Page 1 of 3 1 2 3
A-833 overdrive won't shift 543 stroker #1379124
01/31/13 01:55 AM
01/31/13 01:55 AM
Minnesota
Shawnb Offline OP
Shawnb  Offline OP
Minnesota
I have a 69 Super Bee with a 543 stroker 715 ft lb torque, 410 gears, a-833 overdrive 4 speed trans. I burned thru the 1st 500 hp clutch in a week or so. Swapped to a McLeod twin disc clutch system. The problem is with 2 different transmissions it is very hard to shift from 1-2. The reason I use the a-833 23 spline overdrive from I believe a mid 70's 2 wheel drive truck is with the hemi 4 speed and 410 gears it screams 3800 down the freeway. I don't race the car other than on the street. I need to be able to take it on the freeway and hate driving in the slow lane. The trans itself seeme to hold up to the torque ok but still a very difficult 1-2 shift. I was told the reason this happens to the overdrive and not the hemi 4 speed is because the difference in 1-2 gear ratios in the overdrive is much larger. I've looked up the specs and it is larger. What can I do? I'd hate to switch to the hemi 4 speed because the McLeod twin disc 23 spline set up was expensive and holds great. Is there a gear set for the overdrive that is closer ratios in 1-2-3 and a bigger gap to overdrive? I can do most of the street driving I want to do in 1-2-3 anyways. Any ideas? Thanks in advance......
Re: A-833 overdrive won't shift 543 stroker [Re: Shawnb] #1379125
01/31/13 02:11 AM
01/31/13 02:11 AM
The problem is with 2 different transmissions it is very hard to shift from 1-2. Any ideas?
I'm not a stick guy so take this with a grain of salt but I'd think shifting difficulties would be unrelated to the gear ratio per se but more likely to be 2 worn OD 4 speeds in a row (synchros?)
Re: A-833 overdrive won't shift 543 stroker [Re: Shawnb] #1379126
01/31/13 04:02 AM
01/31/13 04:02 AM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
The issue may be worn parts, but consider this - the O/D trans drops the engine RPM around 1000 more on the 1-2 shift than a Hemi box. That means the syncros/blockers have to slow the countershaft, input shaft, and now 2 clutch discs that much more to match the output shafts speed to make the 1-2 shift. I would think the extra load on the syncros and blocker rings would result in both a slower shift and more wear and tear on the parts.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: A-833 overdrive won't shift 543 stroker [Re: Evil Spirit] #1379127
01/31/13 04:52 AM
01/31/13 04:52 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Those things were a pain to shift fast even when they were new.
The only way we could get the one in my buddy's 76 R/T to shift was to adjust the clutch so it had barely any free play. This gave the clutch maximum disengagement so the synchro could do its thing. The trans didn't crash, it just flat would not go past neutral on a power shift and it would hang just shifting fast if you didn't smash the clutch right into the rug.
Are you running 90wt or ATF in it? I would try ATF if it doesn't already have it in there. Also don't use synthetic oil in it. Synchros need metal to metal contact to work and there is nothing better than synthetic oil to prevent this.
Kevin
Re: A-833 overdrive won't shift 543 stroker [Re: Twostick] #1379128
01/31/13 11:52 AM
01/31/13 11:52 AM
Ohio
Dan Brewer Offline
Dan Brewer  Offline
Ohio
McLeod can re-hub your discs for the 18 spline. Put your 18 spline back in, change the D60 to 3.54 and run a 28-9" tall tire.
I'm sure a 4.10 with a 3.09 low gear trans 1st gear doesn't last long.
A833 4-speeds, parts & services
http://www.brewersperformance.com/
Re: A-833 overdrive won't shift 543 stroker [Re: Twostick] #1379129
01/31/13 11:52 AM
01/31/13 11:52 AM
Philadelphia
radar Offline
radar  Offline
Philadelphia
Did you try double clutching it?
Re: A-833 overdrive won't shift 543 stroker [Re: radar] #1379130
01/31/13 12:27 PM
01/31/13 12:27 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
No problems here. I can speed shift my OD833 just as fast as any other 4 speed.
What condition is your shifter in? Im changing mine from the factory 1 to a barely used Comp Plus I recently picked up.
I am truckless..
Re: A-833 overdrive won't shift 543 stroker [Re: Dan Brewer] #1379131
01/31/13 12:30 PM
01/31/13 12:30 PM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
I would listen to this guy! He knows his stuff. Or call him. He can put you where you need to be .
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: A-833 overdrive won't shift 543 stroker [Re: radar] #1379132
01/31/13 12:37 PM
01/31/13 12:37 PM
Minnesota
Shawnb Offline OP
Shawnb  Offline OP
Minnesota
First thanks for the help trying to figure out a solution. To answer your questions I think it has 80w90 in it. I dont think the problem is worn parts in the overdrive. One of my 2 transmissions is new rebuilt and all new parts, the other is uesd. It has the same problem with both. With each unit removed the syncros look good. To evil spirit, ive been told by a local guy the exact thing you stated. The trans drops the engine down 1000 more RPM on the overdrive A833 and the syncros have to slow the input shaft that much more. To add to that now I have to slow 2 clutch discs rather than 1. I will do a lot of freeway driving and I like the fact I can do that now @ 2800 rpm. One response asked what the problem is. Its after 1st gear @ 5500 rpm I depress the clutch all the way to shift and the shifter will not pull down to 2nd. If I wait and wait and keep pulling it will a go into 2nd few seconds later. That does me no good in a street race though. I was told that I need closer ratios than I have in 1-2-3 and this wont happen. Is that true? And if so how do I do that?
Re: A-833 overdrive won't shift 543 stroker [Re: Shawnb] #1379133
01/31/13 12:44 PM
01/31/13 12:44 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
First thanks for the help trying to figure out a solution. To answer your questions I think it has 80w90 in it. I dont think the problem is worn parts in the overdrive. One of my 2 transmissions is new rebuilt and all new parts, the other is uesd. It has the same problem with both. With each unit removed the syncros look good. To evil spirit, ive been told by a local guy the exact thing you stated. The trans drops the engine down 1000 more RPM on the overdrive A833 and the syncros have to slow the input shaft that much more. To add to that now I have to slow 2 clutch discs rather than 1. To rapidfire64 you said put your 18 spline Hemi 4 speed back in and "change the D60 to 3.54"?????? You mean change a gear? Can I do that? I do have 29" rear tires. I will do a lot of freeway driving and I like the fact I can do that now @ 2800 rpm. One response asked what the problem is. Its after 1st gear @ 5500 rpm I depress the clutch all the way to shift and the shifter will not pull down to 2nd. If I wait and wait and keep pulling it will a go into 2nd few seconds later. That does me no good in a street race though. I was told that I need closer ratios than I have in 1-2-3 and this wont happen. Is that true? And if so how do I do that?
Passon sells an OD gear set with gear splits like a 727, but it's an 18 spline input shaft and about $2k. Is your OD in an alum case ?
you are asking a lot from that OD trans , I'm surprised it hasn't scattered yet.
Street racing
Re: A-833 overdrive won't shift 543 stroker [Re: JohnRR] #1379134
01/31/13 01:01 PM
01/31/13 01:01 PM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
Re: A-833 overdrive won't shift 543 stroker [Re: JohnRR] #1379135
01/31/13 01:03 PM
01/31/13 01:03 PM
Minnesota
Shawnb Offline OP
Shawnb  Offline OP
Minnesota
Im a bit surprised it didnt explode yet too. The M/T street slick tires bite too. We ponuded te hell out of it last summer. Enough to ruine the 1st clutch set. That overdrive is stronger than you would think. $2k is just for the Hemi 4 speed gear set? Could the problem be with the fluid or adjustment? Is there anything I can try with the set up I have now?
Re: A-833 overdrive won't shift 543 stroker [Re: OhioMopar] #1379136
01/31/13 01:10 PM
01/31/13 01:10 PM
Minnesota
Shawnb Offline OP
Shawnb  Offline OP
Minnesota
Thats a cool video. It looks a lot like mine. My rear tires are a bit bigger and my A12 Bee has side scoops. Otherwise it looks the same.
Re: A-833 overdrive won't shift 543 stroker [Re: Shawnb] #1379137
01/31/13 01:13 PM
01/31/13 01:13 PM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
Wasn't sure if you added some rubber and scoops! Sorry to hijack. Nice car. Good luck!
Re: A-833 overdrive won't shift 543 stroker *DELETED* [Re: Shawnb] #1379138
01/31/13 01:32 PM
01/31/13 01:32 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Post deleted by Grizzly
Mo' Farts
Moderated by "tbagger".
Re: A-833 overdrive won't shift 543 stroker [Re: Grizzly] #1379139
01/31/13 02:02 PM
01/31/13 02:02 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
All the OD833s I have seen run ATF in them..
I am truckless..
Re: A-833 overdrive won't shift 543 stroker [Re: JohnRR] #1379140
01/31/13 02:04 PM
01/31/13 02:04 PM
AZ.
696pack Offline
696pack  Offline
AZ.
Street racing
John is correct. The old Chrysler 4 speed ODs were not intended to be a racer's trans they were built for people that wanted better mileage. It is NOT the trans you want behind a big cube engine that you are trying to bang gears in. It is just a matter of short time before you scatter it.
Re: A-833 overdrive won't shift 543 stroker [Re: 696pack] #1379141
01/31/13 03:44 PM
01/31/13 03:44 PM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
just a thought. Try and adjust the pressure plate to disengage the clutch discs more. The maybe still grabbing enough to keep the input spinning. You need at least .060 or so to keep things happy, use a feeler gauge between the disc or in your case discs to see how much clearence you have. But as others have said that OD is on borrowed time.
With 29" tires 4:10s and the 18-spline 55mph should be around 3300RPM.... Put the 3:54s in it that thing has a TON of torque!!!!! You wont need the OD then... Good luck
I want to add also make absolutely sure the gear oil in the trans is GL-4 rated not the newer GL-5 Stuff!!!! Gl-5 rated has too many friction modifiers in it and it doesnt let the synrco grab the gear effectively causing lazy shifts and grinding. ATF may work for you too as others have used it but I am sticking with my guns of GL-4 rated 80-90wt. It may be tougher to find the Gl-4 stuff but it is out there still...
Re: A-833 overdrive won't shift 543 stroker [Re: Shawnb] #1379142
01/31/13 04:53 PM
01/31/13 04:53 PM
Mopar had a lot of complaints on the shifting of the stock NP833 when they first came out way back when, change the fluid and run straight Type F ATF, non synthetic Call Mcleod and ask them how much clearance(free play) you should have between the clutch discs and the flywheel, floaters,with a feeler gauge, set that clearnce up and see if it shifts better
Re: A-833 overdrive won't shift 543 stroker [Re: Cab_Burge] #1379143
01/31/13 06:24 PM
01/31/13 06:24 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Did you put the guts into an iron case or did you have the aluminum case bushed? The aluminum case is a weak spot in those OD transmissions. The counter shaft wallows open the hole in the case that it rides in, eventually resulting in poor gear mesh. However if that was the case here I think you'd see rough, grinding shifting all the time.
Page 1 of 3 1 2 3
