sway bar brackets & mounts still available? D series #1378839
01/30/13 09:44 PM
01/30/13 09:44 PM
Crockett ,TX
9
98RAM1500 Offline OP
Crockett ,TX
I have a factory sway bar from a 78 dodge truck but no brackets, bushings & mounts, are they still available from the dealer? or is there a better option for a sway bar on the 72 to 93 D series trucks.
Re: sway bar brackets & mounts still available? D series [Re: 98RAM1500] #1378840
01/31/13 10:25 AM
01/31/13 10:25 AM
scratchnfotraction Offline
I got the small rubber end links from napa.
I have not found the bar bushings but have not looked for them either.
only bars I have came from the JY-u-pull it. I grabed it all at that time.
have you got a steering box frame brace yet? those are nice when adding the swaybar on the trucks. firms it all right up.
the borg shaft is the last upgrade I need with the frame brace and bars I have. but pricy. been looking at building my own.
good luck and post any info you find.
Re: sway bar brackets & mounts still available? D series [Re: scratchnfotraction] #1378841
01/31/13 09:48 PM
01/31/13 09:48 PM
Crockett ,TX
9
Crockett ,TX
I found 1 bracket that I had for it one that mounts on the front of the bar ( kept digging in my parts stash)but yeah any info I find I will definitly post it cause I know how hard it is finding stuff for 72 to 93 D series cause this makes my 3rd one.
Yeah im planning on getting the steering brace from dodgeconnection.com when I start cleaning, rebuilding, prepping & painting on the frame, front suspension & rear end. Whats funny I have only seen 2 trucks so far with the steering brace & the same goes for sway bars, I guess thats dodge for ya, if the person didn't order it on the truck then it sure wasn't gonna be put on it like 3.55 & lower gears, suregrips, sway bars, steering brace, ect, ect.
Another thing im will be on the look out for is a regular (non cable) hood release the one that has the lever right behind the grill. Every inside hood release I have had or seen the cable is half gone or just breaks.
Re: sway bar brackets & mounts still available? D series [Re: 98RAM1500] #1378842
02/01/13 11:24 AM
02/01/13 11:24 AM
Fortworth TX
mod5v Offline
mod5v  Offline
Fortworth TX
I have a spare original factory brace I'd be willing to get rid of.
Also selling the 84 "marksman" if anyone is looking for a rust free SWB.
