want to retain key start but eliminate
#1382097
02/05/13 07:05 PM
02/05/13 07:05 PM
Posts: 1,824 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
Ballast resistor and voltage regulator. I took off reg.and ballast r. And car now doesn't start. Whats the cure.I'm so
Re: want to retain key start but eliminate
[Re: Sammy]
#1382100
02/06/13 01:34 AM
02/06/13 01:34 AM
Posts: 2,586 Illinois, Indiana, Louisiana
ProStDodge
to eliminate the voltage regulator, you need to install a 1-wire alternator, or move the existing V.R. inside the car.
Eliminating the ballast resistor is easy, as long as you are not using the original points. An MSD box or even a Petronix's will allow you to remove the ballast.
You still need at least one wire to the alternator, the oil pressure and water temp sending unit wires, as well as the coil power and ground wires.
