572-13 Heads and Roots Blower #1379406
01/31/13 02:04 PM
01/31/13 02:04 PM
St. Charles, MO.
Slingshot383 Offline OP
St. Charles, MO.
Anybody have any combinations for a big block with 572-13 heads and an 8-71 blower, mechanical fuel injected?
1994 Undercover Chassis 125" altered stack injected big block, soon blown and injected Member of The Torque and Recoil Club
Re: 572-13 Heads and Roots Blower [Re: Slingshot383] #1379407
01/31/13 08:03 PM
01/31/13 08:03 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
We have built a lot of those exact engines for truck pullers. Give me a call tomorrow.
Josh @ Indy
Re: 572-13 Heads and Roots Blower [Re: Slingshot383] #1379408
01/31/13 08:13 PM
01/31/13 08:13 PM
SW WI
cudacustoms1 Offline
SW WI
I have had a 2wd puller with kb block. 4.310 bore/4.15 stroke. 8.4 comp. -13 solid heads. Jensel rockers. indy manifold . 6-71 littlefeild 1 to 1 drive on alky. msd 20 mag. 34* . Dynoed if I remember correctly 1104hp/920ishTQ.
Re: 572-13 Heads and Roots Blower [Re: cudacustoms1] #1379409
02/01/13 02:04 PM
02/01/13 02:04 PM
St. Charles, MO.
St. Charles, MO.
I have a Mega block, the 572-13 heads, a Mallory III mag., blower and which injection unit is undecided as yet. Looking for a reliable build that doesn't have to be on Kill all the time to run.
Re: 572-13 Heads and Roots Blower [Re: Slingshot383] #1379410
02/01/13 11:09 PM
02/01/13 11:09 PM
SW WI
SW WI
We started out with a supermag. What is your plans for blower,drive ratio, fuel system etc. Our build was for a very specific class with some very weird rules.The littlefeild blower we had was new from littlefeild. It was standard helix with a parker bottom and 9.5" top.It would make 14-15lbs of boost @8000rpm's. Bird hat w/ 80a pump. Fuel only injected thru hat no port nozzles (class rules). This one thing that I will warn you of we had alot of trouble withthe front cyls running hot and the back dead cold. Jetting if I remember right was 68's in the front and 29's in the back with very little heat in the back. We found that if you turn the manifold backwards it helped We couldn't run a set back deal. It's not real hard to do.If you have any more questions I would be glad to talk to you and try to help.PM me your number. Good luck
Re: 572-13 Heads and Roots Blower [Re: cudacustoms1] #1379411
02/02/13 12:08 AM
02/02/13 12:08 AM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
you should have run different compression ratios in the different cylinders
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: 572-13 Heads and Roots Blower [Re: bigtimeauto] #1379412
02/02/13 12:12 AM
02/02/13 12:12 AM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
What blower manifold are you running.
Re: 572-13 Heads and Roots Blower [Re: bigtimeauto] #1379413
02/02/13 08:08 AM
02/02/13 08:08 AM
SW WI
SW WI
The compresion was 8.4 to 1.Class rule was 8.5. we didn't want to give up to much because we had to run heads up against better brand X heads.We don't have anywhere near as much split in jetting in my BAE motor but that is a completely different deal.
Re: 572-13 Heads and Roots Blower [Re: cudacustoms1] #1379414
02/02/13 11:49 AM
02/02/13 11:49 AM
St. Charles, MO.
St. Charles, MO.
Indy intake, will run port nozzles for main fuel, hat just mainly for cooling the blower. Up in the air for injector, Enderly hat is most popular, but a Hilborn 4-port or a Crower 8-port, or even a pair of Ron's Terminators with a scoop would work. I ran a pair of Ron's 4-Shooters on a tunnel ram years ago and they worked great.
Re: 572-13 Heads and Roots Blower [Re: Slingshot383] #1379415
02/05/13 02:07 PM
02/05/13 02:07 PM
St. Charles, MO.
St. Charles, MO.
So, is everybody running a blower on a Wedge engine pullers? No drag racers? Is it that much different from a hemi application?
Re: 572-13 Heads and Roots Blower [Re: Slingshot383] #1379416
02/05/13 02:25 PM
02/05/13 02:25 PM
Franklin, TN
23T Hemmee Offline
23T Hemmee  Offline
Franklin, TN
Hey Larry,
Isn't John Umlauf from up in your part of the country? He's run some 6.90's with a 451 with either 440-1's or 572's in his front-motored dragster. Larry Grenko has run some high 7's with the "Moparius Maximus" full-bodied '63, think they're both running conventional 8-71's with no setback. This is just what your altered needs, jump on in, the water's fine, gimme a call........
Ronny
6.789 @ 198.63 **.956 Brand New 60'***
4.17@ 169 1/8th mile
John 14:6
https://www.youtube.com/watch?v=TUku_hjYRh8
Re: 572-13 Heads and Roots Blower [Re: Slingshot383] #1379417
02/05/13 03:46 PM
02/05/13 03:46 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
Here’s a mild 505 with -1's on a 74 400 block. this just came off my dyno, he was having "fuel" issues with just putting it all into the hat. Added port nozzles and now all cylinders are happy. I think he’s running 4% over, like I said a mild 1250hp setup that he drives to and from the lanes.
http://www.youtube.com/watch?v=ovIVAIrOj24
Joe
Without Data, you’re just another guy with an opinion.
Re: 572-13 Heads and Roots Blower [Re: sr4440] #1379418
02/07/13 12:01 AM
02/07/13 12:01 AM
St. Charles, MO.
St. Charles, MO.
Ronnie, going to talk to John tomorrow, found Larry, will talk to him later. Check your PM.
