Don't ask me how I know that. Lets just say I have to pull my steering box next month.
[Re: 70sixpkrt]
#138248
10/18/08 12:24 PM
10/18/08 12:24 PM
JSSuperbee
Missouri, U.S.A.
The splines are meshed evenly because I've come with in about 1/16 inch of success. I've been beating on it pretty hard....probably damaged something. I know I mashed up the retainer and rubber seal on the back of the coupler. I'm just going to stick a bolt in the coupler in place of the roll pin and take it to the steering column shop. Too much frustration. Again, thanks for your help.
James Stinebaker
[Re: cuda70]
#138250
10/18/08 09:33 PM
10/18/08 09:33 PM
JSSuperbee
Missouri, U.S.A.
Never heard of shoes on the steering column. Maybe this is my problem with the coupler not going over the spined shaft all the way. Can I get a description of the shoes and where they are located in the shaft?
James Stinebaker
[Re: stumpy]
#138253
10/18/08 11:03 PM
10/18/08 11:03 PM
JSSuperbee
Missouri, U.S.A.
Could the shoes have moved without having taken apart the coupler?
James Stinebaker
[Re: Sixpak]
#138256
10/18/08 11:23 PM
10/18/08 11:23 PM
JSSuperbee
Missouri, U.S.A.
Yep...I checked those nylon square spacers. I made sure I had plenty of space there both fore and aft. I even had them unbolted and the column dropped down. All bolts were removed from the inside. The column won't go any further. I used the vice grips on the shaft and pounded the heck out it and it bottomed out about 1/16 inch short of going all the way. About 3/16" of the spline still shows between the coupler and the top of the gear box.
James Stinebaker
