Door Hinge Caulk?? #1380864
02/03/13 03:15 PM
02/03/13 03:15 PM
Vesper,Wisconsin U.S.A
DusterJeff Offline OP
I recently removed the door hinges on my Duster to rebush and repin.There appears to be some type of caulk or putty around where the bolts come through the pillar posts to mount the hinges to seal moisture out of the passenger compartment . Is this a special caulk or could I use some type of silicone to do the same job???
Do Something..Lead..Follow..or get the {Beep} out of the way..
Re: Door Hinge Caulk?? [Re: DusterJeff] #1380865
02/03/13 05:16 PM
02/03/13 05:16 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Its a mastic, you can get it from the local body shop supply store.
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
