disk brake change over #1381108
02/03/13 08:12 PM
02/03/13 08:12 PM
im putting a set of a arms from a 73 duster an spindles on my 70 dart
the upper a arms take the bigger ball joint that i no, now the disk brake spindles will it work on the lower suspension with out changeing anything ?
please pm me with info
thank you randy
Re: disk brake change over [Re: ] #1381109
02/03/13 10:02 PM
02/03/13 10:02 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
thank you randy
Randy go to the tech archives and look at the brake article. It will clear up most questions. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: disk brake change over [Re: ] #1381110
02/03/13 11:36 PM
02/03/13 11:36 PM
The lower control arm is the same as what you have now just need a (disc) lower ball joint. The spindles are interchangeable from side to side but I'd mount them so the caliper is located on the opposite (front to rear) side of the spindle as the hard line to neoprene line frame mounting tab is so in other words the brake neoprene hose has to go behind/past the spindle to connect from the caliper to the frame tab. Using sway bars MAY force you to mount the calipers to the rear which is only problematic as you have to get creative with the hose selection but do check for interference lock to lock & up/down thru its' travel. Yes see the archives.
