Which Cometic head gasket for Source heads? #1378466
01/30/13 10:11 AM
01/30/13 10:11 AM
Florida-West Coast
Thor500 Offline OP
Thor500  Offline OP
Florida-West Coast
Had a cylinder to cylinder blowout after only 50 runs with the white 440 source gaskets, was thinking I'd step up and put Cometic mls gaskets on. Jegs has about 20 different variations listed, anyone know what size and thickness I should order? The motor is 12:1 590mp cam, 180psi cranking pressure. Runs 11:50 in a 4000# car. Thanks for any help.
Re: Which Cometic head gasket for Source heads? [Re: Thor500] #1378467
01/30/13 11:33 AM
01/30/13 11:33 AM
Florida-West Coast
Thor500 Offline OP
Thor500  Offline OP
Florida-West Coast
Pic of damage.
Re: Which Cometic head gasket for Source heads? [Re: Thor500] #1378468
01/30/13 11:38 AM
01/30/13 11:38 AM
Florida-West Coast
Thor500 Offline OP
Thor500  Offline OP
Florida-West Coast
Can this just be welded and resurfaced?
Re: Which Cometic head gasket for Source heads? [Re: Thor500] #1378469
01/30/13 12:39 PM
01/30/13 12:39 PM
dogdays Offline
dogdays  Offline
Been done for ages.
Have a pro do it.
Dan at Performance Only should be able to help, he's in FLA too.
As far as the gasket goes, figure out which bore size you need and then how thick the gasket should be for decent squish.
R.
