Removing side glass/mechanism on 70 Charger - Tricks? #1380012
02/02/13 12:19 AM
02/02/13 12:19 AM
Texas
E
ef8Cuda340 Offline OP
E
Texas
I am removing the side/quarter window glass and mechanism on my 70 Charger hardtop so I can see why it doesn't roll up correctly. Are there any tricks I should know when removing/installing before I start removing things blindly.
thanks,
Re: Removing side glass/mechanism on 70 Charger - Tricks? [Re: ef8Cuda340] #1380013
02/02/13 12:23 AM
02/02/13 12:23 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Soak everything with penetrating oil, unbolt the glass first, two small bolts at the junction of the glass & the big plate..... Take pictures so you know which holes the parts go in.... Rollers tend to bind, get all the old lube out & new lube in...
Re: Removing side glass/mechanism on 70 Charger - Tricks? [Re: 1_WILD_RT] #1380014
02/02/13 12:32 AM
02/02/13 12:32 AM
Andrewh Offline
Andrewh  Offline
not just pictures. video.
if you take stuff out and there seems to be a trick to it, video tape yourself doing it.
especially the regulators.
Re: Removing side glass/mechanism on 70 Charger - Tricks? [Re: Andrewh] #1380015
02/02/13 12:51 AM
02/02/13 12:51 AM
Texas
E
E
Texas
thanks, but can't find the video because an advertisement keeps me from going to your link.
Re: Removing side glass/mechanism on 70 Charger - Tricks? [Re: ef8Cuda340] #1380016
02/02/13 01:11 AM
02/02/13 01:11 AM
Andrewh Offline
Andrewh  Offline
I didn't post one.
I was just saying, don't just take pictures when you take it apart. you should video yourself. so you can see how it goes back.
