Can somene tell me what plant this hemi block is from? #1378710
01/30/13 07:01 PM
01/30/13 07:01 PM
South, FL
cudaized Offline OP
cudaized  Offline OP
South, FL
Please look at the pictures.
Ola Nilsson
Re: Can somene tell me what plant this hemi block is from? [Re: cudaized] #1378711
01/30/13 07:02 PM
01/30/13 07:02 PM
South, FL
cudaized Offline OP
cudaized  Offline OP
South, FL
second picture
Re: Can somene tell me what plant this hemi block is from? [Re: cudaized] #1378712
01/30/13 07:14 PM
01/30/13 07:14 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Looks like a Lynch Road car. What is stamped on the underside of the oil pan rail extension?
Re: Can somene tell me what plant this hemi block is from? [Re: ScottSmith_Harms] #1378713
01/30/13 07:40 PM
01/30/13 07:40 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
Wing car ????
MLR426
Re: Can somene tell me what plant this hemi block is from? [Re: MLR426] #1378714
01/30/13 08:24 PM
01/30/13 08:24 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
Since it's from Lynch Road, we know it's a B body.
Trying to bracket the VIN...
157495 is a Coronet based car
158204 this block
158333 is a Coronet based car
168001 is a Belvedere based car
168204 this block
168440 is a Coronet based car
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
Re: Can somene tell me what plant this hemi block is from? [Re: 69CoronetRT] #1378715
01/31/13 03:02 AM
01/31/13 03:02 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
0A158146 - is a Coronet
0A168175 - is a Coronet
That's some "RARE" stuff right there!! Less than 60 HEMI Coronets in 1970.
WM21R0A158042 is one of the CANADA spec. '70 HEMI Super Bees
Re: Can somene tell me what plant this hemi block is from? [Re: 6bblgt] #1378716
01/31/13 03:55 AM
01/31/13 03:55 AM
Sonora, CA
68X426 Offline
68X426  Offline
Sonora, CA
The OP's question was what plant the Hemi block came from.
All Hemi blocks came from the Trenton (Michigan) Engine Plant.
All Hemi engines were assembled and tested in Marysville, Michigan. I believe the official title was the Chrysler Industial and Marine Plant.
The 12 Scariest Words in the English Language: We are here from the Government and we want to help you. 1968 Plymouth Road Runner, Hemi and much more 1968 Dodge Charger, 318 and not much else 1958 Dodge Pick Up, 383 and loud 1966 Dodge Van, Slant 6 and cool
Re: Can somene tell me what plant this hemi block is from? [Re: ScottSmith_Harms] #1378717
01/31/13 09:03 PM
01/31/13 09:03 PM
South, FL
cudaized Offline OP
cudaized  Offline OP
South, FL
Scott, I will have to ask the owner to look.
Re: Can somene tell me what plant this hemi block is from? [Re: MLR426] #1378718
01/31/13 09:04 PM
01/31/13 09:04 PM
South, FL
cudaized Offline OP
cudaized  Offline OP
South, FL
Wing car ????
MLR426
Martin, I am not sure. Hopefully we can figure this mystery out.
Re: Can somene tell me what plant this hemi block is from? [Re: 6bblgt] #1378719
01/31/13 09:07 PM
01/31/13 09:07 PM
South, FL
cudaized Offline OP
cudaized  Offline OP
South, FL
158204 this block
168204 this block
Doug and Dan,
Thank you for the possible placement of this block. It would be interesting if we could find the original car for this.
Re: Can somene tell me what plant this hemi block is from? [Re: cudaized] #1378720
01/31/13 09:08 PM
01/31/13 09:08 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
1970 Hemi Superbird Orange/black, column auto
Re: Can somene tell me what plant this hemi block is from? [Re: 68X426] #1378721
01/31/13 09:08 PM
01/31/13 09:08 PM
South, FL
cudaized Offline OP
cudaized  Offline OP
South, FL
Daniel, Thank you for the info.
Re: Can somene tell me what plant this hemi block is from? [Re: ScottSmith_Harms] #1378722
01/31/13 09:11 PM
01/31/13 09:11 PM
South, FL
cudaized Offline OP
cudaized  Offline OP
South, FL
1970 Hemi Superbird Orange/black, colun auto
Scott, that would be something!
Would you happened to know that car? Is it missing the original block?
I have access to this hemi block. The goal is to reunite.
1970 `cuda340 convertible 4-speed Rallye Red with Red interior
cudaized.com
1970-71 Plymouth and Dodge E-Body Convertible Registry
ebodyconvertibleregistry.com
Re: Can somene tell me what plant this hemi block is from? [Re: cudaized] #1378723
01/31/13 09:17 PM
01/31/13 09:17 PM
South, FL
cudaized Offline OP
cudaized  Offline OP
South, FL
Gentelmen,
What information can I get from this block, (besides the oil pan rail info), that could help our knowledge and possible placement.
The current owner wanted me to try and learn about this block, to see if an existing car is missing it, and to reunite the two. Engine is currently in VA.
I appreciate all your detective work.
cudaized.com
Re: Can somene tell me what plant this hemi block is from? [Re: cudaized] #1378724
01/31/13 09:37 PM
01/31/13 09:37 PM
South, FL
cudaized Offline OP
cudaized  Offline OP
South, FL
Some more info from owner.
Re: Can somene tell me what plant this hemi block is from? [Re: cudaized] #1378725
01/31/13 09:43 PM
01/31/13 09:43 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
Help me out Scott....
I'm looking at a sorted list of SB VINs. Superbird VINs sorted by sequence
37 RM23 U 0A 155797 5-Nov 13-Nov
32 RM23 V 0A 155798 5-Nov 11-Nov
182 RM23 V 0A 155799 11-Nov 12-Nov
21 RM23 V 0A 155800 4-Nov 14-Nov
18 RM23 V 0A 155801 4-Nov 12-Nov
25 RM23 V 0A 155802 5-Nov 12-Nov
86 RM23 V 0A 155803 7-Nov 14-Nov
120 RM23 R 0A 158577 10-Nov 10-Nov
296 RM23 R 0A 158578 13-Nov 14-Nov
33 RM23 R 0A 158579 5-Nov 10-Nov
267 RM23 R 0A 158580 13-Nov 17-Nov
714 RM23 V 0A 167967 21-Nov 21-Nov
693 RM23 V 0A 167968 21-Nov 21-Nov
1055 RM23 U 0A 167969 1-Dec 2-Dec
705 RM23 V 0A 167970 21-Nov 26-Nov Span 13 90 848
? RM23 V 0A 167982 Joe Ward List
669 RM23 V 0A 168702 20-Nov 21-Nov
964 RM23 U 0A 168703 28-Nov 1-Dec
1018 RM23 U 0A 168704 1-Dec 1-Dec
that specific VIN either in 158204 or 168204 form, doesn't appear on the list.
Are there other Superbirds that have popped up that are not on the original list?
It seems odd that a RM VIN would pop up in the middle of some W* cars.
Any insight you can offer?
Seeking:
Re: Can somene tell me what plant this hemi block is from? [Re: cudaized] #1378726
01/31/13 10:19 PM
01/31/13 10:19 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
If the VIN is RM23ROA166204, I'm pretty sure it matches a known Superbird.
Re: Can somene tell me what plant this hemi block is from? [Re: ScottSmith_Harms] #1378727
02/01/13 12:00 AM
02/01/13 12:00 AM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
Story could get interesting if that one is already "numbers matching"....
Re: Can somene tell me what plant this hemi block is from? [Re: QuickBpBp] #1378728
02/01/13 01:29 PM
02/01/13 01:29 PM
dogdays Offline
dogdays  Offline
YEP! We need another category called "Really numbers matching"!
R.
Re: Can somene tell me what plant this hemi block is from? [Re: ScottSmith_Harms] #1378729
02/01/13 10:45 PM
02/01/13 10:45 PM
South, FL
cudaized Offline OP
cudaized  Offline OP
South, FL
Scott,
If you have contact with the owner, and he would like to find the block, e-mail me.
Ola
cudaized.com
