Monotubes or Twin Tube shocks on a street car #1381356
02/04/13 01:47 PM
02/04/13 01:47 PM
Cooperstown, NY
jrlegacy23 Offline OP
Cooperstown, NY
I am looking at coil overs for my HemiDenny K-Member on the front of 72 Dart. The car is primarily a street car. My question is, would a street car really max out a twin tubes potential? Would it benefit from monotube shocks much? Would I pretty much not see a difference on a street car?
Thanks everyone
Shock preference on a street car?
single choice
Votes accepted starting: 02/04/13 12:47 PM
You must vote before you can view the results of this poll.
[color:"#00FF00"]68 Fastback Barracuda with some stuff[/color]
Re: Monotubes or Twin Tube shocks on a street car [Re: jrlegacy23] #1381357
02/04/13 03:21 PM
02/04/13 03:21 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
I would say, it depends. While there is no debating that a mono-tube allows greater degree of precision control and can show increased performance as a result, the reality is if you have a street car that you are building as a cruiser, the twin tubes can do the vast majority of the job you want at a lower price.
Re: Monotubes or Twin Tube shocks on a street car [Re: jrlegacy23] #1381358
02/04/13 03:26 PM
02/04/13 03:26 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
With what you've already done, why bother with cheap shocks?
Re: Monotubes or Twin Tube shocks on a street car [Re: Skeptic] #1381359
02/04/13 03:28 PM
02/04/13 03:28 PM
Fly Over States
P
PHJ426 Offline
PHJ426  Offline
P
Fly Over States
What is the setup on the suspension already?
Re: Monotubes or Twin Tube shocks on a street car [Re: PHJ426] #1381360
02/04/13 03:30 PM
02/04/13 03:30 PM
Fly Over States
P
PHJ426 Offline
PHJ426  Offline
P
Fly Over States
Now I see some of your specs on the Dart but you made them in some crazy yellow color and its hard to read on my screen.
With a good rear leaf spring set up like you already have why worry about cheap shocks?
Re: Monotubes or Twin Tube shocks on a street car [Re: PHJ426] #1381361
02/04/13 03:46 PM
02/04/13 03:46 PM
Cooperstown, NY
Cooperstown, NY
I already have Hotchkis rear leafs with a Minitub, subframe connectors, 11" 4 wheel disc brakes that are drilled and slotted, torsion bars removed with a Hemidenny made K-Frame with manual rack and pinion steering.
Re: Monotubes or Twin Tube shocks on a street car [Re: jrlegacy23] #1381362
02/04/13 03:53 PM
02/04/13 03:53 PM
Fly Over States
P
PHJ426 Offline
PHJ426  Offline
P
Fly Over States
If its a budgetary issue I would install the cheaper shocks if it was keeping you from getting the car on the road. Since shocks are easily changed out when cash becomes available and would better fit the springs you installed out back.
Remember the suspension is a complete package kind of application where the tires, springs, shocks alignment all work together as a system. Of course matching all these components can be tricky without buying a complete system from a manufacturer.
Re: Monotubes or Twin Tube shocks on a street car [Re: PHJ426] #1381363
02/04/13 04:41 PM
02/04/13 04:41 PM
Cooperstown, NY
Cooperstown, NY
The price is not that of a big deal.
I can get the Twintube coilovers for around $350-450 pair. And I can get the Monotube coilovers for $550 pair.
My main concern is that I read that twin tubes are better for street when it comes to their manners (not as stiff). But also read that montubes are a better shock over all. I just figured I would get some advice from those real world people that have used them. I am just looking for a good ride.
Re: Monotubes or Twin Tube shocks on a street car [Re: jrlegacy23] #1381364
02/05/13 01:49 AM
02/05/13 01:49 AM
Southern CA
Colin Frolick Offline
Southern CA
who you buying shocks from? I'd call the mfgr and ask what they think. i've talked to afco and tokico on the phone a few times and they are very helpful.
Re: Monotubes or Twin Tube shocks on a street car [Re: Colin Frolick] #1381365
02/06/13 12:11 AM
02/06/13 12:11 AM
Cooperstown, NY
Cooperstown, NY
Buying either Ridetech's for the Monotubes. Either Aldan Eagles or QA1's for twin tubes.
Re: Monotubes or Twin Tube shocks on a street car [Re: jrlegacy23] #1381366
02/06/13 09:24 PM
02/06/13 09:24 PM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
how about inverted monotube?
Re: Monotubes or Twin Tube shocks on a street car [Re: jrlegacy23] #1381367
02/07/13 01:43 PM
02/07/13 01:43 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
I know there are some very high quality twin tube designs out on the market and a great number of them even proliferate the racing scene. On dirt tracks and in heavy street stock style racing, twin tubes may even be a preferred set up because of their ability to absorb damage. I would much rather have a high quality twin tube then a unknown mono-tube, not to say Ridetech is an unknown as they seem very active in street performance handling.
Re: Monotubes or Twin Tube shocks on a street car [Re: TC@HP2] #1381368
02/07/13 03:30 PM
02/07/13 03:30 PM
Woodinville, WA
Viol8r Offline
Viol8r  Offline
Woodinville, WA
I run the 26 way adjustable monotube Ridetech shock. Developed in conjunction with fox. So kind of a no brainer. I believe they are $500 a piece though, not 100% sure as they gave these to me as they sponsor the car.
By far one of the best mods to the car.
1968 Pro-Touring Dodge Charger
*2011 Optima Ultimate Street Car Challenge Invitee
http://www.popularhotrodding.com/features/1203phr_1968_dodge_charger/index.html
Re: Monotubes or Twin Tube shocks on a street car [Re: dangina] #1381369
02/09/13 01:05 AM
02/09/13 01:05 AM
Ontario,Canada
brads70 Offline
brads70  Offline
Ontario,Canada
I asked Ridetech on another forum, and the said yes it could be run upside down.
Re: Monotubes or Twin Tube shocks on a street car [Re: jrlegacy23] #1381370
02/10/13 02:46 AM
02/10/13 02:46 AM
Santa Cruz, California
Lefty Offline
Lefty  Offline
No, no and no. Driving around on the street nobody could tell if the shocks were mono or twin tube by the way the car felt. If you want benefits get adjustible shocks so you can tune them to your spring rates and car weight. You'll probably find most adjustible shocks are mono tube however.
