I have Zero line pressure #1378998
01/31/13 12:56 AM
01/31/13 12:56 AM
NE MISSOURI
P
Purpleracer Offline OP
P
NE MISSOURI
I hook a pressure gauge up to the line pressure tap and I am getting zero lbs. Using the same gauge on the rear servo tap I have 150 lbs. It is a 727 with Griner brake .
Re: I have Zero line pressure [Re: Purpleracer] #1378999
01/31/13 01:03 AM
01/31/13 01:03 AM
Portsmouth, VA
DusterW2 Offline
DusterW2  Offline
Portsmouth, VA
Griner VB does not use the center (accumulator piston) tap. Use the rear servo or front servo for pressure readings. Rear in reverse or 1st if a 22G20B (low band apply) brake. Front servo tap in 3rd.
Pressure reading could be anywhere between 140-220 psi. Normal range is 165-180 psi.
John
Re: I have Zero line pressure [Re: DusterW2] #1379000
01/31/13 05:48 PM
01/31/13 05:48 PM
NE MISSOURI
P
P
NE MISSOURI
