transbrake=wheelstand "UPDATE"
[Re: 416challenger]
#1379323
02/16/13 01:31 AM
02/16/13 01:31 AM
Posts: 415 New Braunfels, TX
416challenger
New Braunfels, TX
Well I was finally able to get back out to the track. I really did not have any where that I could check to see were the converter was flashing to. I did pull the chip out out the low side on the 2 step and the converter went to 4800 on the trans brake. The only chip I found close to that was 4100, so I installed it and tried it. It just made the wheelstand worse. It actually went on the rear bumper. It caught me off guard and I lifted instead of shifting, as it was still climbing. It came down kind of hard and dented the pan a little. https://www.youtube.com/watch?v=U1N066LYGyQ I played with the launch RPM and ended on 2500 rpms. The car left good, but is pulling to the right. I added some preload to the passenger side, but when I went to make another pass I noticed I now have a water leak at the radiator. I guess when I came down it twisted the radiator a little. I will try to find a shop to repair it and head back out on Sunday. https://www.youtube.com/watch?v=TkidPFOvDyU
Re: transbrake=wheelstand "UPDATE"
[Re: Cab_Burge]
#1379330
02/16/13 03:41 PM
02/16/13 03:41 PM
Posts: 952 Stockholm, Sweden
MrSixpack
Stockholm, Sweden
Why not try to footbrake? I did that with my car and I dropped from 1,38 to 1,32 in 60 feet and much lower wheelies. And the best buy I did for my combo was Afco dual adj. shocks. Good Luck
1970 Super Stock Challenger ex. Paul Rossi 1968 Dodge Dart GT 340 1968 Dodge Charger /6 3 speed manual 1966 Chrysler 300 Loaded 1968 Dodge Charger R/T 440
1968 Mini Cooper
[Re: Triple Threat]
#1379332
02/16/13 03:49 PM
02/16/13 03:49 PM
Posts: 6,780 Alabama
Mopar-Al
Alabama
Triple threat, I tried that with my dart. 51% of my car weight is on the front, 49% rear. My wheelie bars are set at 2 inches off the ground. If I flash my converter, i'm hard on the wheelie bars, but when I load it up on the stall, it doesn't hit the bars as hard.
I'm not sure if it's because of the limiters I have on my front suspension maybe, after a couple of inches of rise, my car has to pick up the whole front end. but what you are saying isnt always true. I even put max adjustment on my bars to see, and it was the same. This may all change with his shorter wheel base tho.
[Re: Triple Threat]
#1379336
02/16/13 11:08 PM
02/16/13 11:08 PM
Quicktree
Leave the chip out and try that with your foot on the floor when the first light comes on
I 100% disagree. Higher launch RPM 99% of the time is going to result in a more aggressive launch aka bigger wheel stand. This theory people say about leaving against the converter so it doesn't "flash" has never held true with anything I've seen. I've tried it many times in different cars with the same result.
Keep the RPM low. And fix the turning right issue (add pre load).
I am going to do some testing with rpm launches, I am going to go out on a limb and agree with you before hand.
[Re: Triple Threat]
#1379338
02/16/13 11:58 PM
02/16/13 11:58 PM
Posts: 369 California, USA!!!
WheelsUp73
California, USA!!!
I agree with ya, My car has pulled a few hundred big wheelies and I can tell you that the higher the launch RPM the harder it gets up on the bumper.
[Re: MR_P_BODY]
#1379339
02/17/13 12:05 AM
02/17/13 12:05 AM
Quicktree
Does this work in your car Cab? Leaving against the converter at 4-5000 where ever it maybe is a softer launch than at 2500?
Works on my car but I have to vary the tire pressure to work on different tracks... a 1/4 psi to 1/2 psi to control the lift and get the tire speed to what I want.... I leave on the conv all the time... but Tony might have to move the IC back to keep the front down NOTE the pic in my sig is for pics not the way it leaves on the normal basis EDIT even here I needed more air.. I was a 1/4 psi low
what do you mean move it back?
[Re: MR_P_BODY]
#1379340
02/17/13 12:06 AM
02/17/13 12:06 AM
Quicktree
[Re: MR_P_BODY]
#1379342
02/17/13 12:25 AM
02/17/13 12:25 AM
Quicktree
Shorten your IC on the 4 link(shorter and lower)
heck thats the opposite of what i have been told.
