fly wheel ?
#1380514
02/02/13 07:41 PM
02/02/13 07:41 PM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
my flywheel measures 12-1/2 inches across the face,not the gear.what tooth fly wheel would this be? i guessin it would take an 11 inch clutch making it a 143 tooth.
Re: fly wheel ?
[Re: bonefish]
#1380518
02/03/13 12:20 PM
02/03/13 12:20 PM
Posts: 75,004 U.S.S.A.
JohnRR
U.S.S.A.
if it wasnt installed thats what i,d do,but im to lazy to lay on my back on try it.how many diff tooth counts are there?
3 ...
What bellhousing do you have ?
Re: fly wheel ?
[Re: JohnRR]
#1380519
02/03/13 12:49 PM
02/03/13 12:49 PM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
3 ...
cant see the #,s it came off a 69 GTX.its installed on my run stand,if i hadnt loaned out my engine hoist id just pull it apart and count.
Re: fly wheel ?
[Re: JohnRR]
#1380521
02/03/13 06:19 PM
02/03/13 06:19 PM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
that would be the bellhousing for a 143 tooth flywheel.
What is your problem , starter not engaging ? you can count the teeth , mark your starting point with a marker , count 25 , rotate , 25 , rotate ....
not really havin a prob,its for my runstand and most of my motors are 8 bolt with exception of the one with 6 bolt that is on the stand now.Thanks,AJ
Re: fly wheel ?
[Re: 6PakBee]
#1380525
02/04/13 10:58 AM
02/04/13 10:58 AM
JohnRR
U.S.S.A.
You can fit a 130 tooth wheel in a 143 tooth bell but not the other way so if the starter does not engage the wheel then you have the wrong wheel.
I beg to differ. You can fit a 143 tooth flywheel in a 130 tooth bell. It's when you go to put the starter in and find there is nothing but the back of the flywheel in the opening that you realize you screwed up. DAMHIK.
I put a 513 bell over a 143 tooth wheel, it didn't seem like it would go over without some force , I did expect to see the the starter hole filled with flywheel.
