72 roadrunner firewall hole #1381886
02/05/13 06:25 AM
02/05/13 06:25 AM
AR
70_roadrunner Offline OP
AR
What is the 1 1/4" hole beside the A/C drain for on a 72 roadrunner? This is to the right side of the drain.
Re: 72 roadrunner firewall hole [Re: 70_roadrunner] #1381887
02/05/13 09:23 AM
02/05/13 09:23 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Without looking off the top of my head, I say it's for the vacuum to operate the heater/AC box. a rubber gromment goes in there.
Re: 72 roadrunner firewall hole [Re: 70_roadrunner] #1381888
02/05/13 11:02 AM
02/05/13 11:02 AM
Shoreline, Washington
72roadrunnergtx Offline
Correct, pass through for the heater A/C control vacuum supply line. Grommet is molded to the original vacuum hose.
1972 Road Runner GTX 440 6bbl 5-speed
[img]http://72rrgtx.com/carpics/bucket/DSC06730r-1.jpg[/img]
Re: 72 roadrunner firewall hole [Re: 72roadrunnergtx] #1381889
02/05/13 11:08 AM
02/05/13 11:08 AM
AR
AR
Thanks!
Re: 72 roadrunner firewall hole [Re: 72roadrunnergtx] #1381890
02/05/13 11:13 AM
02/05/13 11:13 AM
Cincinnati, Ohio
Cincinnati, Ohio
I stuck a steel tube through mine and the rubber vacuum hoses slides on to it, can't tell that there's a small steel tube in the grommet.
I didn't even try to get rubber vacuum hose through that rubber gromment.
