main studs #1379166
01/31/13 02:13 AM
01/31/13 02:13 AM
bc canada
67valiant Offline OP
bc canada
looking at putting in some arp main studs in my sbm should i get it align honed or ?
Re: main studs [Re: 67valiant] #1379167
01/31/13 03:10 AM
01/31/13 03:10 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Conventional wisdom says yes. If you have a bore guage, I suppose you can check the saddles for true and round. I still think its best to have it honed. If something were distorted in the mainline, you could lose a main bearing and thus, your entire motor. Just not worth the risk in my mind.
Re: main studs [Re: 67valiant] #1379168
01/31/13 03:56 AM
01/31/13 03:56 AM
The studs will pull the threads in the block all the way to the bottom of the studs, not the top three or four threads like the bolts do Bottom line is if there is any doubts in your mind on the need to do it, do it and don't look back If you can take it, the block, to a good machine shop that has a decent dial bore gauge try torquing the main bolts down with no bearings in them and measure the bores for size and out of round, do all of them and write the results down and then remove the bolts and put the studs in and remeasure the bores. If there is more than .0002 differences go ahead and have it line honed, way better to be safe than sorry
Re: main studs [Re: 67valiant] #1379169
01/31/13 01:16 PM
01/31/13 01:16 PM
organ
maximum entropy Offline
organ
check it with a dial bore gauge. sometimes they need to be line honed, sometimes not. always check, though.
Re: main studs [Re: maximum entropy] #1379170
02/01/13 01:43 AM
02/01/13 01:43 AM
bc canada
bc canada
thanks for the help guys
Re: main studs [Re: Cab_Burge] #1379171
02/02/13 01:40 AM
02/02/13 01:40 AM
lindstrom , mn
jerry69gtx Offline
jerry69gtx  Offline
lindstrom , mn
excelent i have a bore gauge and i have put studs in multiple motors & makes checked with bore gauge and every time no matter what make they need at minimal line honing i applaude your resonse!
