Amp meter to volt meter "?" #1378470
01/30/13 10:34 AM
01/30/13 10:34 AM
Elk Grove, Calif.
bigblock340power Offline OP
Elk Grove, Calif.
I want to change my amp meter to a volt meter in my truck. Now, the org. amp meter was abandoned in lew of a separate gage on the dash years ago (yep, the common melt down problem was the culprit for the change). The wires from the org. amp meter were just removed, and moved to make the new gage work. What do I have to do to make this a volt meter, and get rid of the amp meter? Not really looking to make the org. amp meter a volt meter. Just the newer one.
Re: Amp meter to volt meter "?" [Re: bigblock340power] #1378471
01/30/13 11:07 AM
01/30/13 11:07 AM
weymouth,mass.
meepmeep70 Offline
meepmeep70  Offline
weymouth,mass.
Re: Amp meter to volt meter "?" [Re: bigblock340power] #1378472
01/30/13 11:09 AM
01/30/13 11:09 AM
Put both ammeter wires on the same ammeter stud to bypass the ammeter if you want to eliminate the ammeter (if I'm reading this right) & check/clean the ring terminals first. Neg voltmeter terminal/case to ground, Positive voltmeter terminal to switched 12V either fuse box or ign switch ign1 (run) wire
Re: Amp meter to volt meter "?" [Re: RapidRobert] #1378473
01/30/13 01:43 PM
01/30/13 01:43 PM
weymouth,mass.
meepmeep70 Offline
meepmeep70  Offline
weymouth,mass.
is there a volt meter that will fit ion a rally dash?
Re: Amp meter to volt meter "?" [Re: bigblock340power] #1378474
01/30/13 01:52 PM
01/30/13 01:52 PM
Colorado
XS22440SE Offline
XS22440SE  Offline
Colorado
i jut did the Mad bypass. i then ran a new volt gauge wired out of a switched hot from the fusebox and grounded at the dash frame
Re: Amp meter to volt meter "?" [Re: meepmeep70] #1378475
01/30/13 03:01 PM
01/30/13 03:01 PM
Russ H. Offline
Russ H.  Offline
If a volt meter is not available, can the old amp meter be converted to one?
Russ
Re: Amp meter to volt meter "?" [Re: Russ H.] #1378476
01/30/13 04:16 PM
01/30/13 04:16 PM
GA
roadrunninMark Offline
GA
Russ, I asked that too in the other thread. So far, no responses yet. Also, what X has diagrammed, is this known as the "MAD bybass"? The idea is to bypass the ammeter and add a volt meter, correct?
Re: Amp meter to volt meter "?" [Re: roadrunninMark] #1378477
01/30/13 05:29 PM
01/30/13 05:29 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
If I remember correctly, back when I had all my gauges restored by (I think) Auto Instruments (its been a good while) I asked about changing mine over to volt & they said they could, but I changed my mind at the time.
Re: Amp meter to volt meter "?" [Re: roadrunninMark] #1378478
01/30/13 05:32 PM
01/30/13 05:32 PM
Russ H. Offline
Russ H.  Offline
Yes, my idea is to convert my amp gauge to read volts. I have been digging and ran across an outfit in California called Red Line Gauge Works. www.redlinegaugeworks.com They perform amp to volt conversions and keep the face looking original. I read posts on another board giving high praises to their work.
I now wonder how a volt gauge gets wired into the system? Maybe someone can explain.
Russ
Re: Amp meter to volt meter "?" [Re: Russ H.] #1378479
01/30/13 05:52 PM
01/30/13 05:52 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Any 12v keyed power to one side of the gauge and the other side to ground.
Re: Amp meter to volt meter "?" [Re: stumpy] #1378480
01/30/13 05:56 PM
01/30/13 05:56 PM
Russ H. Offline
Russ H.  Offline
Thank you, Sounds simple enough......
Re: Amp meter to volt meter "?" [Re: Russ H.] #1378481
01/31/13 01:15 AM
01/31/13 01:15 AM
IN
ahy Offline
ahy  Offline
IN
That will get you going with a $10 +/- parts store voltmeter. You can also get your OE ammeter converted to a voltmeter for a near stock look by a gauge shop (I did) or DIY per a MA article.
Re: Amp meter to volt meter "?" [Re: ahy] #1378482
01/31/13 12:21 PM
01/31/13 12:21 PM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
Here's a step by step I posted some time ago.
Amp to Volt meter
Re: Amp meter to volt meter "?" [Re: Cudajon] #1378483
01/31/13 02:54 PM
01/31/13 02:54 PM
Richmond Twp. Mi.
Mr340 Offline
Mr340  Offline
Richmond Twp. Mi.
Amp to Volt meter
Just finished converting mine
thanks for the write up
Re: Amp meter to volt meter "?" [Re: XS22440SE] #1378484
01/31/13 05:44 PM
01/31/13 05:44 PM
Norrland, Sweden
Swedcharger67 Offline
Norrland, Sweden
I don't want to be a PIA but also here you have several points that can melt down with bad maintenance.
Things melt down when you have loose connections, corroded connections, half-cut thru wires etc. An ammeter with tight connections doesn't melt down, it's a solid piece of metal and will probably be the last thing that melts down in your car.
But, with loose connections and bad connectors things happen!
Martin, 67 Charger, 512 cui, E85, MegaSquirt MS3X sequential ignition & injection
Re: Amp meter to volt meter "?" [Re: Swedcharger67] #1378485
01/31/13 06:52 PM
01/31/13 06:52 PM
Cab_Burge Online work
Cab_Burge  Online Work
The back side nuts come loose causing a high resistance connection through the threads of the stud and nut resulting in high heat,melting stuff, causing fires and so on Mopar made all the current from the charging circuit go through the amp gauge
Re: Amp meter to volt meter "?" [Re: Cab_Burge] #1378486
01/31/13 11:40 PM
01/31/13 11:40 PM
GA
GA
looks great CudaJohn, thanks for sharing
