74 amc hornet, 440 #1379075
01/31/13 01:43 AM
01/31/13 01:43 AM
california
hornetnut Offline OP
california
i thought i would post some pics of my progress, i started swapping out my amc powerplant for a 440 in 2010, it took me a couple of years to gather up all my mopar buddies leftover parts, ended up with a really good combo
67 440 block, 030 lightweight forged pistons, steel rods and crank, ultradyne 582 lift solid cam, eddy performer rpm alum heads that have some work done on em, procomp roller rocker setup, 3500 converter, 727,
car has had a 9in in it for ten years, 4.11 gears,
it was a lil tricky to get it to fit but not too bad,
Re: 74 amc hornet, 440 [Re: hornetnut] #1379076
01/31/13 01:52 AM
01/31/13 01:52 AM
california
california
Re: 74 amc hornet, 440 [Re: hornetnut] #1379077
01/31/13 01:55 AM
01/31/13 01:55 AM
california
california
Re: 74 amc hornet, 440 [Re: hornetnut] #1379078
01/31/13 11:17 PM
01/31/13 11:17 PM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
Nice work looks nice, sounds great too. I like how lil man ran right over as you went for the car. Good job on all counts
Re: 74 amc hornet, 440 [Re: UCUDANT] #1379079
01/31/13 11:24 PM
01/31/13 11:24 PM
Louisiana
rnch Offline
rnch  Offline
Louisiana
looks like it grew there!
Re: 74 amc hornet, 440 [Re: rnch] #1379080
01/31/13 11:51 PM
01/31/13 11:51 PM
ON, Canada
AMC400Mopar Offline
AMC400Mopar  Offline
ON, Canada
Very cool project! It looks like the 440RB fit in your engine compartment pretty nicely. The 400B in our '74 Javelin actually looks a little tighter between the shock towers than your 440 does in your car. The factory Mopar exhaust manifolds on our Javelin are very close to the shock towers and the steering shaft.
I wonder what the difference in engine compartment width dimensions actually is between the Javelin and the Hornet, or if the difference is in the height of your RB engine and/or motor mounts?
In any case I'll post some pics of the 400 in our Javelin as soon as it's back in; right now our engine is on the stand to get freshened and hopped up.
It'd be interesting to compare notes on our AMC/big block Mopar hybrids as they come together!
Re: 74 amc hornet, 440 [Re: AMC400Mopar] #1379081
02/01/13 01:25 AM
02/01/13 01:25 AM
california
california
close isnt even the word for it...lol... ill post some closer pics of the header clearance, or the lack of...
i built the mounts as low profile as i could and tried to get the engine as low as i could to try and fit it under the hood, but i had to cut the hood anyway, plus i think the hemi scoop is awesome....
Re: 74 amc hornet, 440 [Re: hornetnut] #1379082
02/01/13 01:28 AM
02/01/13 01:28 AM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
Looks good! How much work were the headers?
Re: 74 amc hornet, 440 [Re: 446acuda] #1379083
02/01/13 12:22 PM
02/01/13 12:22 PM
ON, Canada
AMC400Mopar Offline
AMC400Mopar  Offline
ON, Canada
Hornet said it, there is almost no room for headers. The center ports of our stock 400 log style manifolds on our Jav are only an inch or so from the shock towers.
I wonder if upswept HP manifolds would fit better and at least not waste as much power as the log manifolds do? Or headers with the center ports going up and over the shock towers...
I drew a crummy sketch to show what I am thinking about, maybe it will inspire someone with a good idea! We are going to swap to a manual brake master cylinder as well to give us a little more room.
Hood clearance is tight too. With the stock intake, Holley carb and a 3" air cleaner we just about touch the bottom of the hood. I'll need to get out the sawzall to install an aftermarket aluminum intake for sure.
Re: 74 amc hornet, 440 [Re: AMC400Mopar] #1379084
02/01/13 05:15 PM
02/01/13 05:15 PM
california
california
i used b-body headers and the pass side bolted right in, had to reroute two tubes for the driver side.. also had to remove the strut rod brackets and relocated them, but well worth the work imho....
manual brakes was a must for room, plus the blower motor and heater core had to be removed as well... the prices we pay for fun huh....
Re: 74 amc hornet, 440 [Re: hornetnut] #1379085
02/01/13 07:40 PM
02/01/13 07:40 PM
ON, Canada
AMC400Mopar Offline
AMC400Mopar  Offline
ON, Canada
Excellent! Can you show some pics of the header routing and the mods you had to do on the drivers side? What make and model B Body headers did you use?
Re: 74 amc hornet, 440 [Re: AMC400Mopar] #1379086
02/02/13 06:38 AM
02/02/13 06:38 AM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
Did you use a truck pan? Can't really tell, but the dipstick in the pan made me think truck. Looks like a cool conversion.
I had a Jeep pickup I always wanted to put a 440 in when I was a new driver. Dad wasn't having any of it...
Edit: I saw your post in the Javelin thread and see that it is a truck pan. Never mind!
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: 74 amc hornet, 440 [Re: hornetnut] #1379087
02/02/13 03:08 PM
02/02/13 03:08 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
Wow...it sure sounds good. I just knew the little dog was gonna run over and pee on the camera when you set it down...lol.
Re: 74 amc hornet, 440 [Re: JDMopar] #1379088
02/02/13 06:26 PM
02/02/13 06:26 PM
california
california
Re: 74 amc hornet, 440 [Re: hornetnut] #1379089
02/03/13 12:53 PM
02/03/13 12:53 PM
ON, Canada
AMC400Mopar Offline
AMC400Mopar  Offline
ON, Canada
Nice! Looks like you cut the front cylinder pipe on the driver's side so you could twist it a little to get it to clear the steering shaft?
Re: 74 amc hornet, 440 [Re: JDMopar] #1379090
02/03/13 03:49 PM
02/03/13 03:49 PM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
I thought he was too
Re: 74 amc hornet, 440 [Re: AMC400Mopar] #1379091
02/03/13 08:10 PM
02/03/13 08:10 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
From looking at the pictures, I think you AMC guys have more room with the 400/440 than I do with a 440 in my '68 Valiant!!!
If you like drag racing, support your local track.
Re: 74 amc hornet, 440 [Re: CHAPPER] #1379092
02/12/13 04:47 AM
02/12/13 04:47 AM
california
california
lol.. yea it does seem more roomy than in an a-body, but bolt on parts are made for yours, i have to fab everything for the amc...but well worth it
Re: 74 amc hornet, 440 [Re: hornetnut] #1379093
02/13/13 07:01 PM
02/13/13 07:01 PM
NEW JERSEY
dynamite Offline
dynamite  Offline
NEW JERSEY
Cool car..we just picked up a 1976 Matador.was a good running AMC 360 4 bbl...We are in the process of installing a 512 stroker we now have in it ..I starting to make a fiber glass hood for it now.. No pics yet but soon
Re: 74 amc hornet, 440 [Re: dynamite] #1379094
02/15/13 12:33 PM
02/15/13 12:33 PM
california
california
matadors are cool..., i started driving my hornet on saturday, drove around town a lil, and then drove it to work tues and weds, def gets a lot of attention, most people hear it before they see it, im loving this monster 440...... cam seems a lil large for the street but its still drivable so its stayin...lol
