longevity of a 727 w/alum drum #1378759
01/30/13 07:36 PM
01/30/13 07:36 PM
K
KOS Offline OP
KOS  Offline OP
K
whatta you guys think with a little bit of street driving to boot how long will the drum last before needing to be replaced?
Re: longevity of a 727 w/alum drum [Re: KOS] #1378760
01/30/13 07:38 PM
01/30/13 07:38 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
a steel jacketed drum ?... 4ever
Re: longevity of a 727 w/alum drum [Re: dOrk !] #1378761
01/30/13 08:35 PM
01/30/13 08:35 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
My A&A drum is 6+ years old has over 900 passes and many street miles, still looks brand new.
Re: longevity of a 727 w/alum drum [Re: nss guy] #1378762
01/30/13 08:55 PM
01/30/13 08:55 PM
K
KOS Offline OP
KOS  Offline OP
K
Doc all aluminum........NSS thats what i like to hear i was told a while back that they would need constant adjustment and would wear out prematurely.
Re: longevity of a 727 w/alum drum [Re: KOS] #1378763
01/30/13 09:58 PM
01/30/13 09:58 PM
BigFish69 Offline
BigFish69  Offline
Had my aluminum drum for 8 years to many runs to count. This past year i replaced the brass bushing in it. It was showing some ring wear.
Re: longevity of a 727 w/alum drum [Re: BigFish69] #1378764
01/30/13 10:41 PM
01/30/13 10:41 PM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
While the drum might last a long time, our fluid goes to crap after about 30 runs, so I don't know how long you should go between fluid changes in a street driven car.
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
Re: longevity of a 727 w/alum drum [Re: BigFish69] #1378765
01/30/13 10:49 PM
01/30/13 10:49 PM
NC
440Jim Offline
440Jim  Offline
NC
That sounds about right (~600 passes). The ring surface wear depends on the type of rings used (teflon, stainless, cast, etc.) and the valve body line pressure.
The outer surface doesn't seem to wear excessively if you change the trans fluid regularly. But for any significant street driving, I would recommend an aftermarket steel drum rather than an aluminum one.
Re: longevity of a 727 w/alum drum [Re: 440Jim] #1378766
01/30/13 11:19 PM
01/30/13 11:19 PM
Fancy Farm Ky
W
wyoming Offline
wyoming  Offline
W
Fancy Farm Ky
I have an aluminum drum that is 10 years old, it's still fine, as recomended when it was installed I changed fluid every 50 runs. Drum still looks fine. Band adjustments and checks just let you know if you have wear IMHO anyway, you can check all you want, I used to check mine all the time, finally decided to quit doing that, I check it every spring now. When I bought mine I wasnt even aware they had a steel drum, mine is all strip, if I was buying one that saw some street time though, I'd go with steel, safe and would have to be more depenable on the street I'd think. I averaged about 350 runs a year for the first 6 or 7 years I had mine, just 50 or so the last 2 or 3 years.
Re: longevity of a 727 w/alum drum [Re: wyoming] #1378767
01/31/13 01:21 PM
01/31/13 01:21 PM
organ
maximum entropy Offline
organ
i prefer steel. i change my fluid every two years, and that's probably a waste. i could sell it as slightly used. a mixture of street and track time. mostly street anymore (my helmet expired).
