frame rail inboard spring mount help please #1381770
02/04/13 11:32 PM
02/04/13 11:32 PM
michigan woods
imfixinmopars426 Offline OP
michigan woods
i have a 69 dart im building,and it came with a moiser d60 rear,narrowed,all done ready to go,w/ disc's..so i already removed the inners to do a minitub,and the rear end was narrowed to use with the springs to be mounted in the framerail. i see mancini has the kits for sale to do this. what i was wondering can i have some tips on installing the kit??? i have never installed one of these,so i was hoping you all would give me some do's,and dont's on the install....thanks guys..mike
Re: frame rail inboard spring mount help please [Re: imfixinmopars426] #1381771
02/04/13 11:36 PM
02/04/13 11:36 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
here might be a good start for you.mopar65.
http://www.bigblockdart.com/techpages/springs.shtml
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: frame rail inboard spring mount help please [Re: mopar65] #1381772
02/04/13 11:43 PM
02/04/13 11:43 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
That is the preferred method I think. Locating off of the original front spring mounts makes it easy......which is why I did it the hard way.
I used a spring slider set up on the back instead of shackles , but either one will work for you.
Re: frame rail inboard spring mount help please [Re: imfixinmopars426] #1381773
02/05/13 12:21 AM
02/05/13 12:21 AM
PORT ALBERNI B.C. CANADA
71DemonRON Offline
71DemonRON  Offline
Not mine, think it is from a member on here though.
http://www.youtube.com/watch?v=SoHK23off-U
1971 Demon drag car
2004 SX 2.0
1971 Duster 340 4 speed , project for my Daughter
1998 Dodge Ram 3500 SLT Laramie quad cab dually 4x4 V10
Re: frame rail inboard spring mount help please [Re: tubtar] #1381774
02/05/13 08:27 AM
02/05/13 08:27 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Always a good idea to establish a true centerline with a plumb bob.
The original mounts aren't always true. Mine were off 1/4" side to side. Measure back from a 90 degree line to the true centerline. Then check the spring hanger mounts, torsion bar crossmember, and lower control arm pivots and see if all 3 match.
Doug
Re: frame rail inboard spring mount help please [Re: dvw] #1381775
02/05/13 10:02 AM
02/05/13 10:02 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
I went off marks on the floor using a plumb bob from the torsion bar cross member to the mounting hole C/L , but I wouldn't hesitate to use the stock spring hangers if you measure them and find the locations are good. Using round stock through those holes and the holes on the new spring mounts looks so easy that it is practically cheating.
Re: frame rail inboard spring mount help please [Re: tubtar] #1381776
02/06/13 12:55 AM
02/06/13 12:55 AM
michigan woods
michigan woods
thanks guys!!! having help like this makes a scary job,look simple. i just hate to cut up a solid little car...but some must be sacrificed,lol...great ideas,and links! thanks again...ordered the kit from mancini...there brand is much cheaper than the mp part. it was 110.00 vs 190...should be here maybe weds,and then i will fire up the plasma... =
