Re: good quality/affordable steel crank for my 440?
[Re: 78asprin]
#1378956
01/31/13 12:26 AM
01/31/13 12:26 AM
RapidRobert
On occaision I see em on here for $100-125 (plus the ride). I wouldn't have the slightest hesitation about using one
[Re: AndyF]
#1378959
01/31/13 03:26 AM
01/31/13 03:26 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
The 413 crank in my 451 was sourced on craigslist. I see them on ebay now & then also.
[Re: 78asprin]
#1378960
01/31/13 05:35 AM
01/31/13 05:35 AM
Posts: 6,566 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
I'm in the market for a steel crank for my 440 I'm putting together, its a 450-475hp aluminum headed street/strip toy. Trying to find a steel crank motor for a donor crank is damn near impossible around here lol. I was looking at ohio crank, they have a 4340 crank for under 600, any suggestions on one for this build? I'm trying to keep the cost down on the build but definitely dont have a problem paying for a quality piece to save me from destroying the motor a year down the road... thanks guys!
If you haven't started building/buying parts yet, a stroker crank is the same $$ as a new stock stroke crank. Same with new forged pistons. The only extra $$ would be a decent set of H-beam rods if you don't already have them. Gotta buy this stuff anyway so you might as well buy it big as buy it small.
A stroker kit is one stop shopping for your bottom end. 511 cubes for little or no more money than a 446. No replacement for displacement. Best money you will ever spend.
Kevin
[Re: 78asprin]
#1378961
01/31/13 06:51 AM
01/31/13 06:51 AM
Posts: 8,941 Holly/MI
Dean_Kuzluzski
Holly/MI
450-475 HP?? A cast crank can handle that. The only reason it would destroy itself in a year is if the machining was wrong or the assembly prep.
Once you price stuff, the new crank, forged pistons & etc., it's either go KB's w/cast crank and prep'd factory LY rods or the stroker big block kit as mentioned.
If you must have a forged crank, there's always some in the Moparts Classifieds.
[Re: Dean_Kuzluzski]
#1378962
01/31/13 10:00 PM
01/31/13 10:00 PM
Posts: 324 anacortes,wa
78asprin
anacortes,wa
So far i have these for parts: performer rpm intake and fuel pump 4160 750cfm carb 440source stealth heads with 1.5 roller rockers and fabbed aluminum valve covers xe274 cam and dual roller timing chain probe +.030 pistons scat h beam rods melling oil pump and 440source windage tray 440source distributor and msd coil with accel wires billet underdrive pulleys 440source sfi flexplate and fluid damper headmann headers-full length hooked to 3" x-piped exhaust Im not 100% on hp but im guessing between 450 and 475 and Id like to eventually up the power and it would be nice to know that the bottom end is sound enough for it. I would have liked to build a stroker but ive been aquiring these parts from a guy at work who is giving up on a gtx project he was building. the price is defintely right and theres no way i could build a stroker for what i have into the parts i have now. I guess i will start looking for a stock steel crank in the classifieds then. Thanks again guys!
[Re: 78asprin]
#1378964
02/01/13 11:37 AM
02/01/13 11:37 AM
Posts: 75,061 U.S.S.A.
JohnRR
U.S.S.A.
Are those 440source rockers ? if so do yourself a favor and get rid of them NOW ....
[Re: 78asprin]
#1378965
02/06/13 11:10 AM
02/06/13 11:10 AM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
Go rockauto... rated at $300 ( as far I recall ) with bearings included
#1378966
02/08/13 01:40 AM
02/08/13 01:40 AM
Posts: 168 Washington State, USA
Winchester 73
dont waste a forged crank to swing around stock connecting rods,they would be the weak link-there are many 450 horse smallblocks with cast cranks running around.im in yelm wa and if you want ill take 100 plus your cast crank for my 413 industrial that needs polishing(slight surface rust)
[Re: Twostick]
#1378967
02/08/13 02:33 AM
02/08/13 02:33 AM
Winchester 73
Kevin
if you get a crank from your local junkyard,the junkman has a job. get it machined at the local shop and that guy has a job.get apart off graiglist and maybe that guy gets to pay his bills that month.you get to make friends with these guys and learn stuff from them.for want of a 475 horse motor id make sure not a dollar of my cash left my niehborhood much less went to china.
i hear all the time thats its cheaper to buy stuff than to recondition old stuff but personally i like putting my money right into my friends hands.my motor has a set of 906 heads that i have about 750 bones in and nobody understands why.this stuffs only cheeper to those of us who still are employed.
