Re: Amp meter to volt meter "?"
[Re: bigblock340power]
#1378472
01/30/13 11:09 AM
01/30/13 11:09 AM
RapidRobert
Put both ammeter wires on the same ammeter stud to bypass the ammeter if you want to eliminate the ammeter (if I'm reading this right) & check/clean the ring terminals first. Neg voltmeter terminal/case to ground, Positive voltmeter terminal to switched 12V either fuse box or ign switch ign1 (run) wire
[Re: meepmeep70]
#1378475
01/30/13 03:01 PM
01/30/13 03:01 PM
Russ H.
is there a volt meter that will fit ion a rally dash?
If a volt meter is not available, can the old amp meter be converted to one?
Russ
[Re: roadrunninMark]
#1378478
01/30/13 05:32 PM
01/30/13 05:32 PM
Russ H.
Russ, I asked that too in the other thread. So far, no responses yet. Also, what X has diagrammed, is this known as the "MAD bybass"? The idea is to bypass the ammeter and add a volt meter, correct?
Yes, my idea is to convert my amp gauge to read volts. I have been digging and ran across an outfit in California called Red Line Gauge Works. www.redlinegaugeworks.com They perform amp to volt conversions and keep the face looking original. I read posts on another board giving high praises to their work.
I now wonder how a volt gauge gets wired into the system? Maybe someone can explain.
Russ
[Re: stumpy]
#1378480
01/30/13 05:56 PM
01/30/13 05:56 PM
Russ H.
Any 12v keyed power to one side of the gauge and the other side to ground.
Thank you, Sounds simple enough......
[Re: Russ H.]
#1378481
01/31/13 01:15 AM
01/31/13 01:15 AM
Posts: 7,664 IN
ahy
IN
That will get you going with a $10 +/- parts store voltmeter. You can also get your OE ammeter converted to a voltmeter for a near stock look by a gauge shop (I did) or DIY per a MA article.
[Re: XS22440SE]
#1378484
01/31/13 05:44 PM
01/31/13 05:44 PM
Posts: 208 Norrland, Sweden
Swedcharger67
Norrland, Sweden
i jut did the Mad bypass. i then ran a new volt gauge wired out of a switched hot from the fusebox and grounded at the dash frame
I don't want to be a PIA but also here you have several points that can melt down with bad maintenance. Things melt down when you have loose connections, corroded connections, half-cut thru wires etc. An ammeter with tight connections doesn't melt down, it's a solid piece of metal and will probably be the last thing that melts down in your car. But, with loose connections and bad connectors things happen!
Martin, 67 Charger, 512 cui, E85, MegaSquirt MS3X sequential ignition & injection
