Re: Can somene tell me what plant this hemi block is from? [Re: cudaized] #1378730
02/02/13 08:26 PM
02/02/13 08:26 PM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
If the VIN is RM23ROA166204, I'm pretty sure it matches a known Superbird.
Scott,
If you have contact with the owner, and he would like to find the block, e-mail me.
Ola
Must be a well known numbers matching car as NO-ONE will care to elaborate....Funny how some cars have posts about them and ends up in a dog pile about fake numbers matching,fake tag,fake broadcast sheet. This collector however must be special...
Re: Can somene tell me what plant this hemi block is from? [Re: QuickBpBp] #1378731
02/02/13 08:57 PM
02/02/13 08:57 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
For all of the Negative Nancies chiming in, the car matching the VIN# I posted about IS NOT being represented as a numbers matching car.
Re: Can somene tell me what plant this hemi block is from? [Re: ScottSmith_Harms] #1378732
02/03/13 01:54 AM
02/03/13 01:54 AM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
I'm sorry. Maybe I'm not seeing it but does the fifth character really look like it could be a 6 instead of an 8?
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
Re: Can somene tell me what plant this hemi block is from? [Re: 69CoronetRT] #1378733
02/03/13 02:06 AM
02/03/13 02:06 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
0A158204 is what I see, but if it's 0A166204 as depicted as one of the possibilities in the animation, it's the block from a known Superbird
Re: Can somene tell me what plant this hemi block is from? [Re: ScottSmith_Harms] #1378734
02/03/13 02:33 AM
02/03/13 02:33 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
A direct, straight on photo would help, photos taken at an angle are not always easy to judge.
Re: Can somene tell me what plant this hemi block is from? [Re: ScottSmith_Harms] #1378735
02/03/13 01:31 PM
02/03/13 01:31 PM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
"The car matching the VIN# I posted about IS NOT being represented as a numbers matching car."
Fixed!
That's all you had to say since you apparently knew of the car...
Calling names only shows a lack of "real" intelligence. Sorry you are unable to converse with-out doing so.....
Re: Can somene tell me what plant this hemi block is from? [Re: QuickBpBp] #1378736
02/03/13 02:03 PM
02/03/13 02:03 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Fixed!
"Fixed"?
Fixed what exactly?
Re: Can somene tell me what plant this hemi block is from? [Re: ScottSmith_Harms] #1378737
02/03/13 02:15 PM
02/03/13 02:15 PM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
Fixed!
"Fixed"?
Fixed what exactly?
It's hopeless if you can not understand what I wrote....
Re: Can somene tell me what plant this hemi block is from? [Re: QuickBpBp] #1378738
02/03/13 02:54 PM
02/03/13 02:54 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Yes, apparently I'm hopless and ignorant Now that that's out of the way, do you have anything positive or helpful to add to the thread?
Re: Can somene tell me what plant this hemi block is from? [Re: ScottSmith_Harms] #1378739
02/03/13 04:05 PM
02/03/13 04:05 PM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
Re: Can somene tell me what plant this hemi block is from? [Re: Alaskan_TA] #1378740
02/03/13 05:29 PM
02/03/13 05:29 PM
South, FL
cudaized Offline OP
cudaized  Offline OP
South, FL
I have asked for additional photos. Hopefully there will be a better view.
Thank you everyone for helpinig.
Re: Can somene tell me what plant this hemi block is from? [Re: ScottSmith_Harms] #1378741
02/03/13 07:21 PM
02/03/13 07:21 PM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
Yes I do and glad you asked. It's spelled hop E less
Hopless? Is that a paralysed kangaroo?
As far as the thread I was just curious about the car whether it was so-called numbers matching...carry on.
