Page 2 of 3 1 2 3
transbrake=wheelstand "UPDATE" [Re: 416challenger] #1379323
02/16/13 01:31 AM
02/16/13 01:31 AM
New Braunfels, TX
416challenger Offline OP
New Braunfels, TX
Well I was finally able to get back out to the track. I really did not have any where that I could check to see were the converter was flashing to. I did pull the chip out out the low side on the 2 step and the converter went to 4800 on the trans brake. The only chip I found close to that was 4100, so I installed it and tried it. It just made the wheelstand worse. It actually went on the rear bumper. It caught me off guard and I lifted instead of shifting, as it was still climbing. It came down kind of hard and dented the pan a little.
https://www.youtube.com/watch?v=U1N066LYGyQ
I played with the launch RPM and ended on 2500 rpms. The car left good, but is pulling to the right. I added some preload to the passenger side, but when I went to make another pass I noticed I now have a water leak at the radiator. I guess when I came down it twisted the radiator a little. I will try to find a shop to repair it and head back out on Sunday.
https://www.youtube.com/watch?v=TkidPFOvDyU
Re: transbrake=wheelstand "UPDATE" [Re: 416challenger] #1379324
02/16/13 05:42 AM
02/16/13 05:42 AM
Q
Quicktree Offline
Quicktree  Offline
Q
you have the same problem I do, you better put some wheelie bars on that thing while your trying to figure it out.
Re: transbrake=wheelstand "UPDATE" [Re: Quicktree] #1379325
02/16/13 12:46 PM
02/16/13 12:46 PM
gregsdart Offline
gregsdart  Offline
Add the longest wheelie bars you can and still get the car in the trailer and test till it looks like it is working well. Then shift weight forward (if the car isn't repeating like a machine)till the car is as consistent as it can get. Go win races.
Re: transbrake=wheelstand "UPDATE" [Re: 416challenger] #1379326
02/16/13 03:24 PM
02/16/13 03:24 PM
Leave the chip out and try that with your foot on the floor when the first light comes on
Re: transbrake=wheelstand "UPDATE" [Re: Cab_Burge] #1379327
02/16/13 03:31 PM
02/16/13 03:31 PM
Renton Washington
Triple Threat Offline
Renton Washington
I 100% disagree. Higher launch RPM 99% of the time is going to result in a more aggressive launch aka bigger wheel stand. This theory people say about leaving against the converter so it doesn't "flash" has never held true with anything I've seen. I've tried it many times in different cars with the same result.
Keep the RPM low. And fix the turning right issue (add pre load).
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: transbrake=wheelstand "UPDATE" [Re: Triple Threat] #1379328
02/16/13 03:34 PM
02/16/13 03:34 PM
different cars with different suspension and converters have different results
Re: transbrake=wheelstand "UPDATE" [Re: Cab_Burge] #1379329
02/16/13 03:41 PM
02/16/13 03:41 PM
Renton Washington
Renton Washington
Does this work in your car Cab? Leaving against the converter at 4-5000 where ever it maybe is a softer launch than at 2500?
-Dustin
Re: transbrake=wheelstand "UPDATE" [Re: Cab_Burge] #1379330
02/16/13 03:41 PM
02/16/13 03:41 PM
Stockholm, Sweden
MrSixpack Offline
MrSixpack  Offline
Stockholm, Sweden
Why not try to footbrake?
I did that with my car and I dropped from 1,38 to 1,32 in 60 feet and much lower wheelies.
And the best buy I did for my combo was Afco dual adj. shocks.
Good Luck
1970 Super Stock Challenger ex. Paul Rossi
1968 Dodge Dart GT 340
1968 Dodge Charger /6 3 speed manual
1966 Chrysler 300 Loaded
1968 Dodge Charger R/T 440
1968 Mini Cooper
Re: transbrake=wheelstand "UPDATE" [Re: Cab_Burge] #1379331
02/16/13 03:43 PM
02/16/13 03:43 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
In the video in the beginning of this post the car went to the left, and now to the right. Did you make a chassis change between races. If not you better start making sure tire pressure is the same right and left, check track prep and car alignment, or see if the driver is some how doing it. PLEASE don't take this personal but when a car leaves the line like that you better learn not to get back in the throttle because either you are going to wreck the car, do engine damage, or maybe DAD with take over driving HIS car again. Its not worth it.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: transbrake=wheelstand "UPDATE" [Re: Triple Threat] #1379332
02/16/13 03:49 PM
02/16/13 03:49 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
Triple threat, I tried that with my dart. 51% of my car weight is on the front, 49% rear. My wheelie bars are set at 2 inches off the ground. If I flash my converter, i'm hard on the wheelie bars, but when I load it up on the stall, it doesn't hit the bars as hard.
I'm not sure if it's because of the limiters I have on my front suspension maybe, after a couple of inches of rise, my car has to pick up the whole front end. but what you are saying isnt always true. I even put max adjustment on my bars to see, and it was the same. This may all change with his shorter wheel base tho.
Re: transbrake=wheelstand "UPDATE" [Re: Mopar-Al] #1379333
02/16/13 04:49 PM
02/16/13 04:49 PM
Renton Washington
Renton Washington
Fair enough, but I still don't see going up being a good idea as he already went up to near the stall point and it made it worse. The car obviously has other issues, it needs to go straight regardless of how high the wheels are in the air.
Re: transbrake=wheelstand "UPDATE" [Re: Triple Threat] #1379334
02/16/13 06:54 PM
02/16/13 06:54 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
Yeah, but he has a lot of adjustments he needs to do, to get it dialed in. My 72 cuda used to do 2 ft tall wheelies. Some liked it, I didn't. It was a 3800 lb car running 9.85-9.92's no bars, we went back to the shop and made a some corrections for the IC and got it to where it did no wheelies and ran the same times, with a 9.82 best run. 5500 0n the stall and transbrake.
Re: transbrake=wheelstand "UPDATE" [Re: Triple Threat] #1379335
02/16/13 09:26 PM
02/16/13 09:26 PM
It works on all the foot brake cars I've raced BUT, I haven't raced a trans brake car in a lot of years, soon to change sometimes you have to go the wrong way on testing to find out which way the wrong way is Never rule out trying something old on a new problem, what works on one car usually work again in a similar situation
Re: transbrake=wheelstand "UPDATE" [Re: Triple Threat] #1379336
02/16/13 11:08 PM
02/16/13 11:08 PM
Q
Quicktree Offline
Quicktree  Offline
Q
I am going to do some testing with rpm launches, I am going to go out on a limb and agree with you before hand.
Re: transbrake=wheelstand "UPDATE" [Re: Triple Threat] #1379337
02/16/13 11:41 PM
02/16/13 11:41 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Works on my car but I have to vary the tire pressure
to work on different tracks... a 1/4 psi to 1/2 psi
to control the lift and get the tire speed to what
I want.... I leave on the conv all the time... but
Tony might have to move the IC back to keep the front
down
NOTE
the pic in my sig is for pics not the way it leaves
on the normal basis
EDIT
even here I needed more air.. I was a 1/4 psi low
Re: transbrake=wheelstand "UPDATE" [Re: Triple Threat] #1379338
02/16/13 11:58 PM
02/16/13 11:58 PM
California, USA!!!
W
WheelsUp73 Offline
WheelsUp73  Offline
W
California, USA!!!
I agree with ya, My car has pulled a few hundred big wheelies and I can tell you that the higher the launch RPM the harder it gets up on the bumper.
Re: transbrake=wheelstand "UPDATE" [Re: MR_P_BODY] #1379339
02/17/13 12:05 AM
02/17/13 12:05 AM
Q
Quicktree Offline
Quicktree  Offline
Q
down
NOTE
on the normal basis
EDIT
what do you mean move it back?
Re: transbrake=wheelstand "UPDATE" [Re: MR_P_BODY] #1379340
02/17/13 12:06 AM
02/17/13 12:06 AM
Q
Quicktree Offline
Quicktree  Offline
Q
down
NOTE
on the normal basis
EDIT
Re: transbrake=wheelstand "UPDATE" [Re: Quicktree] #1379341
02/17/13 12:08 AM
02/17/13 12:08 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Shorten your IC on the 4 link(shorter and lower)
Re: transbrake=wheelstand "UPDATE" [Re: MR_P_BODY] #1379342
02/17/13 12:25 AM
02/17/13 12:25 AM
Q
Quicktree Offline
Quicktree  Offline
Q
heck thats the opposite of what i have been told.
Page 2 of 3 1 2 3
