who makes a 13 to1 4.00 stoke piston for w5s 55cc #1382162
02/05/13 10:14 PM
02/05/13 10:14 PM
CA.
RAY1969CARS Offline OP
CA.
im looking for a shelf piston ??????
this is a ross piston
340 4.070 4.000 6.123 4.2 13.1 497 1.459 99788^
would this fit the chamber ???? what have you guys done ?????
Re: who makes a 13 to1 4.00 stoke piston for w5s 55cc [Re: RAY1969CARS] #1382163
02/05/13 10:18 PM
02/05/13 10:18 PM
, PA
sleepyhead416 Offline
, PA
My flatop DIAMOND pistions came in @ 13.8 quench was 040
Re: who makes a 13 to1 4.00 stoke piston for w5s 55cc [Re: sleepyhead416] #1382164
02/05/13 10:22 PM
02/05/13 10:22 PM
CA.
CA.
with a w5 head ????
Re: who makes a 13 to1 4.00 stoke piston for w5s 55cc [Re: RAY1969CARS] #1382165
02/05/13 11:19 PM
02/05/13 11:19 PM
K
KOS Offline
KOS  Offline
K
55cc head with a flattop youll be 13.1 or better at that stroke and bore.
Re: who makes a 13 to1 4.00 stoke piston for w5s 55cc [Re: RAY1969CARS] #1382166
02/05/13 11:43 PM
02/05/13 11:43 PM
BPE Offline
BPE  Offline
You don't need a dome to get 13 to 1 with 4" crank and a 55 cc chamber and zero deck. A flat top will get you where you want to be.
Rod
Re: who makes a 13 to1 4.00 stoke piston for w5s 55cc [Re: BPE] #1382167
02/06/13 12:06 AM
02/06/13 12:06 AM
, PA
, PA
YEP W-5
Re: who makes a 13 to1 4.00 stoke piston for w5s 55cc [Re: RAY1969CARS] #1382168
02/06/13 02:06 AM
02/06/13 02:06 AM
CA.
CA.
sorry i have 65cc chambers
Re: who makes a 13 to1 4.00 stoke piston for w5s 55cc [Re: RAY1969CARS] #1382169
02/06/13 06:15 AM
02/06/13 06:15 AM
Washington
skrews Offline
skrews  Offline
Washington
Wiseco 13.4 - 13.8 nominal. 8cc dome volume. .043/.043/3mm rings, vertical gas ports. .984 or .927 pins.
[url=]photobucket[/url]
