J 440 HP #1379539
01/31/13 10:37 PM
01/31/13 10:37 PM
salem, oregon. usa
E
elmor Offline OP
elmor  Offline OP
E
salem, oregon. usa
Just bought a 77 pick up with a 440. Checked out the ID pad today and it says J 440 HP. Can anyone tell me some specs on this engine? I am assuming it's a 72 engine, but I don't know if they had 6pak rods or forged steel crank. It does have the small balancer on the front, but did it come that from the factory? I'm not sure when they started using cast cranks.
Re: J 440 HP [Re: elmor] #1379540
02/01/13 01:56 AM
02/01/13 01:56 AM
I think cast cranks started in 74 but some 74's were still steel (6 pack maybe?). Not sure the difference between the 6 pack dampeners & regular steel crank dampeners but I'd say likely a PO had swapped in a good steel crank 440. Good score!. Here's a BTT & others may clarify further. EDIT this jogged my memory & I had a 73 fury cop car that had a six pack rods 440 & it was orange & I think all 70-73 orange 440's had six pack rods. If yours is OE turquoise then very likely you have a regular steel crank 440
Re: J 440 HP [Re: elmor] #1379541
02/01/13 02:02 AM
02/01/13 02:02 AM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Casting date will tell you for sure...
'72 should be steel crank...
346 heads...
Re: J 440 HP [Re: RSNOMO] #1379542
02/01/13 11:34 AM
02/01/13 11:34 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
346 heads...
Casting dates don't tell you what MODEL year the engine would have been originally assembled as since the MODEL year build started in August of the prior year. and an engine would have been cast at least a few weeks before the actual assembling of an engine.
J is 73 , it could be either a forged crank or a cast crank. Look at the dampner . also if the engine has been rebuilt it doesn't really matter what the casting date is or what model year the engine is .
Re: J 440 HP [Re: JohnRR] #1379543
02/01/13 01:14 PM
02/01/13 01:14 PM
dogdays Offline
dogdays  Offline
John's right, the J will tell you everything you need to know. It's a 1973 model year engine. Period.
Now look carefully at the Engine ID pad. If there is the letter "E" stamped anywhere on it, then it originally came with a cast crank.
R.
Re: J 440 HP [Re: dogdays] #1379544
02/01/13 01:18 PM
02/01/13 01:18 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
lower oil pan rail will have a smooth ID pad with partial VIN stamping
Re: J 440 HP [Re: elmor] #1379545
02/01/13 02:58 PM
02/01/13 02:58 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
I'll stand by my original statement...
It was stated that it was assumed the engine was a '72...
The casting date ends that speculation(of the block)...
After 40+ years, we've seen all kinds of things stamped on the pad...
A 'small' dampener would indicate a steel crank...
A tear down ends ALL speculation...
Re: J 440 HP [Re: RSNOMO] #1379546
02/01/13 03:05 PM
02/01/13 03:05 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The key word is ASSuMEd .... if the top pad is stamped with a J from the factory and it has a PARTIAL VIN for a 73 model year car then I stand by my statement ...
